kevfromwales
the conrod's REALLY out the block now!
Oct 27, 2010 12:08:44 GMT
hang on a minute, is this greg, with the PA, with the small block mopar??
- if it is hiya mate - it's kev from up in north wales
- if it's not, I may be rambling....
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
Oct 27, 2010 13:15:22 GMT
hang on a minute, is this greg, with the PA, with the small block mopar?? - if it is hiya mate - it's kev from up in north wales - if it's not, I may be rambling.... Yes siree it is, how you doin mate?? Your famous ent you, as in, i saw your photo along with Pollitt published in Retro Ford mag when he resurrected his mk2 Zodiac...
Seth
Oct 27, 2010 14:00:38 GMT
Looking at the way that crossmember mounts it looks like it would be possible to modify the crossmember itself to raise it rather than the shell. Those four "stubs" on the crossmember could be dropped relative to the rest of it. No shell mods for that one so no BIVA risk. Need to check there's room for the top arms though. It looks like the steering box must be mounted to the bulkhead/chassis in which case you ought to see what raising all the track rods may do to the steering geometry. You may also need to raise the box by the same amount on a bracket or something.
RobinJI
Oct 27, 2010 14:34:31 GMT
Yeah, I'd say chopping the cross member rather than the chassis would be the easier option. It would be easier to keep the strength that way I'd have thought, as well as avoiding the IVA issues mentioned.
