I'm clearing out the spare room in my flat and I need to get rid of stuff I deem "too good to through away" ;D
BGA rocker cover gasket (pair) for 2.9 Colonge/Ford V6 - £5
extendable wing mount towing mirror - £10
Bilstein non-adjustable shock absorbers to it Ford Sierra 4WD (XR, cosworth ect) - £30
Hadrian wheel arch repair panels for Ford Sierra Saff (LH and RH) - £10 the pair
Modified (read cut up) Ford Mondeo cooling fan, was fitted to my old green Sierra. Could fit others with little work - £5
Bosch alternator and starter motor off my old E30 318i, both in good working when removed from old engine - £5 each
Pair of 2.5 inch coilover springs 6" length 500lb (note NOT 2.25 inch) - £15 the pair
Cheap and cheerful power drill - £5
Obviously some stuff isn't worth posting and is probably worth collecting, but if you want anything posted I'll happily find out how much it'll cost. Failing that I'll be at A52 on the 15-16 October.
Thanks for looking Robin
