bozo
Kinda New
Hey guys, hello to all of you. I am a new member from Zagreb, Croatia, and a proud owner of DAF 44, year 1966. The car is in great condition, but for one part: inlet manifold has corroded and is no more. Since it is made from some kind of aluminum it can not be mended (I tried). Since the car can not run without it, and I can not find it anywhere in Croatia, I need help: can you tell me the web site, or a phone number, or any contact information from a car-parts dealer who has parts for DAF?
Thanks. Bozo
1973 DAF 44 pauldaf44
@GUEST
Hey guys, hello to all of you. I am a new member from Zagreb, Croatia, and a proud owner of DAF 44, year 1966. The car is in great condition, but for one part: inlet manifold has corroded and is no more. Since it is made from some kind of aluminum it can not be mended (I tried). Since the car can not run without it, and I can not find it anywhere in Croatia, I need help: can you tell me the web site, or a phone number, or any contact information from a car-parts dealer who has parts for DAF? Thanks. Bozo Hi mate yes I can help you. If you speak to Danny in Holland he can provide most parts. The website is and it is in both english and dutch. dafhobby.nl/pages/44pag.htmlOn the front of the manifold most British 2 cylinder DAFs have that problem. Is the fault with 2 small pipes one goes to the exhaust main silencer and the other too the left hand heat exchanger. If these are the problem. Slightly retard the timing and blank of the pipes. The car will run without them but will have a flat spot when pulling away and use a bit more fuel. Being a 1966 model makes it a Mk1 so be sure to mention that as some parts are different to the later models. That also makes it a very rare car. I know of only one in the UK. A few things to check does it have script daf badges mounted on the bonnet. A 2 spoke steering wheel, Small headlights concave not convex, and is it 6V. If its all of these things it likely is a mK 1. The reason I say this is because the 44 model was introduced in 1967, and their is a common misconseption about the 1966 on the chassis plate. This actually confirms that the car complies with the 1966 British seat belt standard. Also have a look here dafcars.proboards.comthat is the daf owners club forum which is fairly active and has a good knowledge base. Lastly can we see some pictures please ;D Paul
@GUEST
Forgot to put This is the inlet manifold. The hotspot pipes are the 2 closest to the middle. This pic came from Danny at daf hobby who advertises having them. Beware though it will not be cheap as this is a rare part.
stefan
If it isn't broken fix it till it is
It is a rare part with hot spot pipes we do not have any up in derbyshire, plenty without hot spot pipes though. None of our cars have hot spot pipes.
POWER IS EVERYTHING WITHOUT CONTROL
1985 Honda jazz 1997 Saab 93 convertible 2010 transit 280
bozo
Kinda New
thanks a lot guys for the info. that's what I need: with the hot spot pipes. And I did make a mistake, the car is 1968...don't know how I came up with it being the year 66?? I will send an e-mail to Danny and see how it goes. I know it will not be cheap, but since that's the only thing that's not working on the car, it would be a shame not to have it. And I'll try to put some pictures of the car, it's just that I'm in over my head with work and the car is in garage that's a few km from my house, but I will try to put some pictures till the end of the week Bozo
@GUEST
Jul 31, 2010 18:57:42 GMT
Gladys now has 2 shiny new brake cylinders fitted. The system has been thourighly bled and I am pleased to report that the pedal is good and firm, although has a bit more travel than I would like.
A few things noted that will need attention and a couple of new parts needed.
1. Passenger side rear drum is a bit scored and as a result I would quite like to change it before the next lot of shoes.
2. Passenger side rear backplate has a seized adjuster that just wont free up no matter how hard I try. This produced much swearing when trying to refit the lower spring of the shoes, as I couldn't fully back off one adjuster. I think its gonna need a new one.
3. Drivers side front adjuster have seized and the head of the lower adjuster has sheared. I have some reccon front back plated that I will fit to solve that problem Tomorrow.
The above I think explains the long pedal travel. It does however stop perfectly adequoutely and straight and true . Brake efficiency is back within MOT requirements and at long last I now have a driveable car.
