Feb 21, 2011 11:39:31 GMT
Stunning work as usual. With the speed you are getting through the jobs and the planned finish date the rest must be really bad (just as bad as the bit you have done!) Looking really good so far and I guess when you have one side done you can sit bback and admire the look before turning it around! Keep it up, cannot wait for the next update as with all your threads John.
Last Edit: Feb 21, 2011 11:39:53 GMT by tickman
Feb 21, 2011 23:04:16 GMT
Hi,
I have my Mini door bottom to deal with. From what I can see, did you just weld bit by bit(not seam weld)? Then fill in the gap or just weld every 20mm? I have been seam welded everything and each time I do this, panel distort. So, if I do what you are doing, weld every 30mm or so and go back and do the same. Will it not distort panel but seam welded?
It looks good and I wish I had half of your skill. I have now bought a plasma cutter(arc/Tig) which was cheap but money well spent!
I hope what I luck in my skill, I can use tool to cover it!
Cheers Atchi
Building roof chopped, screen raked '68 Mini with G13B 1.3 16v Gti engine with LSD, Yamaha R1 carbs. As well as mk1 Suzuki Swift Gti AWD with a turbo. Drives PHEV Outlander but wishing my mk1 Swift Gti or mk2 CRX Vt were still with me!
Feb 22, 2011 15:43:49 GMT
Hi! Great work Dave.....like always when it comes to "Blech" ......i stuck on the Express....it's a little bit more work than I think at first... Cheers Totti Hi Thorsten, the difference being you can get spares for your Express Stop faffing around with your future daily and get the MK1 Cortina started ;D Stunning work as usual. With the speed you are getting through the jobs and the planned finish date the rest must be really bad (just as bad as the bit you have done!) Looking really good so far and I guess when you have one side done you can sit bback and admire the look before turning it around! Keep it up, cannot wait for the next update as with all your threads John. Much appreciated John, i think my plan is still about right, the other side is just at as bad unfortunately so i think two years for the bodywork is about right, especially as we´ll be dragging out the Capri out of the barn soon and that needs sorting too Hi, I have my Mini door bottom to deal with. From what I can see, did you just weld bit by bit(not seam weld)? Then fill in the gap or just weld every 20mm? I have been seam welded everything and each time I do this, panel distort. So, if I do what you are doing, weld every 30mm or so and go back and do the same. Will it not distort panel but seam welded? It looks good and I wish I had half of your skill. I have now bought a plasma cutter(arc/Tig) which was cheap but money well spent! I hope what I luck in my skill, I can use tool to cover it! Cheers Atchi The doorskin is not seam welded as you´ll always have issues with the heat needed to penetrate properly. I just spot welded it every 6 inches, let it cool down and then keep closing the gaps until you get a continual line of spot welds. To give you an idea i spent most of a whole day doing that one weld, just leave yourself plenty of time inbetween each spotweld and you´ll be ok. Hope that helps, Dave
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Feb 22, 2011 16:05:51 GMT
Outstanding workmanship there. That's a pretty big project, but it's gonna be a stunner when you've finished it
Feb 23, 2011 18:25:14 GMT
Outstanding workmanship there. That's a pretty big project, but it's gonna be a stunner when you've finished it Cheers mate, hope so Before I refit the door I wanted to finish off the drivers side floor. I´d just tacked it into place to make sure that the inner sill was right So I go the welder warmed up and welded the rear half in for good The original drivers seat mounting rails were not rusty but a previous owner had bodged them up pretty badly so instead of fixing them I chopped out my spare out of the donor. Fortunately it´s identical.. and it goes in here next job is the other half Anyone notice what´s missing in the last picture...answers on a postcard to.......... ;D
Last Edit: Feb 23, 2011 18:28:20 GMT by Oldbus
Siert
Feb 23, 2011 19:23:25 GMT
uhm, I don't have any postcards lying around but my guess would be... rust?
Seth
Feb 23, 2011 20:23:53 GMT
Anyone notice what´s missing in the last picture...answers on a postcard to.......... ;D chassislegs.com? Great looking progress Dave.
luckygti
I need to try harder!
