Okay had these JOM Corsa (A,B,C) coil-over's sat around in my shed for awhile. (try 2 years)
What I have for sale is:
2x front coil-over struts and bodies (unused)
2x front corsa top mounts
2x top nuts
4x adjuster rings.
No rear springs.
No front springs.
No helper springs.
These would be Ideal to modify to suit Nissan Micra K10 / K11.
I can supply information on how to fit these to a Micra if needed.
(basically one of the coil-over holes needs filing/dremeling out a few mm)
www.micra.org.uk/threads/my-facelift-k11.39641/page-2#post-457921
Some info on the above page, Perhaps Mr.Bognor could help out with his MSC skills and copy and paste the important info and pictures into this thread for me ;D
Then it is just a case of picking up a set of spring. either phone FK/Venom motorsport and get some replacment Corsa/Punto coil-over springs
or get a company such as GAZshocks, Red Rose Engineering or DFaulknersprings.com to make you up a set suited to your micra/lowering needs.
josepharren@hotmail.com
07-801293381
Located Taunton, Somerset
2x top nuts
4x adjuster rings.
No rear springs.
No front springs.
No helper springs.
07-801293381
