Fungus
Dec 12, 2010 17:39:16 GMT
1972 mini 850ChasR
@chasr
Club Retro Rides Member 170
Dec 12, 2010 17:48:54 GMT
That does look like it has seen better days! Either way, it is definitely something to learn on . Enjoy.
Dec 12, 2010 18:43:21 GMT
you've got your work cut out there! Great first cars, for learning in and learning on.
wanted, 25th hour. Required daily, cash waiting
Davenger
It's only metal
Club RR Member Number: 140
1972 mini 850Davenger
@dminifreak
Club Retro Rides Member 140
Dec 12, 2010 18:50:52 GMT
So, what does it need? Looking like a new front end, new rear valence and closing panels. Be prepared to replace the lower hinge panel and the trailing edge of the boot floor. What's the rear subframe like?
Dec 12, 2010 19:07:34 GMT
Great cars cheap and fairly easy to restore as parts are easily available Have fun with it
Dec 12, 2010 19:48:54 GMT
Congrats on the new baby.
Anyway, a couple of things for you to ponder:
'72 L reg means free tax - what does the logbook say?
And, that carb is a 1 1/2" SU - which if i'm right, at this age, is wrong (not in a bad way, it's better than the standard 1 1/4"). What are the first 3 digits of your engine number? It's on a metal plate just under the spark plugs at the side.
'83 GTM Coupe. 4A-GE Powered '00 GTM Libra Auto. Ick. '71 Detomaso Pantera. Current Resto '89 GMC Safari Tow/Kip bus '05 SAAB 9-3 Daily '71 Siva Moonbug. Not even contemplating resto yet.
Fungus
Dec 12, 2010 20:21:09 GMT
Thanks everone :')
I'll go and have a look now, i want to put a stage 1 kit on it when it's done, but i didnt know if the carb was the correct one for the needle it comes with :/
Also, if you were were going to keep it an 850, what would you guys do to the engine to to wake it up a bit?
Cheers
Fungus
Dec 12, 2010 20:29:52 GMT
From what i can make out with htis crappy torch the first 3 are 85H
Dec 12, 2010 20:40:49 GMT
i love a nice mini , it will be good when you have sorted it out
Davenger
It's only metal
@dminifreak
Dec 12, 2010 20:50:26 GMT
1 1/2" SU isn't that wrong for an 850. My 83 850cc van had an 1 1/2" SU on it. Could be a later engine, or just a later carb
Fungus
Dec 12, 2010 21:02:44 GMT
i reckon its a later carb - I'll see if i can find some info to tell me what the carb is.
I have the tax disc form from 1990 here, and it says that it's £100 per year to tax, but also that the car is from 1972. So is it possible to apply for tax exemption?
Cheers
Dec 13, 2010 11:24:21 GMT
AFAIK, just send off the logbook with a change of taxation class - it should be automatic, but if it's not, post here for help in argueing it. L reg is a bit of a funny, as it's changeover year from exempt to not. I think 1990 was before tax exempt came in - though I may be wrong.
Yes, it's probly a later carb, but from recent experience, you will struggle getting a new needle and jet for a std 850 nowadays.
And for now, don't bother tuning it. My last 850 (RFM251V) many moons ago was rolling roaded at 19bhp at the wheels - but it was brillliant fun getting it sideways on every roundabout at 15mph.
Easiest, simplest, cheapest mod when you want more power is to bung in a 998.
Fungus
Dec 13, 2010 19:18:13 GMT
The problem is, I'm prety sure putting it as an 998 would make insurance more expensive, although so would listing all the mods. So maybe i dojust give it a good service and be done with it :L I lifted up the carpets today, big mistake So much rust it's untrue, theres almost no floor i will hopefuly get some pictures tommorow, but its getting dark as soon as i get back from school
Dec 13, 2010 19:32:28 GMT
great find mate! Ah thats takes me back!
Ive seen em in worse nick, good luck with the resto!
Dec 13, 2010 23:06:11 GMT
Hi,
For you to drive this car, you will need to have it with 850 engine. You can fit cooper free flow stage 1 kit(not small bore LCB type). Try to get hold of K+N filter in a std airbox as it will run quieter.
To find out if your car is tax exempt or not, you will need to find out manuafcturing date. You can do this by contacting British Motor Inductry Heritage Trust. They will look into your cars history from your chassis number, reg and engine number. I think it will cost over £75 but if your car is proved to be made before 1973(was it 1st March?). I think money well spent!
Resto wise, do a good job with either pattern panel or BMH panels. I think you need to buy David Vizard's books. There are few editions of How to tune BMC A-series and how to modify Mini. You can mod 850 to almost std 1275 level for cheap! MG Metro camshafts are good. 1275 pressed steel cam gears are good for power.
I think 1st things you want is to get hold of unleaded 998 head to make your car to run on unleaded without additives!
Cheers Atchi
Building roof chopped, screen raked '68 Mini with G13B 1.3 16v Gti engine with LSD, Yamaha R1 carbs. As well as mk1 Suzuki Swift Gti AWD with a turbo. Drives PHEV Outlander but wishing my mk1 Swift Gti or mk2 CRX Vt were still with me!
Davenger
It's only metal
@dminifreak
Dec 13, 2010 23:21:49 GMT
My memory is getting terrible. What was the number of the 998 cooper head. AEG295 maybe? One of those would be awesome on an 850
spacekadett
F*cking take that Hans Brrix!!
Dec 13, 2010 23:21:50 GMT
My '68 Mk1 was still reg'd PLG rather than historic as it had been off the road so long. When I got it running I was in far too much hurry to drive it to faff about going to the DVLA office ;D so I just bought 6 months tax. A few weeks later a new logbook and tax disc arrived (a 13 month one at that - that took a little sorting ) along with a form to return my current one for a full refund
Mechanic's rule #1... If the car works, anything left on the floor after you finished wasn't needed in the first place
Davenger
It's only metal
@dminifreak
Dec 13, 2010 23:23:42 GMT
12G295. Wasn't far off ;D
Dec 13, 2010 23:31:44 GMT
AVX - Nice local number plate there, Yours like a lot of work to get back on the road tagain but don't let me put you off, I wanted nothing more then a project car like that when i was 15 but my parents wouldn't let me. I'll have to keep my eyes open for it when I'm about in Colchester!
Davenger
It's only metal
@dminifreak
Dec 13, 2010 23:39:45 GMT
AVX - Nice local number plate there, Yours like a lot of work to get back on the road tagain but don't let me put you off, I wanted nothing more then a project car like that when I was 15 but my parents wouldn't let me. I'll have to keep my eyes open for it when I'm about in Colchester! I had a MK1 escort when I was 15, a 2 door 1300E If only I'd known scene tax was on it's way ;D Which little village are you in 850mini? Think I've still got some bits from my 850 van, I'll have a look when I visit my mum in Thorrington
