Four of, brand new. Were going to go on my Zodiac, but that's not going to happen.
NEVER BEEN ON A WHEEL!
Here's some blurb...
Cooper Zeon XTC:
Three Section Tread Pattern: The inside shoulder is designed to efficiently disperse water from under the contact patch, while at the same time its tread blocks are of computer optimised shape to dramatically reduce noise levels. The centre section of the tread pattern combines diagonal grooves with an unbroken circumferential ring to sharpen steering response and resist aquaplaning. Finally, the outer shoulder employs tread blocks designed to promote cornering stability, adding to the Zeon XTC’s confidence inspiring behaviour at the limit of its grip.
Low Noise Levels: The Cooper Zeon XTC is designed to be comfortably within the latest EU directives on noise levels without sacrificing traction and all weather handling.
£125 for all four, located in Bristol. Not bad considering they're normally £45 a pop.
Chris
Cooper Zeon XTC:
Chris
