Jan 18, 2012 20:19:15 GMT
The next morning (Sunday) work starts in earnest on the Fiesta. James gets stuck straight in, determined that it'll be running properly before the day is out. The Lotus watches on.... Tiggs had been working away on the rear arches of his E46 Touring in order to try and get these wheels to fit: 8.5x17 on the front and 10x17 on the back. It looked a LOT meaner in the flesh. A LOT!! Got dish? There's a lot more of it at the rear I'm not a massive E46 fan, but even when covered in dirt, this thing looked HAWT! Front is coming down more once the arches have had their final fettling. Front wheel in this shot is the original he'd been running (new wheels only fitted for mocking up purposes until the final arch fettling was all done & dusted) James ditches the electronic dizzy and pulls out the one from the 'Area 52 Fiesta' to use as a donor 'get you home' solution. I bit of soldering to convert it to run on the Hardcore Fiesta loom: Dave prepares some epic microwave Nachos. How did I miss this meal?? The crowds gather around as the smell of Doritos, salsa, cheese, jalapenos and other delights fill the air Remnants of the weekends drinking. Not bad! The true sign of an alcoholic is denial. We do NOT have a drinking problem at the unit.
MiataMark
Club RR Member Number: 29
Jan 18, 2012 21:29:30 GMT
This image is brilliant (what lens is it?) Mark
Jan 18, 2012 22:00:16 GMT
This image is brilliant (what lens is it?) Hi Mark, Many thanks for the comment...the lens was a 24-105 (shot taken at 105mm @ f/4). I was a bit lazy this weekend and all the shots were taken with this lens. It's probably the most versatile lens I've ever used which doesn't help matters. I really ought to try out my 50mm or UWA more often! Last shots from the weekend: James continues to work on the Fiesta Special delivery of the biggest non-4x4 wheels EVAR!! Lotus becomes a handy workbench Electronic dizzy now destined for the bin It's old, it's basic, but it's a proper workhorse and just keeps plodding away. It was my Grandads, then my Dads, so I am very proud to have it in service down at the unit. Sometimes you just can't beat a bit of 'old-tech' The 'donor' dizzy turns out to be more than a little worn out. Fooked I think the term was? Luckily another one was found in the boxes of stuff around the unit. PHEW! All the gear! Timing lights, torches, test meters, socket sets, screwdrivers, spare coils....all utilised to get the Fiesta running. it worked too, James got it running pretty well....and certainly well enough to get Andy & Kara back to Brighton. He's a bit of a c..t whizzkid is James. Area 52 can be scene if we want to: ...actually, maybe we can't... ...but that's a very, very good thing and why I love the place so much. We are what we are. That's enough. So, until the next time. ;D
Jan 18, 2012 22:50:06 GMT
have you not seen the boot of a jaaaag? hahah its blasted hooge. What ya got planned to bring down? Also I'm on earlies that week so will be setting of around 3pm-ish friday (this can be changed though to suit ya) though I need to pop into manchester to pick kev up 2 sets of wheels and a couple of tyres iirc, though there maybe more. I'll find out what's happening and let you know, i'm thinking if I can get down early enough on Friday Bruce might offer to take some epic photos of the Proton for me.
Jan 18, 2012 23:36:38 GMT
The true sign of an alcoholic is denial. I do NOT have a drinking problem at the unit. fixed actually - between 15 ish thats not lots ;D andys pic just make me LOL - hardcore squeezing one out FTW ;D
2001 HONDA CT110 (NOT RCV)
Jan 19, 2012 10:14:04 GMT
What rims are on the bimmer? Not seen those before, keep thinking Z8 but I cant be right.
Looks like fun was had by all.
