Fungus
Aug 20, 2011 16:47:58 GMT
Fungus
Aug 20, 2011 16:49:04 GMT
Aug 20, 2011 23:45:43 GMT
got the following new pattern parts if any use
clutch hose (59-84) £2 frt brake hose (59-67) £2 12 inch wheel brake pads £5 cooper/S air filter (60') £1 ball joint (x2) £5 each or £8 pair upper wish bone kit £8mirror glass (80's) pair £2 clutch release bearing std type x2 £3 or £4 pair pressure plt 1.3 (82-89) std type £5 pressure plt (62-82) £5 pressure plt (81-82) £5 clutch plt (59-82) 181mm/51mmx32 £5 realease bearing (82-) verto £3 clutch plate (82-90) verto X2 181mm/51mmx22 £5 each.rear exhaust mount (74-) X7 50p each manifold clamps X8 £1 each. dizzy cap (70's) £2 rotor arm (80's) £1 rear wheel cyl seal kits (74-77) X3 £1 rear wheel cyl (74-) ns X2 £3 each caliper seal kits mk1/2 cooper (not S) (62-69) X3 £3 each. brake master cyl seal kit single line (69-77) £1 A+ head gasket (1275)£1 A+ head set (1275)£4 steering rack gaiters pair £2 duplex timeing chain £2 850cc inlet valves X2 sets £5 per set heater cable £1rear eng mount (59-79) £2 eng steady rubber set £2 auto frt eng mount X2 £3 screen washer pump (82-)£5
all plus P&P will discount for multi buys, swap for mk3/4/5/p100 cortina bits.
theres more to life than mpg & to much power is just enough.
Aug 20, 2011 23:58:21 GMT
try world of parts ltd for panels www.worldofpartsltd.co.ukuse codes for discount etc MINIMAG = 5% Discount WOP0511 = Free UK Delivery hope that helps Jordie
Jordie
Aug 22, 2011 19:12:21 GMT
I've got a set of good rubber cones and i'm not very far away from you....
Fungus
Aug 22, 2011 21:47:38 GMT
sheffieldcortinacentre - I'll give you a PM for bits as soon as some more of mine have gone.
jordie- thanks, looks like a good site!
ShavedHeadedYob - How much you after? are they new? and whereabouts are you?
Aug 22, 2011 22:26:08 GMT
ok no prob
Aug 23, 2011 19:42:43 GMT
They are used (£10 each) and 'I'm in Clacton.
