Copey
engine bay welding done, just needs some grinding and painting battery tray, front crossmember and inner wing battery tray shortened to give room for rad passenger side inner wing drivers side inner wing
Copey
re-blacked the bay today
Copey
Feb 13, 2011 17:52:40 GMT
head off today with the help of Nick and Tim (for a bit at least till he buggered off, lol) ready for gettin the stud machined out its a bit coked up but its in a good condition otherwise! will give it a damn good clean and will check the fuel/air mix when i get it up and running again happy with it tbh
Copey
its been a while since i updated here, if anyones reading here you go got the manifold stud out, eventually, tried a few engineering places local, none would touch it because of the snapped stud extractor (stupid previous owner!) and then i got sent the wrong replacement manifold studs, so that all put the project back a week! anyways, while the head was off i fitted the FMIC and rad and painted the engine blue, after i got the head back i cleaned it up fitted a new head gasket and then fitted new big end bearings inlet and exhaust/turbo back on and back in the bay! then blasted the cam covers primer (incl timing belt cover) paint
Inspirational project much?! Looks supoib as ever mate.
Copey
thanks mate
mrluke
Been following this on here and on Capri Power. Any chance of throwing up a couple of pictures of your new engine and gearbox mounts? Checking how much work it is before I start buying engines lol
Copey
well a few updates, had it turnin over after stripping 90% of the SX loom to end up with about 10 wires, if that! (worlds shortest vid) but its signs of life!! crossmember done and finally back on its wheels and today i sorted out the clutch pedal, used the SX pedal with a bit of modding hope to have it running 2moro once i have finished off the fuel lines
well done, this has really come on quick. be good to see some road test vids.
Copey
thanks mate, hopefully be some vids soon been workin on it today, fitted the fuel lines and swirl pot tried startin the engine, it coughs into life a bit and then dies, i need to connect up all the hoses properly and hopefully it will start then
Mar 26, 2011 22:44:19 GMT
i likes it alot, love the banded steels where are they from
Copey
Mar 26, 2011 22:50:48 GMT
thank you very much they are originally Mondeo Steels, banded locally by a lad in Liverpool bit of an update IT RUNS!!! rough as hell, but its a start! and a pic of the nice rocker covers fitted next up, wiring, touch up under the engine bay, exhaust, proper intercooler pipes, gauges, gear box tunnel...still a lot to do really, but its gettin there
Mar 27, 2011 19:24:53 GMT
That looks so nice, very smart!..apart from all that wiring gives me the shudders! Getting so close now, keep at it ;D
Project Diary1975 Viva / 1988 T25 Camper / 1989 Mini / 1991 MX5 / 1992 Mini / 1994 Saab 9000 / 1997 Saab 9000 / 2008 Saab 9-5
Copey
Mar 27, 2011 19:36:53 GMT
cheers lads
Oli, thats a fraction of the SX loom too! took hours to strip it back! haha
Mar 30, 2011 10:56:49 GMT
Love it
meltedcheese
Please, Don't Sqeeze the Volvo!
Mar 30, 2011 11:41:27 GMT
Certainly getting there now Looking nice and clean.
Copey
Mar 30, 2011 14:47:59 GMT
thanks lads gettin there now!
fanboy
Mar 30, 2011 15:02:12 GMT
WOW I WANT IT!!!!!!
1999 mercedes clk AMG 1997 rover 800 coupe
I refuse to answer that question on the basis that i do not know the answer
"if in doubt flat out"
Mar 30, 2011 15:29:41 GMT
UWPH! come along way from what it was mate, well done!
Looking forward to hearing this and seeing it aorund s-port :-)
