valman
Mar 15, 2010 23:23:23 GMT
..and we(I) want it to go from this: to this:(stance wise) I want to know if any of you have ever got a midget this low? and is it possible to do this without completely chopping up the chassis the wheel on the right is of a 19" flavour. so that would sit VERY low and if you are wondering why the car is sitting on its front hubs - fell off the scissor jack while I was putting an axle stand underneath it although it did make me see how good one would look that low ;D
Last Edit: Mar 16, 2010 13:04:31 GMT by valman
Seth
Mar 15, 2010 23:33:21 GMT
I don't know how low these sit on the suspension anyway but you could surely loose at least 2" using short springs. Could the inner wishbone pin be relocated upwards at all? Lever arm could surely be moved up a bit to match? Possibly dropped spindles of some sort. Maybe Mini 10" wheels too I think the gauntlet for a proper low MG has been laid down
Mar 15, 2010 23:57:51 GMT
Lol, thats what i like about you lot.. discussing lowering a car thats already lower than anything! I mean, you sit about 6-8" from the road in a standard one (and the ground clearance ain't great) I'll look at ours tomorrow tho.. seeing as the gauntlet is down ;D
Seth
Lol, thats what I like about you lot.. discussing lowering a car thats already lower than anything! I mean, you sit about 6-8" from the road in a standard one (and the ground clearance ain't great) I'll look at ours tomorrow tho.. seeing as the gauntlet is down ;D Heh! I'd quite like to do a "Seth-look" early B GT some day...
Nathan
Club RR Member Number: 1
Lets say we have an MG midget...Nathan
@bgtmidget7476
Club Retro Rides Member 1
That height is about the same as the Racing Midgets have so yes you can do it. Most of them run a Frontline seup but its doable at home.
You can get -1.5" lowering springs on the front and -2" for the back, wiill sit just about there. You exhaust WILL scrub though, both of my midgets (1 standard Rubber bumper height, other lowered) both scrub.
Last Edit: Mar 16, 2010 9:39:02 GMT by Nathan
A friend of mine had one that sat roughly that low, it was on decambered leaf springs, it didnt have lowering blocks but maybe you could add those aswell.
spiny
Wiki Admin
I am abivalent towards car electrics ...
Club RR Member Number: 167
Mar 16, 2010 10:29:57 GMT
you can get lowering blocks for the back and springs for the front - but the floor only has about four inches clearance anyway, plus the exhaust hangs below that, so stupid low would be tricky
markbognor
Club RR Member Number: 56
Mar 16, 2010 10:48:56 GMT
This sounds ace, hope it comes together.
Although not stylistically appropriate could side pipe(s) be an option, or something along the lines of the rally healeys with the exhauset running in a recess in the sill. Or could the exhaust enter the passenger footwell and run through the inside to an exit just in front of the rear wheel, would be easier if the exhaust manifold is on the correct side - I know nothing about A-Series.
Mar 16, 2010 10:49:02 GMT
You can get -1.5" lowering springs on the front and -2" for the back, wiill sit just about there. You exhaust WILL scrub though, both of my midgets (1 standard Rubber bumper height, other lowered) both scrub. For extreme lowering, you could run the exhaust through the car with some heat shielding? Might need to bin the passenger seat though, but then you could go for an old-skool racer style front screen that only covers the driver? Depends how extreme you want to go really!
