Soβ¦.. One of my favourite threads in here.\ What wheels would fit on this, 1999 E200 along with sensible, driveable lowering? I do like quirky, left field stuff but no idea what is out there that would fit as a decent replacement. ![](https://hosting.photobucket.com/images/mm90/niknakpix/38088432-2048-4F2F-B9BC-F87C1993DC02.jpeg?width=1920&height=1080&fit=bounds) Thanks. Wheelfitment.eu is a handy site for finding cars with the same fitting. Apparently 5x112 is common across lots of Audis, BMWs and Mercedes. Probably best to go for something close to the 37mm offset though, I'm not sure how far off 37mm you could get away with. www.wheelfitment.eu/car/Mercedes/E-Klasse%20W210%20(1995%20-%202002).html
What wheels would fit on this, 1999 E200 along with sensible, driveable lowering? So while the whole world puts merc rims on other makes You want to swim against the tide and put other makes rims on a merc (since that is what this thread is all about, so suggesting the thousands of merc wheels is not the target here ![:D](//storage2.proboards.com/forum/images/smiley/grin.png) ). You can chose from such a lot of makes that meanwhile use the 5x112 pattern and 15" upwards: every modern VW brand (Audi, Bentley/RR, Bugatti, Lamborghini, Seat, Skoda, VW), but surely a lot of others too. How about this VW Beetle rim looking like a hub cap steelie (removing the vw badge would be my suggestion)? ![](https://www.original-felgen.com/felgenbilder_fs/5c0/5c0601025max1-1.jpg)
misteralz
There are a lot of Skoda wheels that would look great on that nowadays.
75swb
Beta Tester
Club RR Member Number: 181
Were mk1 disco and defender 5x112? Slammed on black modulars would be a look!
Were mk1 disco and defender 5x112? Slammed on black modulars would be a look! What do they look like?
Would these work on that Benz? Really had the horn for these a long time.
Repost? ![](https://hosting.photobucket.com/images/mm90/niknakpix/001(91).jpg) Same thing, different colour
misteralz
Apr 10, 2022 11:03:11 GMT
P38 Mondials? Would require adaptors, they're 5x165 or something mad like that.
75swb
Beta Tester
Apr 10, 2022 20:09:44 GMT
OGDB
P38 Mondials? Would require adaptors, they're 5x165 or something mad like that. 5x120 I believe on the P38. Adapters require M14 studs and some unique flat bottom wheel nuts rather than the chamfer type we are used to seeing. I used to run a set many years ago. Popular choice among van owners I understand as the alloys in some cases are suitably load rates.
misteralz
No, it's L322s that are 5x120. Same as T5s, which is why you see loads of 'surf bus day van l@@k' T5s on L322 and X5 wheels.
mk14dr
Yorkshire and The Humber
Club RR Member Number: 85
Apr 17, 2022 11:51:59 GMT
antni
Apr 17, 2022 15:04:02 GMT
I'm picking up an old Mazda e2200 I've been after for years this week for work. i think it's 6x139.7 pcd and I've seen lots of funky 4x4 wheels in that size. Hopefully I'll find something unusual for that.
Apr 17, 2022 15:16:22 GMT
Is it the wide angle lens or have the back wheels got a bit of positive camber? From the wheel the rear end looks a bit \β/
zeberdee
Club RR Member Number: 2
Apr 17, 2022 15:44:23 GMT
Think itβs the camera angle .
Looked ok when i saw it last weekend , with its cheeky V6 under the bonnet .
π
mk14dr
Apr 17, 2022 17:04:02 GMT
Is it the wide angle lens or have the back wheels got a bit of positive camber? From the wheel the rear end looks a bit \β/ Just an optical illusion, it looked bob on in person. Have a picture from the business end
Apr 17, 2022 17:55:51 GMT
Is it the wide angle lens or have the back wheels got a bit of positive camber? From the wheel the rear end looks a bit \β/ Just an optical illusion, it looked bob on in person. Have a picture from the business end Which V6 is that?
zeberdee
Apr 17, 2022 18:39:47 GMT
It looked like a Cavalier/Vectra engine to me , but I could be wrong .
mk2cossie
Club RR Member Number: 77
Apr 17, 2022 18:58:08 GMT
It looked like a Cavalier/Vectra engine to me , but I could be wrong . Does look like a Vectra engine, the inlet manifold being a bit of a clue for me ![8-)](//storage.proboards.com/forum/images/smiley/cool.png)
Apr 17, 2022 20:01:48 GMT
Blimey! Probably the 2nd worst car I've driven, surely a Matiz V6 is a bad idea!?
...and yet, I still would!
