Front coil over shock body modification??
Hi all, little technical question here. I'm wondering if its possible to modify the lower spring plate on a shock body to make it lower?
My shocks are the wrong ones for my car, two types where available I believe lower plate heights set at around 2.5 or 4.5 inches.
I know it’s not safe to weld shocks etc so is there another way to get around this? I know I could buy new shocks but at 190 the pair I cant afford it!
Heres a pic showing the shock
I had one idea of cutting the plate off and making a clamp to go around the shock body with a new plate if needed above that making it lower, as I have access to materials and my lathe.
Any other ideas?
Thanks
Chris
Any other ideas?
Thanks
Chris
