Davey
Diesel all the things
Nov 23, 2022 14:05:59 GMT |
K11 Micra x3 - Mk3 astra - Seat Marbella - Mk6 Escort estate - B5 Passat - Alfa 156 estate - E36 compact Mk2 MR2 T-bar - E46 328i - Skoda Superb - Fiat seicento - 6n2 Polo - 6n polo 1.6 - Mk1 GS300 EU8 civic type S - MG ZT cdti - R56 MINI Cooper S - Audi A3 8p - Jaguar XF (X250)
bstardchild
Club RR Member Number: 71
Nov 23, 2022 14:40:52 GMT |
Cor blimey, that's a piece of engineering mastery right there. Love a good roll cage. WHS ^ Any idea on "added weight from the cage"
Nov 23, 2022 15:16:08 GMT |
Hadn't come across those, so thanks for the links. You're seeing my problem tho  Hadn't expected there to be any issues getting parts when I bought them.. I should probably investigate these things in advance! Cor blimey, that's a piece of engineering mastery right there. Love a good roll cage. WHS ^ Any idea on "added weight from the cage" Truth be told I do not know. I'll take it back to the weighbridge when it's done. Hopefully still a bit less than its starting weight (1355kgs).
Davey
Nov 24, 2022 11:15:14 GMT |
Hadn't come across those, so thanks for the links. You're seeing my problem tho  Hadn't expected there to be any issues getting parts when I bought them.. I should probably investigate these things in advance! WHS ^ Any idea on "added weight from the cage" Truth be told I do not know. I'll take it back to the weighbridge when it's done. Hopefully still a bit less than its starting weight (1355kgs). Step lips seem to be easy enough to get if you have 15's and want to convert to 16's or 17's to 18's... Why 16's are strange I don't understand.
Nov 24, 2022 11:29:19 GMT |
Hadn't come across those, so thanks for the links. You're seeing my problem tho  Hadn't expected there to be any issues getting parts when I bought them.. I should probably investigate these things in advance! I should probably read back, but also check out : www.cruxwheels.com/Yup should definitely have read back, they only do up to 15" barrels and lips.
Last Edit: Nov 24, 2022 11:36:35 GMT by HoTWire
Nov 24, 2022 11:37:14 GMT |
Yup should definitely have read back, they only do up to 15" barrels and lips. They don't do 16's
zeberdee
Club RR Member Number: 2
Nov 24, 2022 12:10:44 GMT |
Last Edit: Nov 24, 2022 12:11:35 GMT by zeberdee
Nov 24, 2022 12:54:16 GMT |
as above, image are pretty handy. they were able to custom make some obscure rim sections for my bosses race car when he decided to fit some unsuitable wheels to it..... wasnt too expensive either from what i recall, less than i expected, anyway.....
Current fleet: '58 A35 (half mine) '67 11 window splitscreen vw (half mine) '77 mini 1000 (not quite 1000 any more!!) '86 Armstrong MT500 '89 XR4X4 '94 Corrado VR6 Some sort of sevenesque kit car (no age yet!!) '01 Mondeo estate 2.0 (engine eventually destined for kit car!) - scrapped, engine only left! '98 E300 estate, rusty but seemingly reliable, fast-ish tat hauler. eventual engine donor A35 van, or whats left of it after it lived in a field for many years
Nov 24, 2022 13:09:04 GMT |
Thanks, will check in with them. I need to do a proper measure up of the wheels / current lips & barrels so the new ones can be correctly spec'd.
Nov 24, 2022 13:25:54 GMT |
Well I am loving this.
Cage looks fantastic! Going to be a mega bit of kit when it all comes together!
Ooooh, look what's back  The cage looks EPIC. Time to get busy!
Dec 24, 2022 16:04:56 GMT |
WHS ^ Any idea on "added weight from the cage" Truth be told I do not know. I'll take it back to the weighbridge when it's done. Hopefully still a bit less than its starting weight (1355kgs). Martin estimates 70-75kgs of steel has gone in
Last Edit: Jan 17, 2023 17:50:44 GMT by HARDCORE
Jan 24, 2023 13:16:20 GMT |
Last Edit: Jan 24, 2023 13:56:47 GMT by HARDCORE
mylittletony
Club RR Member Number: 84
Jan 24, 2023 13:21:40 GMT |
Merry Girthmas!!!
Steve
Making progress in small, easy to handle chunks of awesome
Jan 24, 2023 13:30:02 GMT |
Sweet jeebus that's gonna look HOT!
Jan 24, 2023 13:31:01 GMT |
W I D E Iām loving that. šš»
Jan 24, 2023 14:05:32 GMT |
Jan 24, 2023 16:56:54 GMT |
Ha! Thanks all  Weirdly it's designed to go over the stock sideskirts & door trim panels (sacco panels, in Benz nerd speak) which I hadn't realised, and they're not on the car, hence the weird gaps.
bstardchild
Jan 24, 2023 19:07:56 GMT |
Ha! Thanks all  Weirdly it's designed to go over the stock sideskirts & door trim panels (sacco panels, in Benz nerd speak) which I hadn't realised, and they're not on the car, hence the weird gaps. Are you going for exposed fixings or fixings behind a load of wag to smooth out the transition from kit to car?
Jan 24, 2023 22:03:40 GMT |
Ha! Thanks all  Weirdly it's designed to go over the stock sideskirts & door trim panels (sacco panels, in Benz nerd speak) which I hadn't realised, and they're not on the car, hence the weird gaps. Are you going for exposed fixings or fixings behind a load of wag to smooth out the transition from kit to car? I think I already know the answer, and it's the light-er weight one
