hillman carbhillminx
@GUEST
hi, is there another carb which could be used on a superminx with 1500 engine? fitted with zenith at moment.
cheers chris.
Davenger
It's only metal
Club RR Member Number: 140
hillman carbDavenger
@dminifreak
Club Retro Rides Member 140
My dad ran a twin choke webber on his 1600 Singer Vogue back in the day. Can't imagine the manifolds are easy to come by though
Davenger
It's only metal
@dminifreak
Dez
Club RR Member Number: 34
hillman carbDez
@dez
Club Retro Rides Member 34
34 ich weber from a landy, providing your manifold has the later wider manifold stud spacing. it should be approx 65mm as opposed to the earlier 60mm. the last one I played with didnt so he had to change the manifold too- the rest of the manifold is identical, and the same as a 1725 one too.
my commer had the same carb fitted, bought brand new at great expense from speedyspares by the previous owner, just before i bought the van. it ran really well with it on.
Last Edit: Jul 7, 2011 19:07:23 GMT by Dez
Seth
If its an Iron head then I guess a manifold like my Minx's with a single Stromberg CD150 would go on but might well need exhaust matching up.
Also, I have seen little elbow adapters to bolt to down draught manifolds to allow fitment of an SU so that would be another possibility.
@GUEST
thanks guys, ouch on that weber manifold!!!! like the idea of ich dez, will have a measure. your correct seth, would need to change exhaust manifold.
cheers chris.
