Davenger
It's only metal
Club RR Member Number: 140
Garage buddyDavenger
@dminifreak
Club Retro Rides Member 140
Oct 13, 2011 20:28:44 GMT
Just found a great free app on android market called garage buddy. Full of useful conversin tables and calculators. Just thought I'e let you lovely folks know about it.
market.android.com/details?id=com.turtlerockstudios.garagebuddy.free&feature=search_resultThe BEST app for car guys who like to wrench! Finally an app for car guys and gals who like to wrench! Welcome to Garage Buddy, your one stop shop for car themed calculators, converters, tables and more. -Want to go from 15 inch wheels to 17's? Garage Buddy can tell you what size tire to buy so your speedometer remains accurate. -Adding Air Conditioning to your hotrod and need to know what size belt to buy? Garage Buddy has the answer! -Going to put some big 33's on your 4x4 and need to re-gear? Garage Buddy can tell you how low to go! -Want to know what size carb to put on your new V8? Punch in a few numbers and Garage Buddy will tell you what CFM you'll need! Garage Buddy can handle the simple stuff too, like converting metric to standard. There are conversions for Speed, Distance, Volume, Torque, Weight, and Pressure. There's also a helpful notes section, where you can record important information for each of your cars, such as spark plug gap, part numbers, oil weights, etc. This is super handy to have with you when you go to the parts store. Garage Buddy includes the following: Engine Displacement Compression Ratio RPM Units Converter Tire Size Calculator Carb Flow Calculator HP Loss at Altitude Belt Size Calculator Gearing Calculators Tap Drill Size Chart Drill Bit Size Chart Metal Gauge Chart Wire Gauge Chart Tool Conversion
Last Edit: Oct 15, 2011 8:00:09 GMT by Soopahfly
