Finished
MOT tomorrow then its up for sale.
£1800 Ono
Car located in Lincoln
07738006776
Spec:
Audi X L J 319 X Spec:
1981 Audi 80 B2 1600 now 1800
Exterior
• Re-spray in Satin Brown - Marathon Coatings, Strong Finish, 436 Satin, UN1263: RAL 8028 078-059-049 #4E3B31 Terrabraun Terra brown
• Clear Front Indicators
• Tinted all red rear lights
• Up-rated headlamp bulbs (50% brighter)
• LED sidelights
• Rolled arches
• De-headlamp washer mod
• Pressed numberplates
• Stainless Exhaust Tailpipe
• Smooth ‘Aero’ Wiper Blades
Interior
• Upgraded to better OEM Clocks with Rev Counter + LED bulbs
• OEM VDO Gauges – Oil Temp, Pressure, and Battery Meter
• Brown carpet set with beige trim
• Sub install in boot
• Blood red leather front seats from 90’s Audi 80 Cabriolet
• Rear bench re-trimmed in faux leather to match
• Chrome MGB mirror with one off Rapid Prototype mount
• Custom Gearknob – Lathe turned OAK
• Moto Lita classic wood rim steering wheel and fully polished boss
Engine
• 1.6 Engine swap for 1.8DS unit
• 1.8 DZ head (from Audi sport DZ engine)
• R6 Carbs with manual choke setup
• Hpi air filter
• JS Performance silicone hoses
• Facet Black Electronic fuel pump mounted under tank
• Chopper style polished horn
• Battery relocated to boot
• Detailed cam belt cover and fan shroud – (gloss white/black)
• Relocated headlamp washer bottle
• (New clutch with engine swap in January 2013)
Chassis
• Shortened panard rod
• GT Cupline rear Shocks
• GT Cupline Springs 50mm drop to rear
• Custom made front struts comprising of Gaz custom adjustable dampers, shortened 85mm. Shortened springs to suit.
• Power Tech 15x8†wheels ET20 running a lightly stretched tyre
• Audi logo centre caps
• Corrado G60 callipers
• Black diamond vented, cross drilled and grooved discs
• Ebc green stuff front pads
To add are: (included in sale)
- rear golf gti disc kit
- -1 degree camber shims to rear
- 6mm wheel spacers to wheel
£1800 Ono
07738006776
Spec:
Exterior
• LED sidelights
• Rolled arches
Interior
Engine
• Hpi air filter
Chassis
