Sept 3, 2010 22:11:00 GMT
I love Minors, my Grandad had a couple yonks ago and I still love the shape. They are soo ripe for modifying and it's great to see you're doing this really properly. Nice. Loving you plans for it, proper suspension, brakes and a 200bhp Zetec are exactly what is needed in a Minor. ![;)](//storage.proboards.com/forum/images/smiley/wink.png) I remember Nic Mann's one from years ago. It was frighteningly quick way back then - even now there isn't much that could match it. It was tested in one magazine (probably CCC) and it did 0 - 100 mph in 6.7 secs! And it handled fantastically on the track and hills too. A real beast of a car. I wonder what ever happened to Nic's Minor? I know he still races in sprint/hillclimb. Maybe he mothballed it as it was his mums car before being passed to him?
dan
Last Edit: May 29, 2020 19:16:13 GMT by dan
Oct 28, 2010 14:10:38 GMT
Looking top notch!
wallopadonkey
stunning grinder! curse word welder!
Oct 28, 2010 18:10:30 GMT
on the picture before where you said 'the lead has gone now' that's not rust is it ? on the seam line
1983 mini city e 1985 miny Mayfair 1997 Audi a4 tdi 2003 gsxf 750
dan
Well spotted. Yes it was rust but most of the messy stuff that you can see on the seam line is the old lead that melted and wasn't removed properly.
The body was returned to SPL do properly. Apparently they had 2 lines - one of which Aston Martin used and one for LDV. Have a guess which mine was initially done on? I don't know the exact details but I think it was either not properly dried off or had been left outside in the rain between processes. You can see also the rust on the underseat battery box photo. Thankfully all sorted now though.
Last Edit: Oct 29, 2010 8:18:18 GMT by dan
dan
Mar 28, 2011 22:51:28 GMT
Update time Since the last installment the mog's returned the the right way as the under side is now done for the time being. Panels, sills, flitches, apertures and interior have now been seam sealed along nearly every joint I can find. The polyurethane seam sealer is horrible stuff it goes everywhere and if you're not careful cleaning up is like trying to get 5hit off a blanket. Just when you think you're getting there you then spot another bit that needs doing. It just never ends, Aaaaghhh :evil: Now it's back the right way up I've masked up this front arch and can now finish it off properly ![](https://img.retro-rides.org/i/v/dantournay/9289f6ff7c49.jpg) Arch now looking good. Got rid of the traces of the lead in this area and on the other side yesterday This side was facing the ground when the underside was done so rear nearside arches have been prepped, skimmed... ...and etch primed. Ready again for more masking and stone chip Currently prepping and masking up again for stone chipping the arches, sills and interior over the next few weeks.
Last Edit: May 29, 2020 20:07:30 GMT by dan
this is deeply awesome.
How easy a fit is a Zetec in a Minor? Say I had a stock Minor, a 1.8 Zetec and a RWD box of some sort, is there an easy sump to chose to avoid hitting steering and so forth? Does the bulkhead need to be cut? Obviously the trans tunnel will need work for the box depending on which one uses...
Nice build you're doing there. I do like modern engine swaps into classics, especially if the exterior is kept relatively standard.
Mar 29, 2011 10:06:44 GMT
my car is almost identical, although i couldnt afford the 4 link bar kit as a student ![:(](//storage.proboards.com/forum/images/smiley/sad.png) very nice indeed!!!
dan
Mar 29, 2011 14:56:57 GMT
this is deeply awesome. How easy a fit is a Zetec in a Minor? Say I had a stock Minor, a 1.8 Zetec and a RWD box of some sort, is there an easy sump to chose to avoid hitting steering and so forth? Does the bulkhead need to be cut? Obviously the trans tunnel will need work for the box depending on which one uses... Yes the bulkhead does need to be cut and reinforced and I think my sump came from www.raceline.co.uk/products/index.asp?CategoryID=4 Omex supplied my engine but you do do a lot worse than having a chat with Jon at www.jlhmorrisminors.co.uk/store/index.php?page=0&act=viewCat&catId=19
Mar 29, 2011 15:07:11 GMT
cheers. I'm just mulling a "future project" I always promiced myself which is a fast, modern, economical Minor but mindful of BIVA and other nausea as well as having concerns about how much cutting I want to get into...
Last Edit: Mar 29, 2011 15:07:56 GMT by akku
Mar 29, 2011 16:42:32 GMT
Great project. Definitely looked a bit crispy to start with!
