Foxy
Making pink manly in the north!
Sept 26, 2010 14:58:02 GMT
Sorry for the dull and maddeningly laborious post BUT what cars have 15" 4 x 100pcd steels? Ive been told that Corrados do and Rover 620's do but I'm just tired of conjecture and hear say, so I thought I'd invest my faith in the wisened and jovial masses of RR for some clarity. Pics for your trouble Pretty pleases and thank you's all round! Foxy
I'm the handsome fella with the cheesy white specs or is that the cheesy fella with the handsome white specs?
Sept 26, 2010 15:13:11 GMT
the 90s vw had em ...known as g60 steels mostly , came on some passats /golfs /rados
still avail new for around £30
Sept 26, 2010 15:20:58 GMT
g60 steels are closer to £40 each new if they are any left.
look for renault steels they are sum either 15x6 or 6.5
Last Edit: Sept 26, 2010 15:22:48 GMT by damageandy
Sept 26, 2010 15:26:33 GMT
My boss's rover 400 has a full size 15" steel spare, not sure how wide it is but it wears a 185/55 tyre... I imagine they might also be standard on some models but I"m not sure.
Seth
Sept 26, 2010 16:09:39 GMT
MINI?
Rover 600s are 4 x 4.5" (114.3mm) I think.
bmw156
Sept 26, 2010 16:16:43 GMT
astra sport?
Dez
Club RR Member Number: 34
15" 4 x 100 steels?Dez
@dez
Club Retro Rides Member 34
Sept 26, 2010 16:17:32 GMT
i agree with seff, new mini is obvious choice as there loads of sets of em on egay really cheap.
g40jon
Sept 26, 2010 16:32:58 GMT
MINI? Rover 600s are 4 x 4.5" (114.3mm) I think. correct as they are based around the honda accord
Foxy
Sept 27, 2010 10:35:10 GMT
Cheers my greasy marras! Much appreciated! ;D
Gem
East Midlands
Sept 27, 2010 10:59:58 GMT
Most VW's are 4x100..
Foxy
Sept 27, 2010 11:07:20 GMT
Yeah but most I've found are 13 and 14"
kevfromwales
the conrod's REALLY out the block now!
Sept 27, 2010 11:19:41 GMT
we used renault 15" steels on raoulduke's starlet, maybe worth trying your friendly local breakers??
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
Sept 27, 2010 11:34:41 GMT
GM ones are some savage offset IIRC. VW ones tend to be more swap friendly.
Sept 27, 2010 14:55:37 GMT
Mx5s are 4x100 but I doubt you'll find steels.
Aren't E30 BMWs 4x100? might have some luck there.
Sept 27, 2010 14:57:42 GMT
Mx5s are 4x100 but I doubt you'll find steels. Aren't E30 BMWs 4x100? might have some luck there. MX5's are 14" though I'd imagine. The alloys on them certainly are.
Sept 27, 2010 15:22:56 GMT
MX5s have a fairly small center bore IIRC, and are 14". I got some G60 steels for £120 a set new from VW about a year ago, but they should use radius seat wheel bolts which is an extra expense if you don't already use them.
Vauxhall are et49 so well inset, also smaller than VW center bore. Renault tend to be around et38 and have a nice big center bore hole that goes over most hubs.
Foxy
Sept 27, 2010 15:26:16 GMT
I basically want them to get banded, so offset isn't really an issue. Anyway cheers for the replies folks, much appreciated! I think I may go down the mini one steel wheel route.
Ryannn
Sept 27, 2010 18:39:04 GMT
I think my Volvo 480 has 15 inch steels... they're 4x100 anyway...
Sept 27, 2010 18:44:18 GMT
If they are getting banded, Vauxhall ones would be good (providing they clear the insides) as you'l get another 1/2" of band on them before they poke the same as a VW/etc wheel.
Sept 27, 2010 20:49:17 GMT
Volvo 400 has always 14" steelies from factory.
Vauxhall Astra had them and Renault Megane.
Nice tip about the new Mini, didn't realize that one.
Click picture for more
