Hi all my long reach car jack has basically lost all of its lift and only works on the last part of the arms throw Can someone tell me if its possible to fix it? or is there someone out there who can? I cant really afford a new one and it seems a shame to throw this one away Any help much appreciated! Chris
bortaf
Depends on the make? my 50 year old bradbury high lift had a re-seal last year for the grand total of £7
R.I.P photobucket
dazcapri
North East
Enter your message here...
it.s probably a seal thats gone in the ram could just be low on hydraulic oil machine mart sell oil to suit in small quantities if you know what type it is you'll probably be able to get a rebuild kit for it
Mk3 Capri LS
Dez
Club RR Member Number: 34
fixing up a car jack?Dez
@dez
Club Retro Rides Member 34
o-rings are cheap, and thats usually all seals them. I local hydraulics supplier will be able to do you the oil and some good quality seals (if you take them the old ones to match) for the price of a pint. its usually quite a messy job doing a rebuild on a jack, but I'm one of those people who take immense satisfaction in fixing/refurbishing something rather than throwing it away, so i spend quite a bit of time rebuilding old tools
Last Edit: Apr 3, 2011 20:14:02 GMT by Dez
sorry for a slight thread jack but I'm also having a slight problem with my farm jack. 25ton proper massive trolley jack for lifting tractors. Got it out to change the wheel on the discovery yesterday and found that I had to literally hang of the jack arm to get it to lift. Yet it still lifts on the whole stroke and doesn't come back down other than with the release arm, its just mega stiff. Any ideas people I need it to jack up a traction engine next week and I'm not sure my 10stone will be enough to make it lift 20tons of steam engine
fixing up a car jack?retrowagen1234
@GUEST
Mine was just down on hydro fluid... Chucked some brake fluid in there and been fine since... Both my little portible one and the bigger 3 tonne one..
I thought you weren't supposed to put brake fluid in them because they have mineral hydraulic oil in them?
mk14dr
Yorkshire and The Humber
Club RR Member Number: 85
fixing up a car jack?mk14dr
@mk14dr
Club Retro Rides Member 85
Mine was just down on hydro fluid... Chucked some brake fluid in there and been fine since... Both my little portible one and the bigger 3 tonne one.. You are joking right? I was under the impression that, like datman implies, the chemicals in brakefluid will degenerate the rubber seals. You could end up with it failing and droping whatever your jacking....
Indeed - you can buy specific jack oil. I'd drain it out and flush it through a few times at least.
Unless it's LHM left over from his dad's Citroen DS...?
10mpg
Club RR Member Number: 204
fixing up a car jack?10mpg
@10mpg
Club Retro Rides Member 204
I've had two jacks for decades working absolutely fine on straight ATF, that's all i use to top them up...
I have one lurking somewhere that is using 10/40 motor oil, seems to work a treat except when it gets really cold! a mate filled it years ago by accident when he had knocked it over and the lid came off draining it out, i put it to one side thinking 'ah well the seals'll be fooked,' i needed to use one in a pinch (somehow the other 5 were being used!) and i dragged it out and used it, worked fine and still is and that must be 5 years ago!
megzy
a little brake fluid will make the seals swell as so tighting them up but this is a very short lived fix i did it on my pas system on the landy and it did 6 months before the pump gave up
@GUEST
Mine was just down on hydro fluid... Chucked some brake fluid in there and been fine since... Both my little portible one and the bigger 3 tonne one.. You are joking right? I was under the impression that, like datman implies, the chemicals in brakefluid will degenerate the rubber seals. You could end up with it failing and droping whatever your jacking.... Nope not joking... Its just brake fluid... Its not going to kill anything more than "jack fluid" Theres rubber seals all over a cars brakings system but they don't disolve with contact of brake fluid do they? Plus on the collapsing side of things... Thats why we use axle stands and chuck a spare wheel under the crossmember or sill. Ive been doing it on various jacks for years with no issues. And both my current ones have no leaks. They don't slowly drop like some new ones ive had either.
@GUEST
I thought you weren't supposed to put brake fluid in them because they have mineral hydraulic oil in them? Never heard of that... Hydraulic oil is hydraulic oil.... ;D If the seals go then they go that doenst bother me. Tbh I'm supprised the big one has lasted as long as it has. It was second hand from a vw mechanic when I got it. So its had a hard life... But still doenst leak. Not even weaping.. It also did a great job at holding the xr4 up for a whole weekend the other week. I know that as I forgot to drop it back onto axle stands... EDIT: BTW I'm not for one second saying its fine to put brake fluid in, I'm just saying I have with no issues... Both mine were emptied by accidentally tipping them (one in the back of my polo ) So it was a quick fix that has worked fine for me... Might be worth looking into a little more just incase it spontaniusly combusts with the precise weight of a austin a40 or somthing...
Last Edit: Apr 4, 2011 11:10:35 GMT by retrowagen1234
Hi all thanks for the replies! Ive worked on hydraulic systems at work before but I didnt really look at how a jack was built until I removed the cover........ simples aint it lol I have pulled it all apart and can see its basically leaked out over time at the handle plunger end so what we saying then, fill with brake fluid, might help the seals a lilttle? or I have some power steering fluid somewhere too. also fill to the brim? heres it in pieces lol thanks chris
Fas as I know seals are made of a different material to handle brake fluid. Why not use jack oil or hydraulic oil, for the sake of a beer voucher. Pretty sure the destructions for mine specifically say do not use brake fluid.
Mine's also due a seal overhaul. Trip to local bearing shop should sort it out for very little £s.
