I bought a volanti suede steering wheel and an M range boss to fit my Capri, the wheel is brill but the boss splines don't seem to mesh up. Its definitely an original capri column and the company I bought it from says that the boss is right and they've had no problems.
It seemed that the boss splines diameter is possibly slightly bigger than the column as it wouldn't lock on, I tightened the nut down and the boss then locked and I can turn the steering wheel on the spot with my wide 9inch front wheels lock to lock with no problem but I'm unsure as to wether its right. I called them and he insisted its right. its just that my previous aftermarket wheels and the standard wheel, the boss has slid on to the splines and locked before I put the nut on. Anyone have a clue what I'm on about?
