Chaps Car is a '99 Passat What I thought was just a blown bulb has turned out not to be the case. Drivers side front indicator.. I polled the unit out and the bulb looked fine? I turned the ignition on and put the indicator on and it worked!? So I though loose wire? I put it back together and it didnt work again? Took it out again and it worked and I left the indicator on whilst I fitted the unit back to the car - all good.. Tunred the car on/off a couple of times whilst checking and I thought all was well.. Went to work this mornining - doesnt work again Ive got MOT this saturday and I need to fix this problem out quick! Any ideas?
Current retro - 1996 Alfa Romeo GTV / Daily - 2016 Nissan Qashqai Previous retros - Prelude, Integra, XR2s, XR3s, Orions, CRXs, Sylvia S12, S13, Pulsar, ZX 16v, 205 Gti, MX5, MR2 etc
crazymonkey
ummm....what was I doing again???
sounds like a dodgy connection or something along those lines if it works then doesnt (bulb holder possibly?). I know our old passat was an electrical nightmare
whoever said dogs were man's best friend....obviously never heard of cable ties
so would i splice another bulb holder on do you think? got to the scrappy perhaps?
Put another bulb in i've had that happen with 'good' bulbs before. 501 sidelight bulbs usually do the same thing, i'd imagine that there's something broken inside that makes a contact sometimes.
Matt
30psi
Jun 22, 2011 10:34:59 GMT
Check the quality of the earth
1962 Ford Thunderbird 6.4L
1981 Datsun Bluebird SSS CA18DET
1981 Datsun Bluebird SSS SR20DE
barty
Jun 22, 2011 15:41:34 GMT
both of the above, check for a good earth and change the bulbs, they are anly a few quid so no great cost there.
bl1300
Jun 22, 2011 16:46:31 GMT
Check the earth sounds very much like a bad earth fault to me. If you can unbolt the earth clean it with some wet and dry and then refit. This quite often works.
Something that I have to do on my own car from time to time admitadly on the side lamps is to push the possitive wire into the holder and that makes it work again.
Oh and as others have said change the bulb again as some are duff as new
Current fleet.
Jun 22, 2011 17:39:58 GMT
Does it work if you hit the hazard switch? that would narrow down the fault finding mission..
1989 Mini MG 1275 ~ 1987 VW Polo ~ 1989 Citroen 2CV ~ 1998 VW T4 ~ 2006 Volvo XC70
Jun 22, 2011 23:57:40 GMT
Put another bulb in i've had that happen with 'good' bulbs before. 501 sidelight bulbs usually do the same thing, i'd imagine that there's something broken inside that makes a contact sometimes. Matt Try a couple. A couple of months ago the nearside stop lamp in my wife's jag quit working. I tried an extra bulb - nothing. Swapped in the bulb from the offside stop lamp - still nothing. Dropped it off at my mechanic and asked him to get it sorted. "It just needed a new bulb mate"
1995 Range Rover 4.0 1995 BMW 320i Saloon 1989 BMW 325i Touring 1991 Mercedes 300TE-24 1991 Mercedes 190e 1970 Sunbeam Imp Sport
1966 Valiant 200 Custom 1964 Ford Fairlane 500 Station Wagon
Jun 26, 2011 20:39:18 GMT
The new bulb did work although I still failed the MOT :sad:
Drivers side front wishbone excessive play (Ive bought both the front and back to replace - £63 for the both)
Rear pads 'low' although braking power fine? Anyway new rear pads cost me £15
And a headlight bulb was out... Well its 'intermitent' I gave it a whack and it come on... Ive since replaced that bulb and seem fine now?
+ £50 to get the above fitted by a mate/mechanic and fingers crossed!
bl1300
Jun 26, 2011 21:01:38 GMT
The new bulb did work although I still failed the MOT :sad: Drivers side front wishbone excessive play (Ive bought both the front and back to replace - £63 for the both) Rear pads 'low' although braking power fine? Anyway new rear pads cost me £15 And a headlight bulb was out... Well its 'intermitent' I gave it a whack and it come on... Ive since replaced that bulb and seem fine now? Point number 1. That play is most likely a worn bush or two can you not just replace the bushes rather than the whole wishbone? Number 2. sounds like that would have been an advice to me, but it best fixed now before they wear all the way down to the backing and start scoring the disc. Number 3. If it comes on by whacking it, its probably a bad earth. Beware though that the tester is may do exactly what you did on a retest and give it a whack, if it flickrs when he does it, it will fail again.
Current fleet.
Jun 26, 2011 21:09:43 GMT
Headlight bulb might have broken down internally same as I said for the indicator if a new bulb fixed it.
Matt
Jun 28, 2011 13:22:23 GMT
Bulb had blown in the past most likely!
Arms are cheaper and easier to change over bushes.
Regarding the indicator fault I had a similar issue with the 205. Random in operation etc. Turned out to be a dirty bulb holder. Some switch cleaner (WD40 may do if you are stuck) later and it has been fine.
murran
Jun 28, 2011 22:49:41 GMT
tossers, these don't have wishbones as such. they have suspension arms... two upper and two lower, you cant buy the bushes or the ball joints separate.... did they not say which arms?.... upper arms can be an as the top bolt on the hub carrier can seize in. upper front arms you have to unbolt the carrier/top mount from the inner wing to get the bolt out. the lower curved arm you need to drop the subframe slightly to get the bolt out. let me know how you get on.... ....... if i had a penny for how many times ive changed suspension arms on these passats/a4's/a6's in the last 10 years...... i'd have about £102.06... I'm not joking!!