Mar 30, 2011 13:58:31 GMT
cheers. I'm just mulling a "future project" I always promiced myself which is a fast, modern, economical Minor but mindful of BIVA and other nausea as well as having concerns about how much cutting I want to get into... I've never tried it, but apparently the Ford X-flow will fit without cutting. It might be worth looking at the Vauxhall family of OHC engines, as fitted to the Astras etc., as I reckon they're probably about the same size. The problem is that although the minor has a very wide and deep engine bay, it's not very long.
dan
Apr 24, 2011 21:05:14 GMT
Update from the last few weeks. Body filler Time! ![:-/](//storage.proboards.com/forum/images/smiley/undecided.png) I'd never done anywhere near this much bodywork before but armed with plenty of encouragement and advice from Jonathan & youtube there was now no turning back. This is the stuff I've been using and I've found it's been incredibly easy to use - unsurprising really as that's what it says on the tin ![;)](//storage.proboards.com/forum/images/smiley/wink.png) ![](https://img.retro-rides.org/i/v/dantournay/6429989a170e.jpg) Starting with the offside rear quarter, I keyed the e-coat, cleaned the body and masked the wing. Once fitted I then had a nice edge to work to. ![](https://img.retro-rides.org/i/v/dantournay/97c6478bf265.jpg) Mid afternoon I heard a weird buzzing noise and the Goodyear blimp flew over. ![::)](//storage.proboards.com/forum/images/smiley/eyesroll.png) A few days later and although it's not looking great it's feeling pretty good. Etch and high build primer to still go on. Started the nearside yesterday. Fingers crossed, I should have the majority of the rear done by the end of this week. Finally decided on the wheels and sourced myself some Citroen C5 'steelies'. They're actually alloys and weigh 4.76kg each ![::)](//storage.proboards.com/forum/images/smiley/eyesroll.png) 6x15in, 18ET, 108pcd and fitted with 195/45/15 tyres. Bit more info here www.106rallyeforum.com/forum2008/showthread.php?t=42661&page=1 I reckon they're going to be perfect for the performance and sleeper historic race car look that I'm after. After giving them a good clean and tidying the garage it would have been rude not to offer them up to the body.
Last Edit: May 29, 2020 19:34:35 GMT by dan
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
Apr 24, 2011 21:50:54 GMT
gonna be a cool moggy,.
facebook: rodney dean / rd transport ![](http://i564.photobucket.com/albums/ss82/rodney_racing/40322327267617s.jpg)
Apr 24, 2011 22:38:30 GMT
Ah I'm glad to see an update on this one. Those "steelies" are a fantastic choice, subtle FTW! Brilliant Minor build, just how I'd like to do it if it were mine.
gn3dr
Apr 29, 2011 23:45:53 GMT
I really like those wheels. What price are they?There are conflicting prices on the thread linked
dan
May 18, 2011 22:06:37 GMT
I really like those wheels. What price are they?There are conflicting prices on the thread linked I got them off ebay where I paid £250 all in including almost new tyres. Would have cost me £400 to if I'd paid full price. I think they're around £60 each brand new from a Citroen dealer. Anyway, bit more work to the rear quarters. Here's the high spots on the offside before I took a pein hammer to them. Shaping nearside rear after the first trawl of filler. The rear wing is a really sweet fit now. Should have taken a one before the first bit of filler went on but nevermind. Here you can see the keyed ecoat and where the lower section of the bootlid was replaced. ![](https://img.retro-rides.org/i/v/dantournay/ab7e3aa49ff6.jpg) Proper skim of plod First working of the bootlid and primed with a bit of etch. Look better in the photo than it is as there's still some lows. After a couple more hours, over a couple more evenings it's now beginning to look pretty darn good. ![:D](//storage.proboards.com/forum/images/smiley/grin.png) Just every other panel and the rest of the tub to go ![:P](//storage.proboards.com/forum/images/smiley/tongue.png)
Last Edit: May 29, 2020 19:48:28 GMT by dan
dan
Jun 13, 2011 23:06:44 GMT
Last Edit: May 29, 2020 19:48:59 GMT by dan
I,m thinking of doing something similar but as the bulkhead has been modified will your car need to be tested sva/biva ?
If I had two brains I,d still be a halfwit 1969 Morris Minor Traveller
