Jul 10, 2012 13:36:56 GMT
So...in the last couple of days I've been pondering how to move this car along significantly...this has been helped greatly by a chap who has been incredibly helpful so far in suggesting that really, this car is actually very close to completion...(yeah, I laughed too). What will speed this up would be completed bodywork, there really isn't actually that much welding to be done on this car - almost unheard of on an S30 chassis. While I will be stitch welding certain spots, its mostly just the odd and typical patches where areas have been exposed to salt on the roads. To help all this along, the shell will get introduced to some ground walnut and lots of air pressure.
Last Edit: Dec 13, 2016 20:50:34 GMT by camerashy
Jul 17, 2012 19:50:57 GMT
At the weekend I managed to sell the (new) but crude Twice Pipes system I had for pretty much what I bought it for. And so today after hanging around forever for the DHL guy, a large box from Osaka, Japan turned up. Oh yes! I remember now, I had ordered something. Somewhere in there was this lot. <3 TIG-welded stainless and holy cow on a stick, this is a micro-tig weld. Robots? That sits on top of the backbox, like so. Photos don't do it justice, it is a modern work of art. I can't explain how happy and relieved I am it didn't get damaged during shipping. An update on the car coming tonight, it's looking pretty naked!
Last Edit: Dec 13, 2016 21:01:12 GMT by camerashy
Anglia68
Powered By Boredom.
Jul 17, 2012 22:33:50 GMT
Holy cow on a stick, THIS is a micro-tig weld... Christ! I've an operation scar on my belly that's not as neat as that. Bostin' car by the way,I like the way it's progressing.
Jul 20, 2012 16:32:21 GMT
I have been busy as a bee stripping out the loom and reading the Service Manual like a fiend, it's funny how much you can learn just by doing that. As such I've made the decision to do away completely with the stock manifold and go down a ITB (Independent Throttle Bodies) route with a full EFI system using Megasquirt. I'd like to do away with the dizzy and use EDIS coilpack system - or potentially COPS (Coil on plugs) depending on budget and how the project progresses. I'm also going to start making a point of making my posts more user friendly and share some of the accumulated knowledge I've built up over the past couple of years playing with these cars - I'm not saying it's gospel, but it helps. While I would like to just 'get on with it' it seems more fun to try and document it was well as possible. Anyhow. As it stands, the car is almost completely stripped of parts, only the engine and box are left. This is so I can take it to be media blasted and start the welding. So, without further ado, the state of the Datsun at present. The interior minus dash, steering column, pedal box, fresh air vents (which oddly don't seem in anyway to be connected to fresh air), pretty much everything. Much of the non-engine loom is resting in the passenger footwell. Dash loom safe and sound ready for cleaning and for me to strip out the JECO clock and associated wiring on the dash loom. These old Datsuns have a wonderful tick-tock clock that runs constantly, it also has a pesky habit of draining the battery when the car is left parked up for a week or so (usually if there is a bad earth), and in an effort to save weight...who needs a car clock when you have a watch or phone. Which takes us to the windscreen wiper cubby. There wasn't anywhere near as much rust as I was expecting here, just some hazel nuts and leaves. I am looking to replace the wider motor with a Honda Accord/Civic unit, this will speed up the wiper considerably - it's totally inadequate in heavy rain) but it will lose me the 'wiper park' function. Still I figure a bit of rain-X on the screen in conjunction with this should make the car more suited as a daily driver. The alternative to using the Honda motor might be to use a citroen AX (single) unit which is just a single wiper, and obviously lighter than having a dual wiper linkage. Just a bit hard to find one over here. Onto the engine. Here is a rather lovely L28 Unit. I believe it is the original engine, I haven't checked the VIn stamp to see if it matches to the chassis yet. I have removed the AC system totally - it's gone to a good home, as well as the Master Brake Cylinder, Clutch, Intake and all the EFI garbage that was for emissions controls. The head is an N47 head which is good stock unit to make nice power without much work. Infact cleaned up and running megasquirt nicely on ITBS I'm not expecting to have to do very much to the engine for it to get close to 185-190hp. With all the weight removed, new header/exhaust working as a system and some degreasing action (possibly replacing the lash pads) I am hoping it'll be a bit happier and freer breathing. I will get it dynoed at the end. Looking a little empty in that engine bay. ^^ The head stamp. The head with the valve cover off Valve cover Cap - sadly not the awesome wee elephant one, but I like it These valve covers came in a whole miriad of different lettering font, size and content with some covers being 'more desirable' than others to certain engine pimps, I like mine just as it is, this car is to be functional, reliable and awesome, not a chromed engine bay. The cam lobes have me a tiny bit worried, I'm not ultra familiar with how to 'check' cam tolerances, and there does seem to be some wear on the lobes, if anyone has a good pointer to some articles to check this I'd appreciate it. I've got a feeling that this engine may have (at one point) either been a bit oil starved, given how ridiculously clean the head was, or have worn lash pads/incorrect sized lash pads. It's running an 'A' stamped cam which I can;t seem to find any info about on HybridZ - although I'm sure its in the FSM, I'm not looking to replace it (maybe in the future?), mearly get the engine running. And the timing gear - this I may replace with an adjustable one to get the timing spot on. Lastly more suspension pornography from T3 appeared in the post.
