hairymel
avatar by volksangyl
Club RR Member Number: 207
I got the engineers at work to make me up an adaptor collar so I could use up my worn down (too much to be effective in a 4.5 inch angle grinder) 1mm slitting discs i was going to make one with my dads small lathe but got scared off by the manual promising death and destruction if an adaptor is used. am still considering it though tatoostudio - i will probably buy a few slimline cutoff discs, the one supplied seems a bit thick to be useful!
whats that burning smell?
oh curse word :-(
drdick
Send me the dimensions Mel and I'll knock you one up at work
I buy em in packs of 50, for £28, can get them for either 4" or 5" fitting And it's pawl, the name's pawl
"No............I think I'll stick with the Maxi"
Arther Daley
hairymel
May 31, 2012 19:32:11 GMT
Rich - thanks , i might take you up on that if i can't get the required tuition from my dad . on a more pressing note how about just sunday the 1st without camping? i am having trouble convincing my boss to let me not be in york saturday evening ..And it's pawl, the name's pawl ... Hi Pawl - i now huntz you down with my leet googlefu skillorz ;D
oh curse word :-(
hairymel
May 31, 2012 20:06:48 GMT
oh curse word :-(
hairymel
May 31, 2012 21:15:50 GMT
wednesday i had to wait for Paul to come and check out the mess i had made in the unit. before he got there i quickly repaired the rotten bit of wing rail - without taking pictures as i had forgotten to take my workshop camera i also didn't have one of the thousand sharpies that pass through my workshop. this lead me to try another technique. it was so successful i went back and did a quick run through so the pics are a bit staged rotten wing rail section because of the shape of the section and the lack of a sharpie i decided to try a technique shamelessly stolen from an episode of american chopper jnr was making a template to fill a hole using duct tape, i used masking tape as i had some to hand. trimmed the edges flush with a stanley blade cut out the wing fixing hole and trimmed to the size i was going to chop out. the blade cuts also marked the rail so i knew where to cut out the rot peeled off and stuck to a bit of zintec i then cut out the repair piece with snips, drilled out the ends of the mounting hole and shaped with a file. I chopped out the rusty section then welded in the new piece and ground it all back. sorry no pics for this bit but the finished repair is better than i normally achieve ;D crossposted to tonybmws brilliant making panels thread retrorides.proboards.com/index.cgi?board=usetharch&action=display&thread=70135&page=1in other news the robins appear to be doing well
oh curse word :-(
Nice one Mel
Does the missus know you've got some young chicks in the garage ;D ;D
hairymel
tony:- I have tried to interest her in pictures (nudge nudge wink wink) but she seems more interested in popping out to the pub with the other yummy mummies
oh curse word :-(
hairymel
in an effort to avoid celebrating the jubilee until nearer the actual time, i hid at the unit today for reasons that will become apparent i decided to roll the beam outside a £7 strip+clean disc lasted all of 5 minutes cleaning off some of the worst suface rust fairly unhappy about the state of the rest of it but not unhappy enough to wire wheel it all to bare metal, i sploshed a whole bottle of loctite 7305 over the shoddy bits. seems much better than the sloppy toolstation stuff i used last time - it seemed to dry quickly and set the rust, rather than just rusting any clean metal i also cleaned back the weld through areas and the bits that had been left from the chassis painting inc. the bottoms of the chassis rails where the xmember was bolted. (b4 pic!) i then sanded back the engine bay and front valence using a combination of random orbital sander and elbow grease not wanting to be left behind by everyone else on RR who seem to be painting their cars, i brush painted the seams , bottom of the chassis rails and any other inaccessible areas. the next 45 minutes were spent wandering about muttering under my breath about the foolishness of building a 'spraybooth' not fitting lights and then filling said 'spraybooth' with tat once my unit neighbors had all gone, to wherever normal people go on a saturday afternoon, taking stock of the white van and white caravan that had been left opposite the unit in my parking spaces , i fired up the spray gun with some black epoxy ;D megane sensibly parked upwind ;D>>>>>>>>>>>>>>>>>>>>> can of energy drink in one hand and a cigarette in the other i surveyed the most impressive spray job i have done so far (also the first ). loads of runs from the brushed bits, a little bit patchy from one coat and half a dozen blobs thrown out by the gun for some reason, but a real mojo boost my o/h even said "that looks nice" to the pics which is better than the usual "that's nice dear" although she was wearing quite thick beer goggles still marveling how i had taken a picture with no free hands i answered the phone to the aforementioned o/h requesting airlift from the pub (1.30-8.30=/=quick afternoon drink ) so back to bed for the beam in other local news the 5(?) baby robins(?) seem to be doing well probably all for this weekend but i will try to sneak away if the 'royal we' allows it
oh curse word :-(
bstardchild
Club RR Member Number: 71
once my unit neighbors had all gone, to wherever normal people go on a saturday afternoon, taking stock of the white van and white caravan that had been left opposite the unit in my parking spaces , I fired up the spray gun with some black epoxy ;D Paint!!!!! megane sensibly parked upwind ;D Have you not burnt that thing yet!!! in other local news the 5(?) baby robins(?) seem to be doing well Yay for the birds
hairymel
paint- only some epoxy mastic to cover the repairs, although i hope i have enough cash left after payday to buy some white rustoleum to do the engine bay and interior - eventually think its interior repairs next then interior paint in 2013, build up running gear in 2014, panel+door repairs 2015, fit wheels and then rework arches 2016, fit interior+wiring/pipes 2017 , 2018 for exhaust, mot 2019, maddog2020,2021 exterior paint and 2022 glass/perspex bring on RR gathering2023 ;D megane is still not on fire working properly
oh curse word :-(
Great Mojo boost to get some paint on I remember having doubts, when I first started following this thread, that this would ever get finished. But hats off to you, you've persevered where many a mortal man would have thrown in the towel ages ago. Well Done Mel
drdick
Crikey, all I did yesterday was re-weld an exhaust manifold so it wasn't scraping along the suspension of the ginger ones truck. You managed this in about the same amount of time, nice!
MK2VR6
Mk2 Golf GTi 90 Spec
Great to see more progress on this old girl. I notice you no longer post costs/timescale! I keep thinking with this project that you could do with a mini RR 'diy sos' crew to descend on your workshop and give you a solid weeks help with getting the body finished, painted and the mechanicals back in. Having said that, your recent progress seems pretty rapid! Will keep watching with interest
hairymel
tony- i still have my doubts ;D if i fail it will be your fault though ;D, i wouldn't have started if it wasn't for your inspirational work/posts rich- any more thoughts on the sunday at the pod? maybe you could convince matt to come? please be my friend ;D gsi2000 - cost/time will make a reappearance, but the figures need a bit of 'creative accounting' to make them acceptable to sensiblehairymel not working parties please - the beers all mine i tell ye
oh curse word :-(
tbh, i thought you were nana's taking this on, just the sheer weight of the work needed, the amount of small areas that needed attention. but you know, chip away at the stone as they say, its actually rolling along into a good restoration
Putting a coat of black on has to feel a lot like drawing a line under all that hard work so you can move on to the next bit.
hairymel
Angyl:- it is a good feeling to have stepped past another millstone milestone i guess its like painting a canvas before painting the picture. not sure about beating, filling, sanding and then painting the canvas again though
oh curse word :-(
drdick
rich- any more thoughts on the sunday at the pod? maybe you could convince matt to come? please be my friend Sorry, missed the original post about this. I have to be somewhere on the Saturday too but could probably make it up on the Sunday. I'll ask the Ginger One what he's doing. What about your bro?
