jr19
Apr 17, 2011 17:50:37 GMT
I have aquired a magnex cat back exhaust for my car but it has previously been modified to fit a different model. Its made of 2 1/2" stainless and the centre section dog-leg bend needs bending and the flange rotated to the right angle (about a 10/15 degree rotation). Anyone able to help me with it please?!
Last Edit: Apr 17, 2011 17:51:14 GMT by jr19
jr19
Apr 18, 2011 21:42:05 GMT
suggestions? would it bend if i put it in a vice and use scaffold stuck in the end?! Any help appreciated
Apr 18, 2011 21:52:43 GMT
I'd be very wary of trying to bend without the proper equipment. The pipe wall would more than likely collapse in on itself. Try taking it to a Longlife exhaust centre or similar and see if you can give someone a drink to bend it on their machine.
Apr 18, 2011 22:00:57 GMT
Looks a simple job for anyone with a welder and a chop saw, as above - find a friendly exhaust place and see if you can get it done under the table. It'll need cutting, then hanging on the car to line stuff up, then removing again to weld all round which is half an hour of anyones money.
jr19
Apr 22, 2011 17:32:44 GMT
sound advice, thanks!
