It will defintly get finished, one way or another it will. Cheers for the boost.
October 2011
This month has been not bad. I have been busy with other things other than the van but i have managed to get a bit more done on the van. I waited 17 days for the gutters to be made, i was told 4 days but that never happened. Which is why i hate having to out-source work. If its not in my control i get annoyed, but anyway, i did get them back and to be honest, they look great.
The one i made is the one in front and the engineering shop one is at the back. You can see that having the proper machinery beats the hand folded one.
Before i started with the guttering I thought I should finish the patching of the drivers side waist-line. No point working on two areas at once.
I kept working my way along in 280mm sections. As the van tapers to the rear the curve becomes more defined. That calls for some serious shrinking and stretching. I have practiced it manually like I've said in the thread already but it is tricky. So, i bought myself another new toy with the money from the Consul.
Its a Metz shrinker/stretcher. I got it from EBay, there is a guy who sells them new through his site for £250 but also puts them on eBay at £10 starting bids. I bid and won it for £117 plus P+P. I think he puts them on his site at that price so that when you do see them on eBay you think your getting a huge bargain and more likely to bid. I wasn't too sure about how good it would be but I'm very impressed. I never used one before but i find it quite easy to get the hang of, you just put the metal in and pull the lever down and it does the work for you. When stretching, the teeth on the jaws grip the metal and pull it apart, thus creating a curve on the angled lip. When shrinking it grips the metal and 'nips' it together. The only hard part now is to work out where on the metal you need to stretch/shrink. I forgot to take a pic of my practice piece.
It did get some use at the end of this repair section.
This was the tricky one that really tested the shrinker/stretcher for me.
The rear corner, I done the usual and marked out a 15mm strip to cut out. Again, i forgot to take pics (aaaarrgh) I cut the repair patch out, folded the lip over then joggled the edge. I made a template out on paper by tracing around the top edge of the area on the van i cut out then used the shrinker/stretcher to get the panel to that shape. It wasn't too difficult, i did over shrink a bit but i just swapped the jaws over and re-stretched the area.
You can see the repair section matches up quite well, i was happy with it anyway. I tig'd it all the way round.
Little bit of a clean up and thats the waist-line on this side finished. I don't think i will need to do the same to the passengers side. It seems that when it was laid up in the field, the van leaned more on the drivers side and the rain collected on that side as the passenger side wont need completely replacing.
With that done i decided to make a start on the guttering, at last!
I started on the front. There is a guy (forum name sidspop) who has restored a pick up cab version of the Thames and he had to replace the guttering also, I liked how he managed to get the guttering to curve so I decided to try the same. First thing i needed to do was make a template of the curve of the front. I had some off-cuts of Perspex so i was able to hold that in the windscreen aperture and using a marker pen, scribe the curve. I then cut it out to leave me with a nice fitting template.
Then i traced that onto a bit of strong wood used for flooring.
I put a slit into the strip of guttering every 50mm, just enough to be able to bend it. Then i put a screw into each section to hold it in place on the wood so it wouldn't distort when welding back up. I used the Tig again so it would be a nice clean weld and not so much to grind away. When welding i was starting to get a bit of contamination when welding the flats. I'm assuming it was the fumes and smoke from the wood burning away. I decided just to do the vertical parts whilst screw down and Il come up with another way of doing the rest of the flat parts. I wanted to put the gutter in place on the van so i brought out yet another new toy i got.
Clecos! , There used more in the aero industry to hold down sheet metal on the fuselage/wings etc.. but there really handy for the auto restorer too. There basically re-usable rivets. You drill a 3.5mm hole through both pieces you want to join, use the pliers to push the prongs down, put it through and release. They grip with 18lbs of pressure and hold the panel your working on in place.
Looks not too bad, the gutter does need more work done to it before i attach it to the body but this gave me an idea of how it would look.
I'm going back to the garage tomorrow plus i have Thursday and Friday of this week which should make for a more filling update next time. Although i am moving house this week so we'll see how much i can (or allowed
) Get to the garage.
More feet!
This part isn't to do with the van but i thought id mention it here all the same. My dad got his VW engined trike started for the first time just recently and i put a video of it up on YouTube. You can see it here,
. The engine hadn't ran in over 20 years!
If anyone is wondering where i get the ambition to do something like this then I'd have to say its my dad. His latest project is a VW trike. Its a project thats been going on for a few years now, almost ten years to be precise. It has been built under completely different circumstances to me. Its only recently really that he moved from working on it outside to inside a shed he built.
My dad said he had ideas for a VW trike from years ago, back in the 80's i think but he never had the money or time to do it. It wasn't until my brother, Ross, started a job for a motorbike dealership as a mechanic and managed to snaffle a few bits for my dad to make a start on. I say a few bits, what he got was 3 Harley frames, a fat boy petrol tank, a twin seat, Front forks, and other misc. parts so that got the ball rolling.
