I'm rammed to the roof again here, with more stuff coming, so yet again I need to clear out some of the stuff I'm not currently using.....
ITEMS WILL BE DELETED FROM THIS POST AS THEY ARE SOLD
first, some tyres.
1. a matched set of 4 almost brand new (8mm+) nankang NS2, size 165/40r16. I bought these to go on my passat but they do silly things to the gear ratios would be ideally suited to something like a polp or lupo, than ran full profile 155s as stock,as they're the same rolling radius
pics to follow.....they really are as new!!
£120 or will trade for 195/45r16.
2. cheap curse word pair of 205/60R13, on the limiters. some form of comedy cheap brand. will get you rolling, or a days worth of skids. £10
4. pair of 6.70x15 tigar crossplies. good condition, deep tread, still pliable £35.
5. pre 67 bug rear valance. small cutout in centre at bottom for some reason- header clearance? otherwise new. £15
6. nissan fendermount mirrors. these were NOS when I got them, ran them on a car for about 2 months, so they're pretty much perfect condition. (the brown/yellow stuff on the baseplates is grease I lathered over them to stop them corroding) £50.
7.sierra sapphire rear drums. good usable condition, no lip, normal surface rust, £10
8. mk3 golf debaged grille. unpainted, looks brand new but a couple of the clips are damaged, but it stays on fine (i didnt knwo they're were damaged til it was removed) £20
9. mk3 golf rear lowering springs, jamex. part no. 85 3314rear. biggest drop they do, 60 or 80mm I think? £20
11. brand new VAG radiator. valeo brand. fits mk5 golf/jetta with the 2.5L motor. never fitted, a few storage marks on one side, loads of mounting points on both sides and the ends, so easily adaptable to your application. inlet and outlet both on LHS. £30.
12. pinto HT leads. set of 5. orange, 7mm silicone. good clean usable condition, no damage. £10
13. couple of bosch blue coils, with brackets. may have minor dents, but work fine. £5 each.
14. random assortment of stacklight merc (w114/w115) bits. a load of black interior trim parts. armrests are for rear doors. other bits will fit any door. 2 sets of vgc original wipers, one set of vgc original blades (so they're the right colour), and a minto set of headlamp rims (if you own one of these cars you know what they're usually like!)
tenner for all the door bits
tenner for all the wipers
20 quid for the headlamp rims.
15. more stacklight stuff-
black underdash card for passenger side (i think, will check) the always-broken front footwell plastic section, also in black, and the centre console mat, in black too.
16. a rather special set of w114/w115 merc headlights. no only are they perfect hella lenses, perfect chrome rims, and perfect bodies with good reflectors, they're angel eye lamps too! (will connect up later to get a pic of them on). proper H4 beam units which I fitted to the original brackets, so they adjust in the stock manner. £50 (the angel eye units cost that alone)
21. mk1 mondeo genuine factory RS overbumpers. front has fogs and grille in vgc. they simply bond on over your existing bumpers, and have a few screws and clips for extra security (included) a few scruffs from storage, and a kerb srape on the bottom corner of the front one, will easily paint over. £50.
22. RHS rear corner for a vw splitscreen van. good cond all way up to gutter, bottom gone below light, has edges/lips but are a bit rough so id just view it as a new corner skin- good if yours is stoved in as I don't think you can get a repair panel for anywhere higher up than the light hole. £30.
26. a framed set of ferrari collectors cards, full series of 6. farraris aint my thing. £10
27. pre-67 beetle inner door handles. one slightly better set (very minor tarnishing) with ivory escutcheons £10 set of 4. other slightly more tarnished set, still perfectly presentable, without escutcheons £5.
28. lucas round lenses, lots of!
all the ones in the first pic are plastic, 2 screw fitment. some new, rest vgc used. £5pair. oddments down the side couple of quid each.
second pic all glass except the 6 to the right. push-in fit. got about 6x sets of good trim rings. prices £5-15 a pair depending on which ones, and with or with trim rings. plastic ones to right £5/pr. just let me know what you want.
30. used late beetle door handle with key, £5.
31.grayston tow assisters, pair of. brand new £10.
32. all these bits are commer PB van. fulls et of inner handles with black escutions and pins, tarnished but polish up easily. good ign/ switch with keys. £15 the lot.
33. split van cab window latch. LHS(i think). has seal, but no centre bolt. minor tarnishing, ok condition id say. £5.
34. all of these are from a '60 chevy impala. I found the other winder after I took the pic. quite pitted, but better than not having any!. fit most other 60s chevy. £10 lot.
