CIH
Can anyone recommend which rattle can spray paint I should lok for ? I'm doing various underbody brackets, subframes etc.
I'll find penance pictures later as I'm at work right now!
Aerosol Spray Paintstealthstylz
@stealthstylz
Club Retro Rides Member 174
Any particular colour? I use enamel mixed to whatever colour I want from a local paint shop for £4 a tin. Nice hard finish so it doesn't fall off.
Matt
I use hammerite normally but its not that cheap
MrSpeedy
East Midlands
www.vintagediesels.co.uk
IMHO if you use ANY Acrylic (water based) rattlecan, don't expect it to last much more than 3 months. It's rubbish. There was a reason we used to use Cellulose based paint !
I would aim to use the more expensive solvent/enamel paints such as hammerite, u-pol etc
Also tbh, using a spray can under a car is a fail, I've tried it and because you have to keep the can upright it's really tricky to get to some bits and you tend to get gassed if you're under the car as well, much easier just to use a brush and slop it on nice and thick. like so...
Last Edit: Jun 8, 2011 15:12:40 GMT by yantorsen
Jun 10, 2011 12:12:24 GMT
Acrylic is solvent based?
Anyway, I have used a bunch and I find I like them all pretty much the same. Get a good primer on there and prep it properly is the key. No pun intended.
Jun 10, 2011 13:56:36 GMT
Do yourself a flavour and pick up a Plasti-Kote Aerosol Trigger or two when you're buying your paint.
As far as brands go, I'm finding Halfords aerosols to be really good at present, nice high pressure and no spitting. U-Pol Power Cans, on the other hand, have been U-Pol Dribble Cans in my experience. Utter poop...
Jun 10, 2011 17:06:03 GMT
I tried some Wilkinsons Blue paint on suspension parts, and wish I hadn't. the paint sprays ok, but its not solvent resistant. it comes off with panel wipe (used for prepping panels before painting) and white spirit.
Jun 10, 2011 17:27:38 GMT
I use stone chip type stuff. UPOL or hammerite depending whats cheaper
Jun 10, 2011 19:12:14 GMT
I've always found Hammerite/Smoothrite expensive and prone to chipping easily.
CIH
Jun 10, 2011 20:03:06 GMT
I tried Hammerite in the past and it was awful
Jun 10, 2011 23:22:41 GMT
Aerosols are not at all ideal for any under body or chassis parts, but if you have to, then order up some aerosol chassis black, you can get it on eBay and places. Failing that, hammerite smooth probably 2nd best, but a long way behind. Cheap aerosols are a waste of time, however much you put on.
1989 Mini MG 1275 ~ 1987 VW Polo ~ 1989 Citroen 2CV ~ 1998 VW T4 ~ 2006 Volvo XC70
I've always found Hammerite/Smoothrite expensive and prone to chipping easily. That's weird, I've always found it pretty solid and hard to chip, especially if you brush it on thickly.
Jun 11, 2011 18:47:49 GMT
I've always found Hammerite/Smoothrite expensive and prone to chipping easily. That's weird, I've always found it pretty solid and hard to chip, especially if you brush it on thickly. I thought we were talking about aerosols?
Jun 12, 2011 15:48:19 GMT
That's weird, I've always found it pretty solid and hard to chip, especially if you brush it on thickly. I thought we were talking about aerosols? Well yeah I guess we were, I kind of suggested aerosols are a waste of time though lol
Jun 12, 2011 16:32:54 GMT
Not if you take the parts off. If you have a stripped subframe & suspension you can do it with spray cans.
