early 70s ace pioneer 12ft 4 berth
double bed one end and a single with solid flip up bunk
will need a fair bit of work due to damp or good base for a car trailer
its missing the cushions curtains, rear lights and skylight so you will need a lightboard to tow it
1 new tyre the other is an old one but pumped up ok
the tow hitch and brake lever,legs all now work ok so should be ok to tow
all windows and cupboards ok
has a sink and cooker,i might take the cooker if its going to be broken up for a trailer
I was intending to restore it as its quite good condition outside
but found a lot of damp timber when I stripped out the front cupboards,the damp goes along and into the roof as well
I guess it def saveable but something else came up similar age needing far less work
it wont need a huge amount of money,just time , some timber and some new white hardboard
its also damp at the back on the bunk area although it looks fine,the panels move if pushed so will need work
or break it and weigh in the ali and make a trailer,the chassis is all good and the tow hitch works fine
needs to go by next weekend,i will be adding it to freecycle in a couple of days time but wanted to offer it up on here 1st