Can anybody help me with rear back plate and brake drum, both of which I can collect at the essex extravaganza if so desired or the RR Gathering
@GUEST
Sept 13, 2010 16:06:06 GMT
I thought car life had been unaturally easy the past few weeks Gladys has decided to change that!!
I took a 50 mile trip out in her today where she stalled at every roundabout, cut out at 20mph and when braking to a stop down hill there was a distinct rattle and judder through the steering wheel. This didn't happen every time but once in a trip is enough to make me wonder whats going on. It felt like the front wheel was going to come off! Does anyone have any ideas as to what would cause this on one occasion and be fine the next 5 times. I stopped as soon as it happened and had a look but couldn't see anything obviously wrong with the suspension system or steering.
The first two are just annoying and will probably sort by resetting points gap, timing and mixture as the tickover has slowed as well. The last a little worrying.
Paul
@GUEST
Well looky what ive been doing. Ive taken the engine out seriously cleaned it. Replaced the flywheel and clutch main housing bearings. Its now turns lovely and smoothly. Then I stripped the front and replaced the crankcase oil seal. Whilst the engine was out I set the valve clearances and generally tidied her up. Gladys is now back together again and drove home. The new clutch bearing has made a world of difference it no longer groans at idle is noticably smoother on the road and feels like it has more power. One slight side as I pulled away the oil pressure light came on. Only because I forgot to connect it and it has a distinctive jingling at certain revs so something must be loose. Oh and did I say locating the engine and doing up that big bar at the front is a right pain in the !! and takes a lot of carefull jacking to align. it aint easy to connect it on a 44 . But having a 2 post lift 4 people and a ten ton engine crane does help I had to align the prop it engaged but didn't go all the way up the splines. as the spring at the back was compressed. The way to solve it was stick it up in the air, use a rubber mallet and then start her up and run her with the wheels off the ground that sorted it. Oh I also noticed my belt dimensions. Left hand 36mm right hand 31mm me thinks its time to put those new ones on. Thats next weeks job then Have a picture of a poorly Gladys sorry its the only one I remembered to take and is how she looked first thing this morning one last thing refitting a forward hinged bonnet singlehandidly is somewhat difficult ;D
@GUEST
Oh great DAF gurus I have a persistant and very annoying problem that I would really like to sort out. It by no means makes the car undriveable but is insanely annoying especially as shes been doing it on and off for the best part of a year I will try and give as much detail as I can 1. When you start her in the morning she starts on the button but needs max choke, I cannot however get the choke in fast enough to get her to not splutter to a stop again almost straight away. 2. On the second start she will run but its a case of having one hand on the hand brake and the other on the key. As soon as she starts you gotta go or she stops again. 3. She will stall at every junction and hesitate and splutter everytime she goes anywhere near tickover untill she is fully warmed up. 4. Once she is warm she will idle but hesitates and stutters when you pull away sometimes backfiring and shooting flames out of the airfilter. Once she is over this she pulls very nicely and has plenty of power. 5. When warm the idle is erractic and is noticeably lower when first stopped than it is if you stop and blip the throttle gently. My thoughts and I haven't done them yet are to change the airfilter and recheck timing and mixture, however it is not very long since they were last set. Other than that I'm thinking perhaps replace the inlet manifold for one that has hotspot pipes but I'm hoping to avoid such drastic measures if possible. Help me please before I loose my temper and slam her on her backside and fit huge wheels and massive bodykit as punishment ;D Paul. p.s. when she is doing her stuttering she has about 3 bhp and will not pull away on any slight gradient which as I'm sure you can imagine is very annoying
Sounds a LOT like ignition to me - especially with the backfiring, and stalling at junctions.
IMO, your ignition timing is too retarded - by maybe 5 degrees.
Was there any improvement last time you set the timing, followed by a deterioration? If so, it seems likely that the points are closing up.
Start by setting the points - preferably use a dwell meter rather than feeler guages, but feelers will work if you don't have a dwell meter.
