Apr 21, 2010 17:00:22 GMT
Ive got a few new SA gear cables. There 2 metre long. Got the barrel nipple for twist grips and the rod nipple for triggers. Cut of the one you don't need, IE barrel. Theres and adjustable cable clamp with the tube that screws onto the rod thats goes into the hub. I got ten of those cables in a Halfords sale. got 8 left. Think it should be under £2 to post them to you. Also got a few twist grips and cables. Different size cogs. The spacers and spring retainers. And some of the rods that goes in the axle.
If the hubs oiled and has no cable attached but still no drive. It maybe that the insides are gummed up or rusted. Theres 4 diamond shaped pawls. 2 on each end of the insides. They can stick down. And the tiny springs can weaken or break. might try putting some parrafin inside to break up the muck in there. Or try taking it to bits and lubing it.
Apr 21, 2010 22:23:15 GMT
This page is useful for adjusting the cables on a 3-speed Sturmey hub: sheldonbrown.com/english-3.htmlAs sugegsted, if the pedals are 'freewheeling' forward whatever the cable position (try holding the trigger between gears and pedalling to see if the adjustement is the problem) then the pawls could be stuck. WD40 or similar could be used to free them off - but you'll have to re-lube as soon as it's freed off with heavier oil to protect the bearing surfaces.
Apr 24, 2010 21:56:41 GMT
Is the hub engaging any gears of does it slip? If it slips then the chances are the hub need stripping and new pawl springs installed
Apr 25, 2010 21:34:18 GMT
definatly not a 1969 bike there. the chain wheel bearing housing is modern. 80s onward.
1995 Toyota rav-4 1978 Kawasaki Z650B
Thanks for all the replies guys, i had a look at some old instructions off the web and managed to buy a gear cable from my local bike shop. Fitted that on saturday and having soaked the hub in oil for a few days i got it engaging gears!! Still needs setting up a bit as i have low gear, neutral and high gear but no 2nd. I bought 2 new tyres and tubes and have been out and about on it all weekend!! Havent even touched the brakes, as the rust on the rims slows you down plenty at the mo! I want to find out the date of this bike. The rear wheel has been replaced with a 1968 model. The front wheel is 1963 so i guess its from then, but some of the parts make me think its a little older. Can anyone shed any light? Put a basket on the ladies bike, looks the part now. Will get some pics up shortly. Joe
looks like youve got Altenburger brake calipers...which arent brilliant. If it was weimman brakes, it would have a date stamped on the back of them. There might be a date stamped on the insides of the front lamp. Or on the handlebar stem quill.
Apr 26, 2010 10:47:54 GMT
Cheers, ill have a look later on when I'm home and see what i can find! Quick pic of my bike outside the chippy on Saturday. Mooched around on it with mates drinking beers in the lovely sun, with my lights flickering away as I rode. Pretty awesome. Later on my girlfriend came over so we nipped to the shop for yet more beer, putting her new basket on the President to good use Joe
Last Edit: Apr 26, 2010 10:48:41 GMT by polojoe
redgt2
praise the lowered!
lovin' the raleigh trent tourist...full of win looking like it is
