Mar 21, 2011 15:04:21 GMT
Anyone got any spares I can borrow/buy/hire before I spend a small fortune on some that most likely aren't right? Ideally I'm looking for some 110 mains & 160 Air Correctors for a start, but anything close would be great.
Mar 23, 2011 21:10:18 GMT
Bump, anyone got any jets? Happy to swap for my 100 mains, 140 airs, or give back after 10 minutes testing??
by a set of micro drills for a fiver. solder the jets and redrill until your happy. then you can order the correct size jets from your experimintation . done that a few times.
once drilled use a larger drill bit to dress the edge of the hole inside and outside the jet. should make them more equal to each other and flow better.