Then turn the engine to the position where no.1 cylinder should be firing. If the static timing is, say, 5 degrees before top dead centre, turn the engine to 5 degrees BTDC. Connect a spark plug to no.1 plug lead, and let it rest on the cylinder block. Loosen the dizzy clamp. Turn the ignition on. Turn the dizzy in the direction of rotation to make sure the points are closed, and then turn it against the direction of rotation until the plug fires. Tighten the dizzy clamp. Test drive.
It might, possibly, be fuelling - it could be something like a blocked idle jet - but change ONE thing at a time, so that you know what the effect of changin that thing is. That way, if you do get it right, you can replicate that setting fairly easily.
@GUEST
Jan 15, 2011 12:21:56 GMT
I have an unhappy DAF. Took it for a short spin this morning and it was a pig to start. Actually had to remove the airfilter to make it fire. It then ran like a bag of nails, missfiring and spluttering and continually stalling. Got it home had a play and found a few things.
Carter valve is as dead as dead can be. Its offset theres a massive gap and it had actually blown out of its holder.
Spark is good but theres play in the dizzy. Throttle wont go home even with the cable slack and there doesn't appear to be anything jamming the linkage.
Now it will not start at all. Doesn't even cough but stinks of petrol. I think the timing and mixture are probably both to blame as the points are good theres plenty of fuel, compression and a strong spark.
Paul
@GUEST
Been tinkering today. Replaced a brake drum back plate and did a simple adjustment So in proper Spunkymonkey of the DAF forum fashion here is a detailed how to. First remove the hubcap for this a flat head screwdriver with a decent length shaft is ideal then slacken off the wheel nuts with a suitable breaker bar Now jack the car up. I have used the factory jacking point as I know its strong. If you are not sure use the subframe. Now remove the wheel completly. I like to use a half inch ratchet to quickly wind the nuts off For safety it is a good idea to use an axle stand. Where mine is put is a good strong location and the stand is unlikely to slip under heavy torques Now thats is done. Place a 17mm socket onto the adjuster nut, a 3/8 drive is ideal for this. Turn the adjuster untill the hub locks and back it off so that the hub just starts too turn. Repeat this for the other adjuster Thats your brakes adjusted. Refit the wheel and do the nuts up finger tight. This is done so that the wheel goes on squarely. Lower the car back to the ground and tighten the wheel nuts properly. This being a 3 stud wheel it doesn't really matter which order you torque up. On most wheels remember to torque across the wheel. Then refit the hubcap and move on to the next wheel. If like me you find that the adjusters wont turn on the next wheel you may need to follow these steps. first remove the little circlip and withdraw the grease cap. Use a 24mm socket to undo the nut that holds the wheel on. Now withdraw the brake drum be carefull not to lose the bearing and retainer or to get them dirty. They will pop out as you remove the drum. This is the front wheel bearing which you may as well inspect and replace if worn. With the drum off you now need to disconnect the brake line. Undo this union and remove the flexi from the back of the cylinder. If you just try to undo the flexi you will collapse the pipe as it twists. Now you need to dissasemble the brakes. So that it goes from this to this The 4 bolts in the centre need to be undone and then the back plate can be removed. There is a nut on the back that you need to hold otherwise your bolt will just spin. Once your done it should look like this. I cleaned that up as I don't like rust! If like me your nuts wont turn despite copious ammounts of penertrating fluid and heat you may need to use one of these on the nut. You place it around the nut with the blade in the middle of a flat face and then tighten till the nut splits in half. Of course you will now need new nuts and bolts. Now that the back plate is off you need to swap the slave cylinder onto the new plate. There are 2 10mm bolts holding it on. Now bolt the new plate onto the hub. You now need to reassemble the brakes and fit the drum. This is where taking a photo of how it looked before is handy if you are unsure. don't forget to smear the stub shaft with plenty of grease. Now take the bearing and retainer and press them in. It must go in the right way around or the wheel will lock! This photo shows what it will look like if its the wrong way around With the bearing the right way around it will press in flush with the drum. Then screw the 24mm hub nut back on tight but not too tight. tap in the grease cap and refit the circlip. Now you can adjust the brakes up as before Now refit the wheel as before and bleed the brakes and enjoy having a nice firm pedal again. Hope you liked the report Paul
