oohh nice build you have there and compound aswell, just out curiousity how do you plan to control the compound effect? I think by adjusting the turbo's wastegate i can controle how much boost the supercharger gets, initially I,ll lower the turbo's boost to about half a bar, and see what the compounding produces. it will be very much suck it and see to start with.
taint
Kinda New
I like my toys
Jan 20, 2011 21:06:39 GMT
oohh nice build you have there and compound aswell, just out curiousity how do you plan to control the compound effect? I think by adjusting the turbo's wastegate I can controle how much boost the supercharger gets, initially I,ll lower the turbo's boost to about half a bar, and see what the compounding produces. it will be very much suck it and see to start with. with my first attempt at compound boosting I found the boost spikes so unpredicatible, I had the turbo making 6psi and the supercharger making 10psi which ended up giving me 21psi but I still got boost creep. I found that if you plumb the supercharger to blow into the turbos then you still get the benefits of running a supercharger for lowend boost and a turbo for highend efficency but without the compound effect. with your eaton charger there I would reccommend a throttle type blow off that opens when the car is on idle after the supercharger (unless you move your engines throttle body before the supercharger), because those merc eatons (any eaton for that matter) make alot of noise when they are pushing against a closed throttle body.
Last Edit: Jan 22, 2011 10:42:24 GMT by taint
Mercedes 190E 3.2l Renault 5 1.8 16v Vanagon 1.9 TDI Mk1 Honda Civic CRX 1.6 VTEC BMW touring 530D
Jan 23, 2011 14:18:26 GMT
Well as prommised, a vid of the first start, unfortunately I'v run out of hose clips so I can't rev the engine (it just blowes the boost pipe off as soon as i close the throttle) still to do, fit the oil cooler (I'v just bypassed it for now) modify bottom hose and then tidy up. then comes the slow process of mapping it using a dastek unichip.
namless
Club RR Member Number: 26
Jan 26, 2011 21:38:28 GMT
that sounds evillllll... nice man
Jan 29, 2011 12:01:53 GMT
I now have a hole in the bonnet, (still a lot of fetteling to do yet) And now we have boost, (don't these mobile phones have curse word sound quality)
Finlay
Jan 29, 2011 12:35:48 GMT
2 thumbs up, cant wait to see it on the move :-)
95 clio 16V - modded track/road car
95 clio Williams 2 - restored to standard
95 TVR Griff 500 - Taraka engine upgrade
MNR Vortx (kit car) - busa power
Chevette SR20 engine
MK2 Escort GM LS1
Chevette XE (building)
excellent! more progress is required and expected of you soon.
Good use of a GTiR intercooler excellent progress, can't wait to see it a RRG2011!
good work man, i like the idea with the bonnet vent i wonder if i can do summat similar to the cav... I'm up this weekend dude so you will have to pop round and we can have a good look
good work man, I like the idea with the bonnet vent I wonder if I can do summat similar to the cav... I'm up this weekend dude so you will have to pop round and we can have a good look You'll have to come around here, it's not on the road yet.
Last Edit: Feb 5, 2011 13:46:12 GMT by claymore
So how does it feel? Is it doing what it is meant to?
So how does it feel? Is it doing what it is meant to? To early to tell, that run was with the maf disconected, with the maf connected it's over fueling badly (which isn't a surprise) so it's now a case of getting the dastek connected and getting the car mapped.
I upped the boost today (bloodey hell it feels strong) and spent the day putting pipes back on...lol, I must have jacked the car up about 10 times today..lol so I'v took off all my alloy joiners and will weld beads on them all tomorrow, I knew I'd have to do that anyway but I wanted to wait until I had all the pipe runs sorted.
Bioshock
It aint hip to be square.
I love the T5 we got to replace our old 940T. Nearly 300bhp.Hybrid Turbo, Rica chip,forge blanker,Bucket size pipercross induction kit,MBC, V70 injectors. Just trying to get the power down through the fronts is a nightmare.......Sticks the dog to the rear window nicely! ;D
Almera GTI = ugly bird who turns out to be great in the sack = Win
Feb 13, 2011 12:00:48 GMT
All the pipes are staying on now, so it's ready to go for it's mot on tuesday (it's going to fail on a wishbone and a split drive shaft gaiter, but I can't get the hub nut undone, so they'r going to crack it open for me at the mot, then I'll change the wishbone and do the gaiter and take it back) have some picks: the back slot in the bonnet will be to let hot air out. The scoop is partitiond the front draws cold air onto the tmic, the back half lets out hot air (I may have to make a bigger hole in the back)
Last Edit: Feb 13, 2011 12:02:48 GMT by claymore
Feb 21, 2011 22:23:59 GMT
good to see this is going well, mot'd and mapped yet?
faild mot on wishbone, driveshaft gaiter and emmisions. co = 13.08....lol hc = 1117 ppm.....lol
going for a re-test tomorrow.
Feb 22, 2011 16:27:58 GMT
just insured the car, £440 with all mods declared
Feb 23, 2011 18:22:25 GMT
Now with MOT, let the fun begin