35. assorted VW window winders, 70s-80s. point to what you want, £2 each for a complete one.
36. chrome beetle pancake air filter. small dent it top otherwise good clean condition. £5.
37. pair of DMs. more or less brand new just really dusty from being on the shelf. yeah theyve been sat on that shelf a while. worn a couple of times by my dad before he got some riggers instead (Too lazy for laces!). he then gave em to me when I'm a 11 and hes a 9 so size is UK9. protect your feet in the garage!! £15.
39. mk1 mondeo radiator with fan/etc. from a 2L zetec model. ally with nice big fan on the back. measurements on request. £20.
40.vw beetle oil pump, BNIB, never opened. late deep type (32mm?) for late type cam. £20.
41. genuine hella RHD splitscreen van headlamp lens- RARE! vgc no damage or anything. £25.
42. hot rod/ vintage door handles. very similar to model A, but they're not. fit the same though. standard 30s bolt hole spacing and square bar down the centre. keyless( for seperate locks) chrome pretty good, some marks but presentable. some paint on it though needs cleaning off. £25.
pair of GT cupline inserts. not 100% sure of application, but part no is GT 52 VW 003 F, which with my previous experience of their part number system, means they're mk3 golf fronts. I got them fitted (terribly) to something else though, so very adaptable to other uses. they seem to be pretty much new. measurements on request if youre wanting to adapt them to summat else. £35
48. pair of 14"x7" widened steels, 4x114.3mm, et0. 185/65 tyres on them. good 86 skid rims, £60pr.
50. pair of allycats centre caps. a few scuffs but perfectly usable. do not fit ford pattern ones the centre spigot is bigger, mini ones only. £10pr.
52.
hornpush/steering wheel centre for porsche 928 and 944 S2 steering wheel. black. £10
54. plastic '32 ford grille shell. has had about 3" cut out of each side to section it at some point in the past, but the bits are still there, so ive zip tied em together so they don't get lost- will easily glass back together. has been trimmed to fit an A chassis. has been painted terribly in satin black, has 2 badge holes drilled at top. £20
56. e93a/103e pop f+r springs and crossmembers. rear can be used as a front on an A as they're near as dammit the same dimensions
front spring is blasted and primed, everything else is greasy and dirty. all good condition.
£30 front pair £40 rear pair.
57. a complete '60 chevy impala front bumper. suits '58-'60 (i think). good strainght condition, not a dent or bend on it, but the chromes long gone. good for your kustom project maybe? has brackets in good condition. I think the extra 2 brackets are for a rear bumper. £50.
58. volvo 740 front chin spoiler. has had top lip trimmed to fit to another bumper, and the rear vents cut down, but still has all the mounting points for it to bolt up. has towing eye blank too. look cool fitted to other stuff(i had it on a nissan 300C) £15. measurements on req.
59. a unidentified steel dash. best guess is mid-thirties hillman, with it being 3 oval shapes. the 2 outer holes are just cubbyholes- no holes drilled in them. 37" wide, screws to a flat frame, heavyweight steel nearly 2mm think. ideal for an A or T modifed. £50
60. complete beam setup from a '40s ford e83w truck.
its basically the same axle as a stock model A, so a 'heavy' axle, but 5" narrower so a good setup for a smaller rod- T modified, etc.
it has the stock spring in good condition, stock unsplit wishbone in good, undamaged condition with undamaged brake linkage, stock brakes with good cables, unbent trackrod, good steering arms and trackrod ends etc.etc.
very small amount of kingpin play- less than 1mm. I expect this would disappear with a good dose of grease.
plus a pair of 17" wide 5 ford steels with shagged tyres that are rock hard.
the spindles take pop brakes and hubs, so can easily be converted to 4x108 discs, or you can mod the backplates to accept VW wheel cylinders to keep the trad drums.
only bits missing are the shackles and perch pins, but they're both the same as model A, not pop = cheap.
some base measurements-
axle depth 2-1/4"
31-1/2" perch to perch
45-1/2" kingpin to kingpin
1-3/4" wide spring, 30-3/4" eye to eye
bones would measure 29" if cut, then plus your bungs and ends obviously.
£200 the lot.
more to come soon folks!
pic of items not piccied on request.
all items in manningtree near colchester.
can post no problem.
yes, I take paypal.
can post pretty much any item for £8, less for smaller stuff.
PM, ddmetalworks@hotmail.com or 07813289931 to get in touch with me......
first, some tyres.
52.
axle depth 2-1/4"
£200 the lot.
yes, I take paypal.
