Apr 29, 2011 17:34:15 GMT
Apr 30, 2011 16:24:20 GMT
Got the old zaust of this morning and worked out how I'm going to run the new one. Then I dropped the old gearbox back in and refitted the new intercooler and rad. All the pipework seems to route well and clear everything. Much tidier than the last setup. :-) Plenty of room for a second smaller rad fan. I may run that one constantly and have it on a timed relay along with a small pump to circulate coolant through the turbo after shutdown.
Apr 30, 2011 17:36:04 GMT
thats looking very promising. Good catch getting that bearing out before it completely shot the box to bits.. remember my brother having a 1 lite one of these and the thing would pull nearly 40mph in first gear.. (he wasnt afraid of high revs) a reg one.. brilliant thing to drive as well
Apr 30, 2011 17:51:22 GMT
Very lucky! With the new box it should pull 50 in first, 75 in second, 95 in third and at least 125 in 4th.
We're just sorting out the maifolds and feeds etc for the new turbo. Hoping to break the 200bhp mark this year ;D
May 10, 2011 20:11:58 GMT
Standard Dash Diet Dash Not the most scientific of measuring sticks, but it's good enough as a guide. It had the heater at 7KG :-) So with a few other bits and bob's that's 12KG out of it already.
May 12, 2011 10:06:41 GMT
Partial defeat by the gearbox last night. However Andy devised a novel way of assembling synchro hubs with a tie wrap.
May 15, 2011 16:12:02 GMT
Lots of progress this week :-) Benross Racing have nearly finished the head refurb/upgrade, should be a cracker when it's done. The block has been stripped and drilled for 11 head studs. That'll be getting dropped into Force Racing for new cam bearings tomorrow. There oil fed thrusts have done their job well, the thrusts are near on perfect after a load of abuse on the road and drag strip. The new rotating assembly will be going for balancing tomorrow too. The new box is just about done, just need to fit the diff. New exhaust is nearly sorted. Got the new turbo butchered onto the metro manifold. Getting there.
May 17, 2011 20:06:15 GMT
Some ham fisted sod has snapped the bit of the waste gate arm that holds the actuator arm on (before we got the turbo). So I've wobbled up a new one. Turned out OK. Then we pulled the engine out of my mini, dropped it in the van and shoved a few things on. Should all fit and work. Actuator will be a bit of a pain though.
May 28, 2011 15:46:12 GMT
Got the oil drain sorted. Not pretty, but it should do the job. Got the down pipe sorted. All lines up nicely, just needs welding up. Got the short engine built. Finished the gearbox And stuck them together Benross Racing has also finished the head refurb/upgrade. New guides and 30/36 stainless valves. In comparison to it's original 'Stage 3' porting, the chambers are massive and the ports look great, should be a big improvement. :-) Getting there :-)
ben1
May 28, 2011 17:56:38 GMT
Allot of good work there, very inspiring, I'm also a metro owners have you seen on the owners club too
May 28, 2011 18:05:57 GMT
Thanks. We can see the light at the end of the tunnel now.
I'm not aware of anybody else who has put a GT17 down the back of a metro engine, hopefully another first :-)
ben1
May 28, 2011 18:10:54 GMT
Wont be even attemping it really, looks abit too hard for my skills, the welding on the inner wings on mine is enough for me
May 28, 2011 18:12:28 GMT
Bit of spanering, bit of cutting, bit of drilling, bit of bzzzzzzzzt. piece of cake
May 29, 2011 16:18:04 GMT
Got the downpipe welded up. Noticed a bit of a restriction in the mouth. So I ground it out a bit
hamps
www.medwayrscentre.co.uk
May 29, 2011 16:51:51 GMT
Awesome
May 30, 2011 17:20:57 GMT
It wouldn't be our van with out a rusty hole in the floor come MOT time... Exhaust and fuel plumbing is sorted. I've shifted the fuel filter out of the way and plumbed it in after the pump. Got most things slung in place in the engine bay, should all fit OK... Also whipped the interior out so that John can have the pleasure of chipping of the sound deadening from the floors :-)
May 30, 2011 21:50:25 GMT
Love this car! I love the constant tinkering! so cool.
BTW- what weight oil are you running in your carb? Older SUs are meant to have have 20 weight but I have heard the HIFs like yours (and mine) should have 20/50 like say Gtx?
Last Edit: May 30, 2011 21:53:17 GMT by yoeddynz
Thanks. Hopefully the tinkering will be done soon and we can start driving it again!
We use propper SU damper oil. engine oil, 3 in 1 etc is no good as it's not what the carb as designed to run with.
May 31, 2011 20:19:42 GMT
Engine