spiny
Wiki Admin
Mar 16, 2010 11:00:29 GMT
This sounds ace, hope it comes together. Although not stylistically appropriate could side pipe(s) be an option, or something along the lines of the rally healeys with the exhauset running in a recess in the sill. Or could the exhaust enter the passenger footwell and run through the inside to an exit just in front of the rear wheel, would be easier if the exhaust manifold is on the correct side - I know nothing about A-Series. theres not much space in the sill, but two smaller diameter pipes could conceivably fit, then exit into the rear wheel arch and pop over the axle. lots of work though. sill depth reference:
PhoenixCapri
West Midlands
Club RR Member Number: 91
Mar 16, 2010 11:11:01 GMT
Great idea if you ask me, do a write up if you do it, as I'm interested in doing sprite/midget sometime theres not much space in the sill, but two smaller diameter pipes could conceivably fit, then exit into the rear wheel arch and pop over the axle. lots of work though. And I'm not sure it would be that much work given the WIN that it would result in But surely the easiest thing to do would be to add a tunnel next to the transmission tunnel (box in a bit more trans tunnel) and run the pipe down that? Then if my memory of midgets is any good all you'd need to do is notch the seat to make it fit - and obviously invest in lots of heat sheilding to stop you melting the passenger! Or, fit a turbo which will have the lovely effect of removing most of the noise from the exhuast (and give power obviously ) and then just pipe the exhaust out around the A-pilar - instant WIN, and easy to do if you have an A-series lump ;D
valman
Mar 16, 2010 11:13:13 GMT
some good ideas there ;D, I totally forgot about decambered springs :lol: unfortunately I had to sell this one up, due to space being an issue but soon there will be loads of space and I will try buy one for the slam treatment looks over practicality any day for me so scrubbing won't bother me too much - the vw guys manage with it, ill be fine ;D when I was looking at it, while I had it in my posession, I was thinking of notching the front chassis to allow the wishbones to travel further up but would need a home brew front turret set up I think
Last Edit: Mar 16, 2010 13:02:05 GMT by valman
Mar 16, 2010 14:14:56 GMT
Have we all forgotten about Dr. Sexy's Midge of WIN, last seen blasting round the track at RRG? ;D Slammed Midget? Done! He's not updated the thread for aaages (will give him a poke) but iirc it's down about 4' at the front a 3' at the rear (on Mini shocks) with 14's on the rear and 13's up front. His was US-spec (rubber bumper) so had the plates under the rear spring hangers to raise the car 0.5' as standard (now binned, obv.) Re. exhaust issues - you seem to be able to get away with a lot more lowness in a car with such a short wheelbase without too much scrapage. Sexy's Midge probably has a good 0.5" less ground clearance than my Benz yet he can go places I can't.. HC.
Nathan
@bgtmidget7476
Mar 16, 2010 14:30:08 GMT
some good ideas there ;D, I totally forgot about decambered springs :lol: unfortunately I had to sell this one up, due to space being an issue but soon there will be loads of space and I will try buy one for the slam treatment looks over practicality any day for me so scrubbing won't bother me too much - the vw guys manage with it, ill be fine ;D when I was looking at it, while I had it in my posession, I was thinking of notching the front chassis to allow the wishbones to travel further up but would need a home brew front turret set up I think Let me know when your looking for one, I usually have 2 or 3 pass through my hands at any one time which are MOT/Taxed and cheap.
valman
Mar 16, 2010 15:18:19 GMT
some good ideas there ;D, I totally forgot about decambered springs :lol: unfortunately I had to sell this one up, due to space being an issue but soon there will be loads of space and I will try buy one for the slam treatment looks over practicality any day for me so scrubbing won't bother me too much - the vw guys manage with it, ill be fine ;D when I was looking at it, while I had it in my posession, I was thinking of notching the front chassis to allow the wishbones to travel further up but would need a home brew front turret set up I think Let me know when your looking for one, I usually have 2 or 3 pass through my hands at any one time which are MOT/Taxed and cheap. Ace! certainly will, thank you that low midget has made me realise how bloody cheap I got mine for mine had new sills and floors all for a grand total of £215 with a working engine and I sold the whole thing to a chap for about £150 after stripping all the valuables out damn. oh well I shall have another and much lower me thinks
Last Edit: Mar 16, 2010 15:20:17 GMT by valman
valman
lets resurrect this, anyone found/noticed/etc any problems/ideas with this?
also to prevent making a new thread, is it realistic to find a midget for under £1k with an MOT OR not rotten/ (couldnt care about the appearance of it aslong as they are solid)? as ill be in a position to get one soon...
GavinJ
MGB 3.9 v8 Sebring
Club RR Member Number: 209
it's down about 4' at the front a 3' at the rear (on Mini shocks) Holy cow HC...4 & 3 feet lower!!
Your car is not 'epic', this thread is not 'epic'....the OCEAN is epic, the UNIVERSE is epic.... please stop misusing this word!! It would appear Hotrods are the new VWs - aint fashion funny! '69 BUICK LESABRE 350
Seth
That sits well
it's down about 4' at the front a 3' at the rear (on Mini shocks) Holy cow HC...4 & 3 feet lower!! Lol - nice phail! Please accept this comedy mash-up of the Midget in question, the Revo's off my Manta & my old R19 as penance..