Last Edit: Dec 13, 2016 21:20:33 GMT by camerashy
ewokracing
Snuffling for food in a river
what brand is that muffler you got from Japan? Looks perfect for what I need...
I have the same problem as you with wipers on both Mazdas and the Rover. Shockingly bad in the wet. The wipers are out of sync with how often they should wipe across the screen - either too slow or too fast.
It's a Fujitsubo ewokracing check out RHDJapan.com and see if there is something available for your needs, search by chassis code. I'll let you know how the wiper upgrade goes, and yeah, driving the Datsun in the rain was like wishing for death.
Last Edit: Dec 13, 2016 21:26:12 GMT by camerashy
ewok Aaawwww! Sorry ;D Good to see this progressing fast I think I have to catch up a little ;D Cheers, Jan
L28 Powah. After taking the cylinder head bolts off in the right order - as per the full service manual, and loosening the camshaft towers AND by nothing short of a miracle, getting the cam pulley off without taking the crank pulley off or pulling the timing cover (magicians hands), I was left with this lot. Bolts were bagged and numbered as I good them out, same as the cam towers. Contrary to what I thought originally, this lot is in mint condition, it's barely even broken in, the lobes on the cam are nigh on perfect, the head is in 'like new' condition but for a bit of carbon, and it can only be on it's second head gasket (it's an after market Felpro), so I'm guessing the milage is the original milage, 72000 miles. Brilliant! [/url] The honing on the cylinder wall is like it left the factory, like glass, I actually laughed hysterically for a bit, I couldn't quite believe just what good nick this block and head are in, they're dirty, but mint! [/url] [/url] The cross-hatching doesn't show up well but it's there, and it's excellent. Granted, there's alot of carbon build up, but judging by the state of the gunked up throttle body, this thing was running rich anyway, one of the injectors was also leaking. The block has even maintained its factory blue colour. Something I am going to replace in here (all the gaskets, and the cam pulley - nice shiny fully adjustable Tomei one is on its way) are the lash pads As you can see, they are worn, as the rocker arms obviously spent billions of times hitting the wee things, and they each wear slightly differently. So as a matter of course I am going to replace them all back to OE spec which should help reduce any knocking as well as tighten things up. I am still weighing up if I will replace the rocker arms with gram-matched ones too, it's a fair chunk of change. For anyone who wasn't sure what a lashpad was, it's the small circle above that has the trough cut through it. It sits atop the valve on the stem and collets and is what the rocker arm pushes down on when the camlobe moves the rocker arm. Like I say, they're a little worn likely as a result of the valves not being periodically adjusted. The whole point of removing the head was to 1. Check condition and 2. Make getting the engine out easier. Condition checked it's on to engine removal. The ceiling in my garage is very low, so long that getting an engine crane in to get the engine out is a faff, and I needed the engine to be as 'short' as possible to be able to get it out. Short to the point that I returned the leveller I'd bought as it was too tall to be able to get the engine out in the space I had, lacking the chains that come with a leveller. The stock seatbelts entered a bit of surgery. Spotted some dull round objects hiding $4.10. Profit. I was pretty chuffed! Not only had the worthless seatbelts given up their lives to become engine cradle...but I am $4.10 richer. Well happy. That'll do . All set to lift tomorrow. Now., how to move the shell to the blasting place? A free pallet found round the back of the Beer Store, a walk to Home Depot for some castors, and some 2x4" from the garden (my Canadian friends are insistent that it is a 'yard' and I have no place calling it a garden) to shore it up.
Last Edit: Dec 13, 2016 22:16:28 GMT by camerashy
More large boxes from Japan have been delivered, I've managed to sell parts I won't be needing (old bonnet, distributor etc) and those funds have been recharged back into the shiny fund. Today, after being way too distracted (lady trouble, work busy, rain stopping play) I manned tup and got on with it. First off, getting the engine out. I undid the 6 bolts that hold it to the box (not before raising the two connected together and draining the box our the prop-shaft end) and raised the engine. A bit hair-raising when using 40 year old sun-worn seatbelt.... I was right to take the head off though, there was no chance the crane would have been manuverable otherwise, I even hit the central air bulkhead without the head on. Empty bay at last. Thar she be! Free from the clutches that held it. The scrap extension cord did a nice job of stopping the box smashing to the ground when the two parted ways. Then I put together the engine stand I got for $40 (50% off sale ) I'll have to track down the right bolts to hold the block in it, I'll trek up to Home Depot tomorrow night. With the block and box out the way, I pulled the fuel and brake lines - I'll be redoing the whole lot, lifted the front end with the crane, and shuffled the dolly in underneath. Whole thing moves with one hand now.