It was a while ago so i don't remember how my dad ended up with the rear half of a beetle chassis and engine. His vision of a VW trike is a low slung affair with long forks and a good rake. My dad is very old-skool, everything you see has been cut by hand, i don't mean using a grinder but literally a hacksaw and lots of filling.
This is the earliest photo i have on my trike of the build. At this point he had welded the frame to the beetle engine/gearbox mount and he even made the wheelie bar at this point.
The last pic you can see a nice bit of engineering detail. The hand brake for example, You see infront of the hand brake lever there are two pulleys, well, you pull the hand brake lever, a cable runs underneath those two pulleys where there is a lever which pulls the pulleys forward which puts the hand brake on. The panel just behind those pulleys is form a washing machine which just so happened to look good on the trike. Those foot pedal levers are another hand cut and bent item.
The next photos were from about 2-3 years ago, He had the engine painted and detailed by this point.
My old bike project in the background
Bonus picture of my crotch!
These pics were taking last year i think. My dad put the tank and seat on to see how it would look.
These pics were taking a few weeks ago when he got the engine running.
Its not far from being on the road now. I cant wait to see it driving down the road and maybe getting a few shots aswell. I love this trike, to me its all in the detail, its like engineering art. My dad has an image in his head of how it will look and thats exactly how it will look. There has been a lot of parts that have been a complete ball-ache for my dad that no one, not one person will ever see or appreciate the full extent of effort thats been put into this. The indicators for example, The original Harley switches were designed to be on-off , that is, you have to keep your finger on the switch to keep the indicator on. Not very good when you have to use your hand to change gear at the same time. So instead of scrapping the Harley switches, my dad got switches designed for table lamps and made his own copper switch mounts inside the casing so it would work as he needed it to. Even the main ignition switch has been totally stripped inside and had new internals made by my dad. This trike is a real one off, its art.
The trike isn't the first thing my dad has done. I have some pictures of him and my mum back in the day, i think late 60's early 70's.
This was his first project car i believe, a proper rear oval window beetle, way back when they were just seen as a cheap old car. Thats my mum standing beside it. The idea for the beetle was a street buggy and my mum chose the colour.
Check out the flares! Great photo of my dad.
The engine guard was made from old gas pipe i believe.
After that, The next big thing was a custom morris minor. Started in the late 70's, to me this is the car that epitomes my dad. I have such a strong link with this car and my childhood that i wish i knew where it was today.
This is what he started with, he bought it off his brother for £5 i think.
As usual, a lot of the work was done outside at the back of his old home in cramond. The wheels have been reversed and banded. I can remember what the rear axle was from, the front was a Wolsley i think.
kev.studiomike.net/morris4.jpg [/img]
The engine is a V4 from a Ford Corsair, i remember it sounded beautiful, really loud.
After a while he managed to move it into his work.
The rear bumper was from a Renault 5 and the huge spoiler was a truck roof spoiler. The wheel arches were from a ford Mexico.
It was painted Miami blue and silver.
This was it finished and my dad took some shots of it next to a standard morris to compare.
It even won a few car shows.
At the same time he managed to build a trailer to go with it.
And a buggy to keep my brothers entertained.
Unfortunately a few years after it was complete, someone braked hard infront of my dad during a bit of road rage and the car was heavily damaged. I think my dad was going through a bad time and couldn't afford the garage rent so it had to go. It was sold to a guy near gilmerton i think and i only ever saw it once again driving past me. I would do anything to know where it is now.
After a while my dad decided to build a motorbike for me. I remember being young, about 8 or 9 and feeling so excited seeing this motorbike being built.
The engine was from a Yamaha passel, the forks were from an old monkey bike and the rest my dad made himself.
My dad has some amazing creations.
I had so much fun with this bike. It taught me a lot for my future of riding bikes on the road and it was the best way to spend a Saturday. When i think back to my childhood i always think of going out on the bike as being the happiest time of my life. No job worries, no money trouble or stress, just get on the bike and have fun.
Theres tons of other stuff hes made but these are some of his best. He self-taught himself everything and i respect that so much. I have followed his lead and taught myself a lot too. seeing the amazing stuff my dad can do gives me the confidence that i can do the same. If somethings broke, Il try to fix it. If something needs made, Il make it. When i was younger i guess i was always trying to emulate my dad. Its what got me into working with metal, fixing cars and having a keen interest in anything mechanical or engineering.
My dad is pretty much the reason i can do what i can. I like my dads attitude of "I could make that" rather than "i could buy that". I try to follow that also, i don't want to pay someone to do something that I'm pretty sure i can do.
