Hey guys,
Today I decided to remove the sound deading, while the carpet is up. Might as well do it right while I'm here.
drivers foot well
The reason why i was getting a wet carpet i suspect.
The rear
Not sure if the pic will show it well, but the floor has had a battering at some point, not to bad, but a few scattered dings.
WTF! the part where the rear bench is supposed to be weld to the floor!
The remains of the sound deading from both sides. At least 4kg's there. nice weight saving.
Then got out the grinder and cleaned up the smal bits and just went over the few crusty areas
I plan to weld this in place. below the new carpet as i think its an eye sore and it will allow me to have a mat down!
Plans tomorrow are to crack out the welder, weld up 3 small screw holes in the driver foot well, to stop me getting wet feet. Weld down the false floor. Give the inside a good hoover, and hopfully my paint will arrive so i can paint it. then some rot behind the wing and in the rear arch. so tomorrow should be a good welding day.
drivers foot well
The rear