1973 DAF 44 automatic
@GUEST
Apr 13, 2011 16:04:29 GMT
Gladys has had some more attention today. You may remember last year I skinned some fibreglass over a rust hole as a temp fix. Well today that was removed cut back to nice sound metal and a patch welded in. Shield your eyes it aint pretty and is going to take some hiding with the filler. Must learn to weld better!! as you can see the rot extended quite a long way back. I will mask that repair with a thin layer of filler tomorrow. Meanwhile I had noticed that there was a crack appearing at the bottom of the passenger wing. This made me think FILLER oh yes it was. All of that was dug and sanded out making the workshop resemble the arctic. leaving a sizeable hole in the end of the sill and no bottom to the wing. So I patched the sill and built a bottom to the wing out of sheet steel. Again with a touch of filler to mask it should look nice I'm quite proud of this second repair I must be starting to get the hand of this welding lark On a side note my oil leak problem is ongoing. I have confirmed there are no leaks from the pushrods , the oil sender is properly sealed again. I have traced the leak and its a weird one that I cant think how to get around. Its bubbling out of the dipstick tube only with the dipstick in place. Any ideas on how to stop it?
Apr 13, 2011 16:28:11 GMT
Dipsticks often have a felt washer to stop oil leaks. More modern cars use an o-ring, but the dipstick and tube need to be designed for it.
How's the crankcase breather? If it's blocked that will make otherwise small oil leaks much worse.
@GUEST
Apr 13, 2011 18:11:13 GMT
The crankcase breather is absolutly shagged. But I cant get another one. However it is shagged in the form that it wont close here it is As for the O ring maybe a bit of igenuity to make one fit is neccesary.
Apr 13, 2011 19:11:19 GMT
The o-ring will need to be in constant compression, ideally radially (in other words a tight fit in a tube). If the dipstick is anyhing like the thin, bendy metal things fitted to old british cars you'd be better off with a felt 'seal' that only needs a light pressure due to it's natrual springy-ness.
That breather's odd. If it a one-way valve? And does it vent into the inlet somewhere?
megzy
Apr 13, 2011 19:12:36 GMT
please don't fill that full of filler. the filler wont stay in after a few bumps. try going back over the holes with the welder. apart from that looks a good project
@GUEST
Apr 14, 2011 18:08:02 GMT
The breather is a carter valve yes a one way and is designed to keep an even crankcase pressure. As this is a boxer twin. i.e. both pistons move together at the same time the crankcase volume is in constant flux. I have sorted the problem and it was related to the carter valve which had dislocated blocking the breather outlet to the air filter. This pic shows the fitting. The valve again had dislocated resulting that time in blue smoke. The black pipe is connected to the air box. Oh and this may give an idea of just how much oil it was chucking out
@GUEST
Apr 28, 2011 16:51:33 GMT
Today has been presented to me by the devil himself!! Got up this morning and took Gladys up to do some work on Bruce who fought me every step of the way and 7 hours later I'm very tired and haven't really got very far. Bad Bad car! I decided to call it a day chucked all the tools in the triumph jumped in DAF and headed home only for her to decide to break halfway home and all the tools are 7 miles away in the ruddy triumph! Anyway this is whats happened Open bonnet hello that don't look right where the tie bracket gone? waa waa waa too seperate pipes where there should only be one That silencer is less than 500 miles old to say that I am curse word off with it would be the understatement of a century. So I strapped it up and limped home with a missfiring engine. No back pressure and a harley davidson sound track. Only I now have to remove the silencer to repair it and remove that engine mount to make a bracket to reduce vibrations. Oh and did I mention all the tools are in the ruddy Triumph!! ARRRGGGGHHHHHH Paul
MK2VR6
Mk2 Golf GTi 90 Spec
Aug 14, 2023 20:06:36 GMT
Just spotted this on Flickr. Photo taken three years ago so I guess the condition is even worse now. What happened? Real shame to see the old girl looking abandoned. Where did OP vanish?
