Model: VW Golf GTI 16v
Year: 1991
Mileage: 170000
Tax: 3 months
MOT: 10 months
Price: £1650
Additional Information:
1991 Golf GTI 16v, 5dr, Oak Green, Full runout spec, including PAS, EW, EM, Sunroof, BBS Alloys, Rear Head Rests, Rainbow Interior, top tint windscreen, etc etc Also has the very rare benefit of factory fitted Aircon, in FULLY WORKING condition.
Ok, this was meant to be my weekend fun car, but a year later and I've put 12k miles on it - eek! It's just getting used too much and even though it's been completely reliable, I need something cheaper to run. The car has been built up to a great spec by the previous owner, comprising:
Engine / Gearbox:
Brakes / Chassis:
The car is lovely and torquey in normal driving, and really takes off above 4500rpm. Plus, you don't have the issue of a horrible idle due to lumpy cams etc.
Other bits include smoked indicator lenses, Duo Styling Oil pressure, Temp, Volts guages, Autostadt numberplate holders, Thatcham Cat 1 Cobra Alarm with RCL, Both original keys with torch & 16v covers
In the 12 months I've owned the car, it's had the following:
Bad Points:
Not too many for 19 years old...has the usual 2nd gear crunch when cold (had it when I bought it and 12k miles later it's no worse - behaves fully once warm), driver's seat bolster worn (not awful), needs ARB link soon and new exhaust rubbers (MOT advisories)
I really am gutted to have to sell this, it's such a good car, and it's in the best spec and colour. It has every old MOT and an entire folder full of history and reciepts plus a full build diary from the engine convsersion. Needless to say, I'm not letting this go for peanuts - I don't care if your mate bought one for a grand, so please don't waste your time telling me! Please PM me if any more info is needed.
![](http://pic100.picturetrail.com/VOL769/2849786/21984210/363356782.jpg/bmi_orig_img/363356782.jpg)
![](http://pic100.picturetrail.com/VOL769/2849786/21984210/363356763.jpg/bmi_orig_img/363356763.jpg)
![](http://pic100.picturetrail.com/VOL769/2849786/21984210/363356711.jpg/bmi_orig_img/363356711.jpg)
![](http://pic100.picturetrail.com/VOL769/2849786/21984210/363356757.jpg/bmi_orig_img/363356757.jpg)
![](http://img.photobucket.com/albums/v648/Beesley/16v/gauges2.jpg/bmi_orig_img/gauges2.jpg)
Guages & AC controls
![](http://img.photobucket.com/albums/v648/Beesley/16v/flywheel_2.jpg/bmi_orig_img/flywheel_2.jpg)
Flywheel vs standard
![](http://img.photobucket.com/albums/v648/Beesley/16v/oilcooler6.jpg/bmi_orig_img/oilcooler6.jpg)
Oil Cooler
Year: 1991
Mileage: 170000
Tax: 3 months
MOT: 10 months
Price: £1650
Engine / Gearbox:
- Audi 6A 2 litre bottom end (90k when fitted)
- Crissel ('Man in the Shed') worked cylinder head and ported matched cast exhaust manifold (more reliable than a four branch) - ££££!
- Lightened flywheel (by CGTI's 'Hotgolf'), new clutch when flywheel was fitted
- Baffled sump
- All new engine mounts (solid front), belts, gaskets, tensioners, tappets, cam chain, nuts and bolts etc when engine / head went in a few years ago
- WUR modified as per Stealth’s spec, ignition timing set to factory 6 degrees BTDC, always run on super unleaded.
- Large Mocal oil cooler fitted with thermostatic sandwich plate.
- Weighted shift rod
- Recently reconditioned original 90amp alternator
- Power steering
- Correct semi synthetic oil & genuine filter changed every 6k miles
- Not been RR'd since head fitting but estimate 170 bhp / 150lbsft, very quick, smooth and useable with excellent economy and reliability.
- Revs very freely to over 7k rpm and will pull strongly in 5th from 30 - 130mph (on the autobahn!) No problem keeping up with (or leaving behind) most modern hot hatches.
Brakes / Chassis:
- 280mm front brakes - Brembo plain discs, Pagid FR pads
- Mk3 rear calipers (no sticky handbrake)
- Goodridge braided lines with ATE ‘Superblue’ fluid – no brake fade
- Eibach lowering springs, approximately 40mm drop – firm and good handling but not too harsh for daily use.
- 4 x Yokahama Tyres
- BBS's professionally refurbed with the rim polished
- 2 good 2nd hand nearside doors fitted (originals scabby) and full side of the car professionally painted and blended (cost over £800)
- Grille spoiler fitted & professionally painted
- New radiator
- New radiator fan & CV boot (2 weeks ago - cost £377!)
- New Aircon Condensor (cost over £340!)
- Full Sebring twin rounded square exhaust (2 box system so no louder than standard)
- Full service
Bad Points:
Oil Cooler
