Hello. My name is Cesar Barbosa. I'm from Porto Portugal and I'm here presenting my retro ride... It's a 1973 Volvo 164 3.0l straight 6 B30A M400... At the moment it's all dismantle for a major restoration... Now some fotos of it taken from the add on the internet... www.volvoforums.org.uk/album.php?albumid=580The future holds for it a turbo conversion with the stock engine ...I'm going to need some help from you guys... ;D
Jan 31, 2011 21:42:27 GMT
Hi... ;D It's now time for some long awaited pics of my volvo 164... The original registry paper... From the add on the internet... Now already at home... and the start of finding out why it wouldn't start It still had the original spark plugs.. The worst part of the paint... The back seat... The engine number... The body number... The identification plate... That's all for now...
Needs a bit of tidying up, but that should be a really cool car!
Needs a bit of tidying up, but that should be a really cool car! Thanks... I've already started on that... I think I've removed 80kgs of trash, dirt , sand, underseal, etc... The engine and gearbox was taken out by hand by lifting the front of the car.. easy peasy... so i could clean, derust and paint the engine bay. It has some rust holes in the usual places... But it's going... slowly but going...
speedy88
"Nice Cortina mate"
Club RR Member Number: 118
Nice car! That should be really cool when it's finished.
I'm going out on a limb here, but i think your rear seat has seen ALOT of action. Your on for something very awesome cesar
If weldings like tattoo'ing Then my car has some really sh*t ones
Nice car! That should be really cool when it's finished. Thanks I'm almost on the same boat like johnrh's in his 1973 Volvo 164 RS... So it will take some time to be finished but not to johnrh standards, it's too much off budget but will still look good...
I'm going out on a limb here, but I think your rear seat has seen ALOT of action. Your on for something very awesome cesar Thanks..It's already showing it's worth...Last weekend I took it out for it's first drive in my hands, without doors, wings, front panel, gas tank, rear brakes, bonnet, boot, seats, exhaust, windscreen, with only steering wheel, pedals and a gas drum as a driver seat...and that straight 6 sounded healthy even running on e95 unleaded and a straight exhaust pipe... just awesome, almost like a supra... ;D
Now it looks great.... Almost all done...
Some rust holes in here... Another one... The passenger side only surface rust, no need patching up... More to come...
I need some help cause i'm turbo charging it can anyone help??? I've seen this ( forum.savarturbo.se/viewtopic.php?t=27260&postdays=0&postorder=asc&highlight=volvo+164&start=0) ... And I'd like to do just the same... I'm on a little bugdet... just need to know what type of needles should i get for it (0.4 bar Max) the other stuff I've already have... Garrett t04e35, Blow off valve, Wastegate, Boost controller, Pipping and intercooler, Oil filter relocation kit with radiator and 2 monitor exits, a volvo 850 electric fuel pump,... and other bitts... Cheers
I need some help cause i'm turbo charging it can anyone help??? I've seen this ( forum.savarturbo.se/viewtopic.php?t=27260&postdays=0&postorder=asc&highlight=volvo+164&start=0) ... And I'd like to do just the same... I'm on a little bugdet... just need to know what type of needles should I get for it (0.4 bar Max) the other stuff I've already have... Garrett t04e35, Blow off valve, Wastegate, Boost controller, Pipping and intercooler, Oil filter relocation kit with radiator and 2 monitor exits, a volvo 850 electric fuel pump,... and other bitts... Cheers
Carburette B21 Turbo B21 N/A B23 Turbo Needed Cost Standard Needle B1FJ B19420 B1FU YES £12.33 Piston Spring B18339 B18339 B18339 NO Damper B27190 B20465 B27190 YES £10.19 Jet B21582/100 B21582/100 B21582/100 NO Needle Valve B28999/2.5 B21344 B28999/2.5 YES £19.67 Float B19470 B19470 B19470 NO Throttle Spindle B26808 B26808 B26808 NO Throttle Disc B25562 B27103 B25562 YES £18.54 Float B19420 B19420 B19420 NO misc part ? B24818 not fitted B24818 YES £37.18 gasket pack £8.34
Just found this list... for the carbs ... still collecting info for this project... Help still needed...
johnrh
Looking good so far!
Familiar rust in familiar places!!
There are quite a few turbo 164s on Swedish forums. So, if you don't know Swedish, funding a helpful translator would get you a lot of info. There are Swedes on this forum, and turbobricks.com, so wanted ads might possibly get you a volunteer!
I've been slightly distracted by a 240 GLT, but will be back on my 164 very soon.
Cheers
John
Feb 13, 2011 14:48:20 GMT
It is at least looking solid around the bonnet hinge mounts. That's quite unusual for a 100 series volvo.
194? Willys Jeep MB 1965 Volvo 544 Special 1968 Opel Rekord 1975 Opel Kadett Estate 1985 Mercedes-Benz 230E 1985 Datsun 720 King Cab 4x4 diesel 1997 Volvo S70 2.5SE (ex. "Volvo544special65" - changed to more reader friendly username. )
Feb 14, 2011 21:21:12 GMT
It is at least looking solid around the bonnet hinge mounts. That's quite unusual for a 100 series volvo. Just surface rust as you can see in the photo below... The boot is the worst part ...It seemed that it have an first degree meeting with a strong vehicle... it has some bent chassi rails just near the bumper both sides... and of course the usual spare wheel wells...
Feb 17, 2011 23:06:38 GMT
Feb 17, 2011 23:10:03 GMT
G A R'goyle
Bad to the bones Senior citzien
Feb 17, 2011 23:43:45 GMT
I just have to say this! ;D Volvo has made farm engines under the name Volvo-B M (Bolinder Munktell) One used as a rhythm machine! Some links maybe they are of some use.... Klokkerholm karosseri delar Kg Trimmning
Hey Cesar, that's a brave project! With regards the turbocharged engine, would it not be easier and cheaper to get a turbocharged red block from a 200 or 700 series? I don't know how common they are over in Portugal though.