Last Edit: Dec 14, 2016 0:58:17 GMT by camerashy
And a very small sneak preview of future things to come. These were snagged from an R34...any guesses on where the project is going? and no...I'm not dropping an RB lump in there. and these are the highest quality ZG flares you can find, I was not happy with the fit of the ones I bought from MSA, the were warped and I imagine the mold is too. So a browse of RHDJapan and a two week wait Marugen Shokai ZG flares. Thanks Japan
Last Edit: Dec 14, 2016 1:04:21 GMT by camerashy
Aug 29, 2012 15:20:47 GMT
Spying some grainy images, for $146 AU I picked this up off Yahoo JP. Bargain. An original TRUST header (A copy of one of the Nissan motorsport headers). The Trusts were blue, the OS Gikens were Green, the Fujitsubos were red. Once it arrives I'll get it media blasted, check for cracks and paint it. Saved a small fortune versus buying a stainless Fujitsubo one that wouldn't have fit an LHD car anyway. Also picked up 6 trumpets from a chap in Hungary like these. Should look good paired with this lot. In other news, I took a bunch of parts to be blasted and powder coated, with the valve cover being powercoated wrinkle black. Everything else is set to be plated with zinc when I get back from Alberta in 2 weeks time.
Last Edit: Dec 14, 2016 1:34:06 GMT by camerashy
Aug 29, 2012 18:21:24 GMT
If anyone missed the Import Monster posts I made in reply to scousers thread in the general forum...if you combine the trumpets with the ITBS and manifold in the previous post, and the header and exhaust above you get an idea of the direction the engine is going in . And people used to comment on this thread! So many gawkers with no-one telling me if I'm batshit or genius....sad and lonely times!
Last Edit: Dec 14, 2016 1:36:20 GMT by camerashy
Aug 29, 2012 18:36:06 GMT
And people used to comment on this thread! So many gawkers with no-one telling me if I'm batshit or genius....sad and lonely times! Ha ha, that's 'cos I don't know. I'm sat here learning, slowly. However if the pallet based body transportation device is anything to go by I'll err on the side of genius, i gotta get me one of those! The cars really starting to look like it's getting somewhere too, we're not miles away from all those wonderful pictures of shiney things going together, looking forward to that bit. Rob
'55 Austin A30
'71 MGB GT
'72 Datsun 240 shed
'72 Mercedes 240D
'79 Firebird
'86 Austin Maestro Van
'91 Mercedes 250D
'91 BMW e34 535i Sport
'92 Mazda MX-5
Aug 29, 2012 18:50:18 GMT
Thanks Rob! I was going to send you a PM actually suggesting when you do get around to working on the shed, to track down a 280ZX engine, the parts for the L28 are FAR FAR easier to come by than the 240's L24 with many many more options of after market parts to spares like headgaskets, pistons, seals etc. . It'd be so much cheaper in the long run even if it does mean a change in engine size to 2800cc. There are many more shiny parts...but they're tucked away until after I'm back from out West for a proper 'engine build' update
meltdown
South West
Isn't letting old age get the better of him, still making the same bad decisions with vehicles.
Sept 1, 2012 13:15:00 GMT
Totally blown away by the progress on this, it's just lovely all these parts coming together.
Powered by biscuits
Sept 2, 2012 22:38:58 GMT
keep up the good work! here's a pic of a ZG to inspire you-
@ CRX_IN_SCOTLAND
Sad and lonely? It's one of my few bookmarked threads! Lovin' it, as they say.
Sept 3, 2012 10:00:41 GMT
Looking forward to seeing the blasting results! Dash loom safe and sound ready for cleaning and for me to strip out the JECO clock and associated wiring on the dash loom. These old Datsuns have a wonderful tick-tock clock that runs constantly, it also has a pesky habit of draining the battery when the car is left parked up for a week or so (usually if there is a bad earth), and in an effort to save weight...who needs a car clock when you have a watch or phone. I have a JECO clock in my car. It's so loud you can hear it at idle! And it doesn't keep time anyway..
Sept 5, 2012 13:53:30 GMT
Amazing! can't wait to see results. I love old J!
bstardchild
Club RR Member Number: 71
1978 Datsun 280Zbstardchild
@bstardchild
Club Retro Rides Member 71
Sept 5, 2012 22:07:47 GMT
If anyone missed the Import Monster posts I made in reply to scousers thread in the general forum...if you combine the trumpets... with the ITBS and manifold there.... and the header and exhaust above...you get an idea of the direction the engine is going in . And people used to comment on this thread! So many gawkers with no-one telling me if I'm batshit or genius....sad and lonely times! This thread has been one of my bookmerked threads but I've very rarely much to cotribute - this time I have I bought a set of those throttle bodies intending to mount them to a 24V senator injector rail and a set of the polish bell mouths but I couldn't get it all adaptorplated up and in a reasonable length to clear the inner wings so I went with carbs for now and the bell mouths have been on my carbs since - you need to either flat the mating faces on a bit of glass with grinding paster or make up a gasket from gasket paper as they aren't perfectly flat and don't do them up too tight as they can crack (I've had to order 2 replacements in 3 years. Rest of the project please carry on ;D
