Lots of bits for sale, I’ll start with the bits that’ll probably sell easy. Open to offers on everything, including combinations. Going to say collection only, given most of this is big and heavy. I’m in Southam, Warwickshire.
Mk2 Escort Fibreglass bonnet, will full internals. £70 ONO
Got a bit of light crazing on the front RH corner, and has blistered paint a bit. Easy fix with some paint and a touch of resin.
Mk2 Escort Saloon bootlid, with intergral spoiler and internals. £50 ONO
This wasn’t on the car all that long, and is basically in perfect condition. Has two catches on the lower edge (for standard spring catches) which could easily be removed and the holes filled.
Mk2 Escort Saloon rear window. £10 ONO
Good condition, think a couple of the elements have gone, stickers will come off easy.
Mk1 & 2 Front Floor Pans. £10 each.
LH & RH pans, as new.
MK1 2 door saloon&estate/Mk2 Escort Estate Drivers Side door. £50 ONO
Frame has lots of surface rust at bottom, but basically sound. Skin has bump and crease in it, and has gone in lower corners. Easy reskin.
MK1 2 door saloon&estate/Mk2 Escort Estate Passenger Side door. £50 ONO
Frame is basically sound, but last owner seems to have put some filler in. Don’t think it’s hiding much though. Skin is starting to go in lower corners and under window, but not bad really.
Mk1/2 Estate Tailgate. £50 ONO
Very solid, just starting to go around screen seal, but not rotten. Very few this solid around. Has a bump in the rear, but will knock out pretty well.
1978 Mk2 Escort Estate Shell, with V5. £200 ONO
The doors and tailgate come from this, I will do a deal for someone if they want to take all of them together, make me an offer.
Bought this as a replacement for my sadly deceased Mk2 2 Door. Plans have changed since buying a Mk1 Capri!
Shell was in a garage for 21yrs apparently. I have new type V5 in my name. Lots of photos here – s40.photobucket.com/albums/e246/phoenix_escort/Escort%20Mk2%20Estate%20Shell/
It is solid in the important places: strut tops just starting to go, chassis rails basically solid – need couple of patches; original sills – been patched, but actually pretty solid. Sadly the floors have gone, and someone made a mess pulling it from the front, this has just damaged the front panel & support, not the main structure of the shell. Also going along RH roof drip rail, but not too hard to fix. Few small holes around tailgate, but easy fix and the boot floor is solid! The rear arches are going, but not badly, would patch easy. Body itself has a few bumps, but won’t take much to straighten
What it comes with – not a lot, tank is in there, as is rear seat, front x-member, rear lights (including one new lens), wiring harness and a few other bits (dash I think etc) few rear brake bits.
Minimum panels it needs: Wings, Front Panel, Bonnet, all floor pans, splash panels, wing mounting rails + patches.
It’s on a trolley at the moment, so easy to get it near a trailer. When I bought it we moved it on a flat bed and lifted it with one guy on each corner – so you’ll need 3 mates with you to move it.
PM me, or call: 07759 495294 or email at phoenixmk2escort@hotmail.com if you want to come have a look at anything, or make me an offer. Whatever doesn’t sell in the next week or so will end up on ebay.
Cheers
Andy
Cheers
Andy