Feb 23, 2011 20:24:17 GMT
uhm, I don't have any postcards lying around but my guess would be... rust? That would be my guess too Dave. Quality ;D
mrj
Feb 23, 2011 22:00:31 GMT
the reinforcement bar that Dave fitted before cutting the car in three pieces gets my vote
- 1971 VW 1600 TL Fastback - 1978 Passat GLS Variant - 1980 Audi 100 5E - 1981 VW aircooled panel van (sold) - 1983 VW Jetta Mk.I - 1984 VW Polo Coupé - 1984 VW Passat hatchback - 1987 VW Passat Variant - 1987 VW Passat hatchback - 1988 VW T25
Feb 24, 2011 19:53:28 GMT
It's great to see some good quality workmanship and a big project being tackled to competently. Keep up the good work sir
mino
Great progress, have a picture:
uhm, I don't have any postcards lying around but my guess would be... rust? Wasn´t thinking of rust mate but you´re right ;D Anyone notice what´s missing in the last picture...answers on a postcard to.......... ;D chassislegs.com? Great looking progress Dave. Thanks Seth, you´re right mate - once i´ve got the floor done on the drivers side i need to fit the middle section of the lefthand chassis leg uhm, I don't have any postcards lying around but my guess would be... rust? That would be my guess too Dave. Quality ;D but only if you don´t look at the rest Pete the reinforcement bar that Dave fitted before cutting the car in three pieces gets my vote and another winner, beer is on me at Lobbach in summer ;D It's great to see some good quality workmanship and a big project being tackled to competently. Keep up the good work sir Thank you, much appreciated Great progress, have a picture: Danke Mino, JP 922 was one of the early press cars that got the balls screwed off it ;D - wonder if it survived? I have the day off so with a bit of luck i´ll get the drivers side floor finished today
bstardchild
Club RR Member Number: 71
1967 Osi 20M TS - please lockbstardchild
@bstardchild
Club Retro Rides Member 71
Feb 25, 2011 23:03:31 GMT
Excellent progress - look forward to seeing this at a gathering next year
Feb 25, 2011 23:26:08 GMT
You're chomping through this at a helluva rate! Nice work as always Dave, this is going to be an incredible car.
Excellent progress - look forward to seeing this at a gathering next year Wishful thinking mate, 2013 maybe? ;D You're chomping through this at a helluva rate! Nice work as always Dave, this is going to be an incredible car. Cheers Dean, i´m not too sure about the "incredable" bit mate but at least it won´t be rusty ;D Yesterday involved a bit of this... a bit of welding..... and after hours of grinding, a bit of this to boost the mojo ;D with a bit of luck i´ll get the front jacking point in today and the rest of the chassis leg welded up.
Last Edit: Feb 26, 2011 11:08:54 GMT by Oldbus
OB-wan. With this thread you have been propelled to the top end of the 'welding jedi' league table that exists only in my head. You are jostling with TonyBMW and those vietnamese guys who do VW campers, for top spot!!! Amazing stuff and very inspiring. I'm gonna buy a set of those cleco things, they look like THE TOOL for doorskin repairs etc.
OB-wan. With this thread you have been propelled to the top end of the 'welding jedi' league table that exists only in my head. You are jostling with TonyBMW and those vietnamese guys who do VW campers, for top spot!!! Amazing stuff and very inspiring. I'm gonna buy a set of those cleco things, they look like THE TOOL for doorskin repairs etc. .. I was always partial to your special brand of humour ;D ;D Those Cleco clamps are brillaint Richard and well worth the money mate, especially as you are partial to bit of "car rescueing" yourself . The last job on the drivers side floor was to weld in the front jacking point.... the old one was completely nackered as with most of this car.. i´d been able to source a pair of new ones that are made for the Taunus 17M and as the floorpan is the same they fit quite well... i´ll give it a couple more coats of primer over the next couple of weeks and then seal all the welds with Sikaflex. The floor is now finished...... Next job up is the rear left hand corner. If you think the front was bad wait until you see what´s left of the boot
Last Edit: Feb 27, 2011 9:32:31 GMT by Oldbus
drpete
Feb 27, 2011 10:11:55 GMT
it all your fault when started to read this threa my coffee was hot, it cold now lol amasing work there, from one tin basher to another, by any chance could you bottle up your mojo and sent it this way, i need it,
Feb 27, 2011 10:13:46 GMT
Great Milestone Reached Old Bus, looking forward to seeing the boot
Feb 27, 2011 10:57:42 GMT
I would love to jack up this car on that new jacking point! It'll be great.
