Stu
Jan 23, 2006 12:12:26 GMT
Hi All, Well, after spending about 3 years reading up, tinkering and generally working out how K-jet fuel injection works I have gone and bought myself a car with good old fashioned twin carbs - back to square one! Bascially it's a Mk1 Golf 1500cc with twin Dellorto 40's on it. I can get it running ok from cold but only by putting my hands over the trumpets (is that what they're called) to restrict the air a bit and act like a choke. There is no manual or auto choke fitted so cold running is a bit rough, and pretty rich by the smell of it. This is a pic of the carbs: Am I right in thinking if I make a little linkage to connect up the two spring loaded levers in the top middle of each carb to each other, and then hook that up to a cable I will have a manual choke mechanism? I have worked out how to lower the idle speed so far and it runs good when warm but my knowledge of carbs is pretty basic. Anyone got any tips or good links for info? I know some people don't bother with the cold start mechanism and just pump the throttle a bit before starting but I'd like to get it all set up properly and make use of the choke for cold starts if it's possible. Much appreciated. Incidentally, the noise they make is far better than K-jet! Stu
Last Edit: Jan 25, 2006 20:08:52 GMT by Stu
Nathan
Club RR Member Number: 1
Jan 23, 2006 12:19:09 GMT
I thought about this when i got my Weber 45. but I don't use the car often so i just let her tick over on her own on the drive for a while before use. your idea sounds good and easy enough
SidewaysGTM
Spending my time at the Race track, Pub or in an Engine
Jan 23, 2006 12:21:56 GMT
Am I right in thinking if I make a little linkage to connect up the two spring loaded levers in the top middle of each carb to each other, and then hook that up to a cable I will have a manual choke mechanism? From memory that is the choke mech, havnt played with twin webers for a while but think that is it, you gotta love the sound of those bad boys, and yes calling them trumpets is the right term., for changing mixture on these bad boys you need different jets for, idle, main , emulsion tubes, accel? and you can even change the venturi size, a very tunable carb WEST
Live life sideways, Honda Powered GTM Coupe, you better belive it GTM Coupe VTEC Constant progression and acceleration 67' Triumph Vitesse 2ltr [finally decided what to do with it, at the planning stage] 92' Mini nearly std [SOLD and Missed] GTM ownersclub forum
Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
Jan 23, 2006 12:54:03 GMT
Hi My 104ZS has twin dellortos and a fully functional manual choke. If you want I can take some pictures of the linkage and attachment details for you to copy. It will be this evening though as the cars at home. It works very well. car has never failed to start no matter how cold/long its left. Here's a bad pic to be going on with basically that's the choke cable running across the top. The throttle linkage is between the carbs
This space available to rent. Reach literally dozens of people. Cheap rates!
Stu
Jan 23, 2006 13:16:05 GMT
104ZS - more pics would be very helpful but even from that pic I can see how the choke cable works. I take it you just set it up so when the two choke levers are fully sprung back the choke knob is pushed right in against it's stop on the dash?
Do you need a choke knob that you can turn to lock in position as presumably otherwise the return springs on the carbs will keep springing back?
Thanks for the info so far everyone. I feel like I have really got into 'retro' motoring buying a car with dirty great carbs on it! ;D
Shortcut
Jan 23, 2006 14:03:58 GMT
Yes, what you said. I fitted a choke knob under the dash. Luckily older 104s had a manual choke so it went there. It turns and locks into position. easy peasy
Will take a few pics theis evening
You'll love the noise. Great gobs of induction roar. Sounds much better than just lobbing a 36" back box on a la Paxo stylee! Get them set up properly and they sound great at full chat as they rasp and blow, just like an old style rally car.
The bonkers thing about my set up is that for no apparent reason Peugeot cast the manifold flanges upside down so if you bolt the carbs straight on they'd be the wrong way up, so the vibration damping rubbers reverse the mounting to bring the carbs the right way up, which means you can't use off the shelf rubbers and you can't get the Pug ones any more!!
