Thanks for the comments Guys. I do really get a buzz it when I see that other people like the car.
![8-)](//storage.proboards.com/forum/images/smiley/cool.png)
They're not everyone's cup of tea I'm sure but there are so many open minds on here, it is rewarding to share.
I'd like to hear the reasoning behind moving the front wheels rearwards, I assume its to get a better angle on the steering arms, but 99% of companies would just move the rack not create a load more work making the new front wings.
That's a logical question, and one I'm not equipped to answer without asking Mike to explain again
![:-[](//storage.proboards.com/forum/images/smiley/embarrassed.png)
. I will update once I've done that, Mike is happy to explain his work and is very open about his thought processes, which helps me learn too. Suffice to say, we have made new brackets for the top wishbones to fit the front subframe and had new stub axles made, so it has been pretty involved to get the geometry correct.
The front arches were going to need a lot of work anyway, based on the wheel offset change.
Aside from that, if you study this photo, and the contour of the front arches, you may see what has always been niggling anyway. Look left, then right, then again....
![](http://i42.photobucket.com/albums/e327/alolympic/Olympic/olympic001.jpg)
So, here is more of an update that is non wheel related, and a little more detailed than normal (this info is mostly from Mike).
Diff and Rear suspension -
Since the car was rebuilt with the BMW set up, the undertray of the car has been damaged by the droop of the trailing arms, as can be seen here -
![](http://i42.photobucket.com/albums/e327/alolympic/Olympic/ABanksRochdaleasreceived007.jpg)
We sent the dampers back to Avo and they fitted droop stops to prevent the excessive droop being a recurring problem. There is still plenty of droop for maintaining tyre contact with the road in all but extreme road conditions. Shorter rear springs are now also fitted too.
Mike also identified that the rear mount for the diff wasn't really satisfactory.
![](http://i42.photobucket.com/albums/e327/alolympic/Olympic/ABanksRochdaleasreceived022.jpg)
![](http://i42.photobucket.com/albums/e327/alolympic/Olympic/ABanksRochdaleasreceived015.jpg)
The top of the diff was bolted to a bracket off the beam. It is presumed that this area would be bolted to the chassis of the donor BMW. As it is here, it could be levered and the beam twisted against the "heel board" of the Rochdale where it has those two mounts. Loads through the suspension would put much more force through this so it needed a far more secure mount.
Since that diagnosis and some further thinking, the reassembly of the car will involve far more than making better mount points.
The Rochdale is losing more and more of what it owes to an E30 by the day, and losing weight at the same rate......
The fuel tank -
We removed the fuel tank in order that we could get to the diff rear support bolt. The tank was found "supported" on various bits of wedged in timber and two self tapping screws. The fuel tank had a hammered indent to clear the nut for the rear mount bolt so the tank had to come out to remove the diff. Mike advised to change the way it is secured, to re-glass a vertical section of this area, provide a steel hard point with captive nut to allow diff removal without the tank having to come out.
A new fuel tank support, has been made, as can be seen in the pic
![](http://i42.photobucket.com/albums/e327/alolympic/Olympic/Photo0525.jpg)
This is made from two vertical plywood panels each side of the tank, which will be permanently bonded and glassed to the boot floor and vertical area. Aluminium angles are bolted to their tops so the tank flanges can in turn be bolted to them into floating anchor nuts. Lightening holes are also cut into the plywood panels to provide pass through for wiring etc.
Talking of wiring, Mike wasn't impressed with what lurked beneath the tank in the boot. Suffice to say, a new loom is having to be made, massively frustrating for a car that has travelled less than 1000 miles since this was done.
![](http://i42.photobucket.com/albums/e327/alolympic/Olympic/Rochdalerearsuspensionandfueltankarea025.jpg)
![](http://i42.photobucket.com/albums/e327/alolympic/Olympic/Rochdalerearsuspensionandfueltankarea024.jpg)
![](http://i42.photobucket.com/albums/e327/alolympic/Olympic/Rochdalerearsuspensionandfueltankarea019.jpg)
This is the wiring for the rear central fog light and number plate lights.
![](http://i42.photobucket.com/albums/e327/alolympic/Olympic/Rochdalerearsuspensionandfueltankarea018.jpg)
As a slight aside, but on the same subject, this is inside the drivers side wheel arch. An area that is completely exposed to road debris.
![](http://i42.photobucket.com/albums/e327/alolympic/Olympic/ABanksRochdaleasreceived006-1.jpg)
More in the exciting world of 'why pay for a car to be rebuilt once, when you can do it twice' soon
![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
