ross_m
Hi, hoping someone will have some instructions for the old piranha alarm/immobilizers. They don't make them any more and the websites about them that are left don't have any instructions I have this fob And the unit looks like one of these in black If you need any more info I'll get it. Thought this was the best place to ask. cheers
Last Edit: Nov 7, 2010 16:12:29 GMT by ross_m
model number?
1993 Fiat Panda Selecta 2003 Vauxhall Combo 1.7DI van 2006 Mercedes Kompressor Evolution-S AMG SportCoupé
"You think you hate it now, wait til you drive it"
ross_m
The only bit on the sticker that was readable was 546753/A
Any use?
ross_m
Yeah Ive seen those but theres nothing useful. It looks like in the last on thier used to be links for downloading manuals but they don't work any more. Cheers anyway!
Kyle67
I used to fit these for a living but it was 20 odd years ago when I worked for these guys... Bulldog Motor Spares 129 Horseley Heath, Tipton, DY4 7EH 0121-557 6817 See if Pasty still works there, he can fit them in his sleep....
ross_m
Brilliant! I'll try him
cheers for that
frag
Fairly sure,black button obviously is arm & disarm...... Red button is "panic". Pressing black button again straight after arming (beeps again) will disarm ultrasonics. Got same alarm on me transit but no instructions
'69 Holdsworth bay '88 T25 Panel van ‘72 beetle ‘78 vw champagne T2
Paul
Mar 13, 2011 12:52:05 GMT
Bit of a thread resurrection but here goes...
Found one of these under the hood of my 'new' car - the design looks the same. The top plug (as per picture) isn't plugged in but the lower one is. Unplugging it immediately kills the car.
The alarm doesn't do anything other than make an annoying whining noise and presumably draw power. I have no keyfob. I just want to bin it - does anyone have a wiring diagram or similar so I can trace back what wires do what and what needs reconnected/disconnected?
Sept 29, 2014 12:47:51 GMT
Another thread resurrrection! I have one of these - an alarm and no fob, and wondering if it's possible to get a new fob programmed without having a) another fob or b) any type of code/manual/etc? I do have the little key for the alarm box though! Would be nice to get it working. (and it does go off if I turn the key on).
I always remember on the old Clifford alarms from 2000 era, they had the code on the circuit board inside two secure metal boxes.
Last Edit: Sept 29, 2014 12:57:13 GMT by DavidB
Hi , I have a Piranah alarm on my motorhome, I spent ages looking for instructions and eventually found the instructions in Italian, I translated them with Google and although it's not 100% you can understand them, I found my model no and adjusted the sensitivity, it now works perfectly with 2 remotes, if anyone wants a copy I will send it to them.
Can you send me them?
Last Edit: Nov 25, 2017 14:38:58 GMT by DavidB
Hi. Just came across this. I used to work for Piranha. What info do you need on them?
hi got a piranha car alarm the 1 you got on the pictures were can i get the manual from
Hi can you send me a copy please
Hi can you send me a copy to my email on maz78600@Hotmail.com please
May 30, 2017 20:28:26 GMT
Good night guys,
I just recently bought na old 1991 Renault Clio RT, which is equiped with one of these Piranha alarms. I've been searching all the web for some info about programming the remotes.
The thing is: When i turn on the alarm with the switch key, the four blinkers light up, the sirene makes a continuous sound for about 2 seconds, the doors lock themselves (if oppened) and the red led light above the steering weel lights up.
However, i cannot disable the alarm using the remotes, despite they seem to be working just fine (changed the batteries and the red led on them blinks when I press one of the buttons).
I believe this is due to unprogrammed remmotes. Can you help me by sending a user manual for the alarm so that I can set up the remotes ?
hi guys! I recovered this acoustic system from an older car and I would like to use it... can anyone help me with technical info please? I would be interested in the connections to the battery and the rest of the wires! Thanks' !!!