Last Edit: Jan 23, 2006 14:08:30 GMT by Shortcut
Jan 23, 2006 14:24:34 GMT
You'll love the noise. Great gobs of induction roar. Sounds much better than just lobbing a 36" back box on a la Paxo stylee! Get them set up properly and they sound great at full chat as they rasp and blow, just like an old style rally car. Agreed! If you've got a stereo fitted in the car,throw it away,you wont need it! The k-jet system was the worst thing about my old manta gte.Nothing but trouble with it. If i'dve kept it,carbs would've been thrown on for definate. Give me carbs any day.
Jan 23, 2006 17:03:52 GMT
yeah, its known as a 'cold starting device' not a choke, i have mine on my escort, although its a bit simpler to wire up with one carb
Jan 23, 2006 17:07:22 GMT
as for carbs being better................yes, i agree, on a nice warm sunny day, and your rich enough to pay for the fuel to boot. my 1.6 crossflow (86 horses) averages 15-20 mpg round town, and in the single figures if i boot it ;D ;D, and days like today the carb freezes over to make being stuck in traffic a rather pleasant experience indeed. I'm going for some bosch l-jetronic on the pinto I'm putting in
Stu
Jan 24, 2006 12:18:06 GMT
I agree with SeventyNine, carbs are good for weekend cars but I will be sticking with K-jet on my everyday Golf. It does about 30 - 35mpg however you drive it, starts warm or cold and goes pretty well (Audi 2L 16v engine), sounds alright but not quite as good as the Mk1 on carbs obviously.
SteB
Jan 24, 2006 12:48:55 GMT
How is the mk1 with fuel economy, a mate has a 1500 Automatic Jetta which does about 15 mpg tops because of the autobox. And with yours having carbs as well....
Stu
Jan 24, 2006 13:20:21 GMT
How is the mk1 with fuel economy, a mate has a 1500 Automatic Jetta which does about 15 mpg tops because of the autobox. And with yours having carbs as well.... Ste - Don't know yet as it's not roadworthy yet but from what you've said I expect it'll be a little thirsty! On the plus side though, it sounds like a big yank V8 or something when you rev it! ;D I would hope for something like mid 20's mpg when it's properly set up... if not I'm going to have to fit original style skinny wheels to reduce drag...!
SteB
Jan 24, 2006 15:00:51 GMT
Booo!hisss!! etc
Continental EcoContacts if you do, they're good for a couple of MPG
Stu
Jan 25, 2006 20:08:17 GMT
Don't worry, not about to change anything unless the car is hideously un-economical! ;D
Shortcut
Jan 26, 2006 10:11:17 GMT
Stu- soz, hadn't forgotten, been working from Dawn til Dusk. Will photo carbs at the w/end
Stu
Jan 26, 2006 12:03:28 GMT
Stu- soz, hadn't forgotten, been working from Dawn til Dusk. Will photo carbs at the w/end No problem, thanks for your help. I will hopefully get some work done on the car this weekend, should wake the neighbours up...!
Shortcut
Jan 29, 2006 11:17:07 GMT
Stu
Jan 29, 2006 19:50:39 GMT
104zs - That's brilliant, thanks so much for the pics - I will do mine just the same. I have found a manual choke cable in a box of bits at my Dad's, it's off a Bedford CF I think but it's long enough so should do the job. I've routed it through the bulkhead and just left it hanging under the dash for now, not connected to the carbs yet either, will sort it soon though.
Jan 30, 2006 20:01:49 GMT
Yup, that's exactly the same way the 'enrichment' thingies are set up on my engine. Don't want to be a killjoy here, but are you guys running without filters all the time?
Stu
Jan 30, 2006 20:22:27 GMT
Don't want to be a killjoy here, but are you guys running without filters all the time? I was wondering about filters, I think it'd be best to fit some kind of filter (only just bought the car and not got it on the road yet) - any ideas?
