Rich
Club RR Member Number: 160
Show Us Your R/C CarsRich
@foxmcintyre
Club Retro Rides Member 160
Stratos looks great, be good with modern electronics in. I’d have donated a WPL control board (fully proportional combi esc and receiver but you look like your sorted) I’ve been playing with the Merc SK heavy. Less than 2 weeks to the RC Trucks national gathering 😬
ovimor
North East
...It'll be ME!
richYupp, just cobbled all my peripheral parts up to the board + battery... All Systems GO 👍 ... for £9.99 it's a no brainer >> SO another set on order. OVIMOR
Last Edit: Jul 4, 2024 18:13:32 GMT by ovimor
Knowledge is to know a Tomato is a 'fruit' - Wisdom, on the other hand, is knowing not to put it in a 'fruit salad'!
ovimor
North East
...It'll be ME!
The Lambo is here.... Totally gutted it! Poncy 'Nail buffer' motor is skipped and a Fat Boy [brushed] is lined up.. Dremel will nuke all unnecessary chassis plastic webs/pillars. So, It Begins 😎🔧⚙️ OVIMOR
ovimor
North East
...It'll be ME!
Gearbox done.... Fiddly job 😵💫. I created an 'L' bracket, to carry the required idler. The fat drive motor cannot mesh with the primary diff gear so I needed to insert an 'idler' 🙄. That all done (freehand with my drill) the fat motor is held in 'compression' against the high density foam and zip ties are holding the correct mesh ⚙️✔️. It runs very sweetly... Steering >> tomorrow 😎 OVIMOR
Rich
@foxmcintyre
ovimor interesting to see the rear wheels are on a hex, what size hex is it? Be interesting to know to see if these could be a good wheel donor for WPL/Bruder conversions..
ovimor
North East
...It'll be ME!
6mm is the Hex size, M8 Rear floor is all cut away = Txl now closer to floor/underbody clearance much better! Bits of plakkie glued on, to hold tx firm... Hot glue action will seal the deal. Steering jiggery-pokery to do now 😎 OVIMOR
Last Edit: Jul 7, 2024 16:16:38 GMT by ovimor
ovimor
North East
...It'll be ME!
Final 'stance, baybee' 😎⚙️ #1.. Wide wheel track @rear #2.. Camber dialled in @front #3.. Nose bleed 'lift' @undertray ... just sorting out the steering link/servo swing. Should be zipping round the living room by tomorrow night 🎈♥️ OVIMOR
Mine and the youngest lads tamiya tt02's that we take to the local rc carpet track, the bodyshells look battered after the first session.
ovimor
North East
...It'll be ME!
.... Just picked this up @charityshop £2 All sorts of interesting possibilities 🔧👍 OVIMOR
ovimor
North East
...It'll be ME!
The Lambo now has 'steering'.... A slot to be cut into the 'tie bar', for the servo actuator.... OVIMOR
ovimor
North East
...It'll be ME!
Jul 10, 2024 17:49:52 GMT
ovimor
North East
...It'll be ME!
Jul 12, 2024 13:22:26 GMT
Made my 1st purchase, towards the Big White Whale! .... Planning in it's early stages [IFS] ✔️ OVIMOR
ovimor
North East
...It'll be ME!
Jul 12, 2024 14:01:36 GMT
Rather than clog up this 'show us' thread, I'll start my own 👍
"Great White Whale!".... As above ^^
OVIMOR
ovimor
North East
...It'll be ME!
Jul 15, 2024 10:59:29 GMT
Batteries [2500 mAh AA 6pack] arrived and I can now run the car properly! 👍 OVIMOR
ovimor
North East
...It'll be ME!
This is some vid, down at Chester le Street cricket club car park...
OVIMOR
