Model: Scirocco GTII
Year: 1990
Mileage: 125k
Tax: Sept 2011
MOT: June 2012
Current owner: Me...
V5 present: Yes
Price: £800 or swaps, see below
hi, up for sale is my rocco, not had this long but I'm after something a bit different now. (got it as a run about for when I'm at college but not off now!!!)
Good points - the interior is in really good nick, the car is standard apart from a CD player and rear speakers (all in black so tasteful!) and a certified immobiliser. In the past year this car has had a replacement gearbox and new clutch, battery, radiator, fan, water reservoir, front shocks and replacement carburetor. Also January engine service with new HT leads, vacuum piping etc. Loads of receipts and history available.
also I changed the oil and filter today. and the valve that controls the heater (they start to stick and the heater will only blow hot)
bad points - its dirty (most of which was from going to leeds fest)...will have had a full inside and out clean when it stops raining...
the rear quarters both have dents/ scratches in them, the drivers door has started to peel, apart from that the body work is good, I gave it a full polish and wax when I got it and will do again.
the carb is a pierburg and therefore has its issues, cold start is fine but idels a bit high for a few mins, then its runs fine. hot start sometimes takes a bit to get going, but again its fine when going.
in the short time ive had it ive done over 2000 miles with no probs (wish my other roccos were as reliable!)
it wont come on the sebrings, it will be coming on the bbs's that were on it when I got it, which need a refurb to be honest.
right, I'm after 800 or swap for a E30 (any considered), e36 (318 is or above), mk1 or mk2 toyota mr2, or poss a merk 190.
no diesels, french, fords, other J. german or a a mr2 only ;D
my mobile is 07584307252 email is riklyons@gmail.com, txt/email will be quickest
Year: 1990
Mileage: 125k
Tax: Sept 2011
MOT: June 2012
V5 present: Yes
