79cord
Eliminating Voltage regulator?ChasR
@chasr
Club Retro Rides Member 170
I guess going to a more modern alternator. A Cortina bod no doubt should point you in the right direction (Probably done on cars with a Cossie engine).
79cord
I was actually thinking of this for my old Accord but it would no doubt be of wider interest and applications. Any ideas when internally regulated Alternators started to be introduced (would obviously vary with manufacturer), or other potential wiring changes required to adapt them to older cars ?
Last Edit: Oct 1, 2011 10:10:29 GMT by 79cord
An internally regulated alternator only needs a connection for the battery (the heavy cable) and a wire to the charge light. If you're not interested in a charge light you can just wire in a resistor between the charge light post and the output terminal. Simples!
1994 Rover Metro 1994 Peugeot 405 Estate 1991 Rover Metro Gti 16v 2001 Fiat Seicento Sporting 1999 Fiat Punto 1.2 1994 Peugeot 106 Xnd (x3) 1991 Westfield 7 2004 Landrover 110 SW 2003 Seat Ibiza 1.9Tdi Sport 1959 Ford 107e Prefect 1992 Suzuki Vitara 2008 Skoda Fabia
79cord
Last Edit: Oct 1, 2011 11:56:07 GMT by 79cord
bortaf
R.I.P photobucket