And love the H&S FTW shot lol
Last Edit: Jan 19, 2012 10:16:24 GMT by joem83
rob0r
East of England
Club RR Member Number: 104
Jan 19, 2012 10:28:27 GMT
Hamann HM1, looking great on the E46
E30 320i 3.5 - E23 730 - E3 3.0si - E21 316 M42 - E32 750i ETC
rtlkyuubi
Low and Slow
Jan 19, 2012 11:06:01 GMT
have you not seen the boot of a jaaaag? hahah its blasted hooge. What ya got planned to bring down? Also I'm on earlies that week so will be setting of around 3pm-ish friday (this can be changed though to suit ya) though I need to pop into manchester to pick kev up 2 sets of wheels and a couple of tyres iirc, though there maybe more. I'll find out what's happening and let you know, i'm thinking if I can get down early enough on Friday Bruce might offer to take some epic photos of the Proton for me. Haha that is a fair bit of stuff. If your coming down too then we can convoy
Jan 19, 2012 11:17:06 GMT
Nah you won't keep up Matt
Jan 19, 2012 14:18:32 GMT
The 'donor' dizzy turns out to be more than a little worn out. Fooked I think the term was? Luckily another one was found in the boxes of stuff around the unit. PHEW! Fooked is the polite way of describing that Motorcraft dizzy. The ignition timing was randomly altering between about 30 degrees before TDC and about 10 after - at idle - because of the play in the shaft for the points cam. That, combined with the broken condensor, might go some way to explaining why that other Fiesta woudn't drive. The Bosch dizzy from the shelf had next to no play, and timed in perfectly - it transformed the running of the car. All the gear! Timing lights, torches, test meters, socket sets, screwdrivers, spare coils....all utilised to get the Fiesta running. it worked too, James got it running pretty well....and certainly well enough to get Andy & Kara back to Brighton. He's a bit of a c..t whizzkid is James. And yes, I always work like this. I could get most things done twice as quickly if I wasn't always looking for the tool I had in my hand 20 seconds previously.
Jan 19, 2012 14:24:12 GMT
And yes, I always work like this. I could get most things done twice as quickly if I wasn't always looking for the tool I had in my hand 20 seconds previously. Very important in maintaining that very well earnt and much deserved status. ;D
Jan 19, 2012 15:03:55 GMT
Interjection: I would be very very interested in these wheels if they are available at a sensible price, assuming 5x4.5" Ford/Mopar. PM me if so. I would be happy with a pair, as I have a pair here...
rtlkyuubi
Low and Slow
Jan 19, 2012 15:15:39 GMT
Nah you won't keep up Matt Ive had it up to 140 with more to go but then i looked at the fuel gauge
Jan 19, 2012 15:49:37 GMT
Interjection: I would be very very interested in these wheels if they are available at a sensible price, assuming 5x4.5" Ford/Mopar. PM me if so. Hi Alistair, they were dropped off at the unit in December as part of the Pony Express journey to the infamous car/wheel collector Mr Bickle. I am sure if you were to PM him he'd be able to tell you what their planned role is and if they are indeed for sale or not. Sorry I can't be of any more help. I was simply the 'middle man' storage facility in their journey across country.
Jan 19, 2012 15:50:30 GMT
Haha was only messing. I don't tend to go much above 110mph in it, mostly because the roads I go ragging on don't have enough space to get to that sort of speed.
We'll sort out a setting off times etc nearer the time.
actually - between 15 ish thats not lots ;D It was the soberest play weekend I've been to. That might just be me though...
Lacy
Wish I lived nearer to you.....
I love this thread and your awesome workshop/communicty centre/asylum......also love your photography and the effective way you play with depth of field.
Awesome stuff.
2007 Porsche 987 Boxster S 'Percy' 1994 Landrover 300tdi 90 CSW 'Connie' 2001 Buell M2 'Bertie' 1976 Kawasaki Z1000 A1 'Nobby' ....and my wife has some nondescript modern box of some sort
Jan 20, 2012 10:06:10 GMT
Sorry I can't be of any more help. On the contrary, that was helpful.
benzine
Club RR Member Number: 87
Jan 20, 2012 11:51:42 GMT
awesome thread, I love reading updates and the photos are sweet
Jan 20, 2012 18:51:24 GMT
Seriously wicked reports/write-ups/photos/stories/videos guys Love it It makes me wonder if some of you were once in the abandoned mental hospital I spent the weekend wandering around ;D ;D
