Jul 30, 2010 19:20:10 GMT
Except.... ha ha, I went and ran the codes. Asked the ecu for the trouble codes with 03 got 43 01 61 00 00 00 00 as a reply. That works out to one DTC, code P0161 which is "Downstream Heated Oxygen Sensor Heater circuit fault - Bank No. 2." and therefore useless. You would be surprised how often that happens I did find a BOB fuel rail (with injectors and regulator) in the shed, shame it's inlets off again to try it ![:(](//storage.proboards.com/forum/images/smiley/sad.png)
Got a mate with a big screwdriver?
![](http://i88.photobucket.com/albums/k198/scaryoldcortina/DSCF3276.jpg) Sort of....
is that seat petrol tank for sale?
Probably cheaper to buy another Scorp than have to buy more gaskets and take time out fixing yours. ![:(](//storage.proboards.com/forum/images/smiley/sad.png)
Jul 31, 2010 14:24:01 GMT
^^ Oh heck no, I don't give up that easily ;D
I don't need more gaskets to change the injector rail (just some 'o' rings and a big bag of swearing and throwing stuff) and the pump isn't THAT hard to get at. Might have another crack at it this evening.
AAAAAAAGGH! ok, deep breath. Fuel pressure checks today then., Showing 45psi delivery pressure (Does drop off a bit quick for me, but, it's there) Also tried blocking the return line off with an 8mm drill bit (to eliminate regulator issues) no real change to engine running. Changing the pump requires removing the tank ![:(](//storage.proboards.com/forum/images/smiley/sad.png) bah. In other news, I've written a basic diagnostic/logging prog in python to save me having to type commands into a serial terminal ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
