Sept 20, 2011 3:49:17 GMT
I just thought you should know that I've had a terrible day, and considered quitting my job more than once since I woke up this morning, but then I found this thread, listened to the videos and now I'm giggling like a loon.
What a spectacular car!
Sept 20, 2011 7:31:28 GMT
I just thought you should know that I've had a terrible day, and considered quitting my job more than once since I woke up this morning, but then I found this thread, listened to the videos and now I'm giggling like a loon. What a spectacular car! Well I'm certainly glad I could stop you from quitting your job...lol
Sept 29, 2011 17:00:46 GMT
Sept 29, 2011 19:32:33 GMT
If it doesn't work you could also try some bonnet raisers, might help...
Sept 29, 2011 19:35:29 GMT
If it doesn't work you could also try some bonnet raisers, might help... I don't realy understand bonnet raisers as the rear of the bonnet is a low pressure area.
Sept 29, 2011 22:23:22 GMT
Good luck this weekend, hope the heat aint too much. Look forward to pics afterwards.
Btw is the fan to encourage hot air out or cool air in?
The good news is, the fan worked perfectly (no heat soak to the top mount), the bad news, had a couple of poor runs, then Fitted my nitrous bottle, but on the staging line it burst a pipe and dumped it all, then to make things worse this happened
Last Edit: Oct 3, 2011 7:51:33 GMT by claymore
v8chevette
PROUD TO BE BEIGE!!
I did that the first day I got the chevette running, far to giddy and forgot to put the bonnet pins in
I did that the first day I got the chevette running, far to giddy and forgot to put the bonnet pins in Got another bonnet already donated, so at least I can cut the new one up properly, instead of a little chop here a little chop there. did you see the nitrous go....lol?
v8chevette
PROUD TO BE BEIGE!!
Nah I was pushing my mates 32coupe.
I forgot how to change in to 3rd gear on the Saturday lol, glad to here you have a replacement bonnet sorted.
What times did you run?
Rubish, best I managed was a 14.8
v8chevette
PROUD TO BE BEIGE!!
.2 faster than the R32 golf that was running, not to shabby for a big estate car.
I was hoping to get into the 13's yesterday with nitrous, but hey ho, I'll have another go at the end of the month
KruJoe
Really enjoying this thread! The bonnet incident is bad luck - Gutted - but in a way you're lucky it didn't take out the screen / wipers / roof! I also have a bonnet if your replacement doesn't come through, and hinges etc... I'm in N Yorks by the way.
Breaking: V.850, R8 214, Escort, 205, Justy Tat: Lada Samara 1.5, BX14 (Daily driver), Thai 850 2.3 20v LPG.
Really enjoying this thread! The bonnet incident is bad luck - Gutted - but in a way you're lucky it didn't take out the screen / wipers / roof! I also have a bonnet if your replacement doesn't come through, and hinges etc... I'm in N Yorks by the way. Cheers, I'm amazed at the number of people who have offered me bonnet's
someone got a picture of me loosing all my nitrous.....lol
nofrills
my wings are made of Steeeeeeeel!!!
Blimey mate, but look on the bright side it could of been worse.... i have a small question for you, do you run a progressive controller on your nitrous or a push button to fire it?
Blimey mate, but look on the bright side it could of been worse.... I have a small question for you, do you run a progressive controller on your nitrous or a push button to fire it? LOL...everything I do is basic, so I have an arming switch on the dash and a wat switch on the throttle linkage.
Last Edit: Mar 8, 2015 9:08:10 GMT by claymore
Last Edit: Oct 9, 2011 15:01:52 GMT by claymore
