Sept 18, 2010 17:38:33 GMT
hi,i need this car back on the road so any help you can give would be great! its a vw caddy pickup,and I have just changed the engine and cant seem to get any fuel up and I have filled the filter and fuel lines but still nothing?
Last Edit: Sept 19, 2010 15:50:36 GMT by maiders
SPOTS MUSH!
Sept 18, 2010 17:56:20 GMT
Is there a bleeding procedure for these? Do they self-bleed or do you have to bleed the fuel system manually?
kevfromwales
the conrod's REALLY out the block now!
Sept 18, 2010 17:57:47 GMT
what benzboy says - think you'll need to bleed it
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
bortaf
Sept 18, 2010 17:58:48 GMT
do you have a manual lift pimp on the filter? if yes take off the union from it to the engine and see if is squirts when you pump the button, if no there either no fuel in the tank, a blockadge or the lift pump is knackerd. If yes check for alive at the shut off solenoid, no live = fix it, a live listen out for a click when you put the live to the solenoid, no click remove it and either change it for the old one ir free it off if it's seized. I take it you just swapped in a known running engine ? if there is a click try cracking the nut on the injectors till there is fuel coming out, retighten and try agan?
Last Edit: Sept 18, 2010 17:59:42 GMT by bortaf
R.I.P photobucket
Sept 18, 2010 18:07:51 GMT
yeh it was a running engine,there is a bleed nipple on the pump but no amount of turning it over seems to bring any fuel through?same with cracking the injectors?
SPOTS MUSH!
Sept 18, 2010 20:04:01 GMT
was it a petrol and youve converted to derv .or just an engine swap.
97 volvo 940 turbo wagon 87 fiat strada abarth 78 gs1000 82 katana 1100 84 gsx1100 efe
Sept 18, 2010 20:54:48 GMT
it was just a straight engine replacement aef diesel 1.9,cambelt jumped on the old one!
SPOTS MUSH!
gn3dr
Sept 18, 2010 20:59:13 GMT
I was recently trying to bleed a diesel Merc and I used one of those vacum pumps (for sucking engine oil up through the dipstick). I just connected it to the fuel return line to the tank and it primed the whole system. If you have one of those it's worth trying.
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
Sept 18, 2010 22:13:54 GMT
hang on a mo , what year is it??
if its a chip key , normally after 96 with most cars then youll have to bypass the immob on the pump or fit your old pump,.
facebook: rodney dean / rd transport
maxlee
Sept 19, 2010 7:09:15 GMT
if its just an older one with out chip and key etc try pulling it down the road in 3rd or 2nd. if nothing eles works
i have had this problem with one or to cars over the years and given up pull started them then they have started on the key ever since.
Sept 19, 2010 8:06:29 GMT
hang on a mo , what year is it?? if its a chip key , normally after 96 with most cars then youll have to bypass the immob on the pump or fit your old pump,. i think you may have a point there!just looked in the key and there is a chip. i didnt think it would be a problem with immobilizers as i thought they were in ecu's?
SPOTS MUSH!
Sept 19, 2010 11:21:31 GMT
you will have to wire the stop solanoid to an ignition fed live mate to get it to work
Sept 19, 2010 11:51:36 GMT
you will have to wire the stop solanoid to an ignition fed live mate to get it to work is that a way of bypassing the immobiliser? it defo has one but you have to take the pump off to swap the immobilisers over,which i don't want to do as i hate timing!
SPOTS MUSH!
Sept 19, 2010 13:23:21 GMT
no just uncover the stop solanoid on the end of the pump.and run an ignion live to it jobs a gud un
Sept 19, 2010 15:47:16 GMT
ok sounds good!which one is it?heres some pics of it.. right hand side [/img] bottom,where immobiliser is? i was told the solinoid was under where the immobiliser is?because otherwise people could just hotwire it?
SPOTS MUSH!
Sept 19, 2010 15:48:27 GMT
bottom of pump where imobiliser is?
SPOTS MUSH!
froggy
Sept 19, 2010 16:57:57 GMT
smash the security cover off the pump and change the solenoid for a conventional one . the soleniod is pulsed to open it so running a permanent feed wont work. i had this problem after doing a crash repair to a caddy and fried the immobilisor module whilst welding and had to do this to get it working again.
Sept 19, 2010 18:07:11 GMT
smash the security cover off the pump and change the solenoid for a conventional one . the soleniod is pulsed to open it so running a permanent feed wont work. I had this problem after doing a crash repair to a caddy and fried the immobilisor module whilst welding and had to do this to get it working again. i cant see any covers on the pump?
SPOTS MUSH!
Sept 20, 2010 5:17:32 GMT
well caddy not going still,need more help lads!
SPOTS MUSH!
Sept 20, 2010 17:21:58 GMT
the back of the pump just above the pipes to the injectors its a steel cover with shear bolts to hold it on.its a curse word to get off.and the solanoid just need a 12v live to open it .ignition fed so it will turn off
