Nov 12, 2009 22:20:49 GMT
my sister has just brought a Nissan Figaro. the wheels are a pure letdown. so I'm thinking a lotus steel wheel look. but I'm stuck on the center caps?? how would I get the center caps to fasten on to the banded steel? sry bout the newbie question but cheers for Any info. choppah
MonzaPhil
Think like a man of action, act like a man of thought
Nov 12, 2009 23:02:28 GMT
How about swapping for some non Nissan steels? I think they are 4x100 (possibly?) so old Vauxhall like on mine... Are the Figaro ones full wheeltrims or just centres? Can't see any major challenges facing you.
This is now a clicky linky!
will
Nov 12, 2009 23:11:08 GMT
If they are just center caps and not a full trim you should find they fit in the same way if you get your current wheels banded. Even if they are a full trim it may still work. Welcome to RR
miaspa
Nov 12, 2009 23:15:06 GMT
The chrome hubcaps on the fig are plastic, and have clasps that grab the nuts. So would fit most wheels, the white trims don't fit on Micra K10 wheels.
Found my flashing Pao again.
Nov 12, 2009 23:30:26 GMT
cheers for the welcoming response
the current wheels are a really tacky alloy wheel, so i was thinking micra banded steels (as there Penny's and banding ain't a problem either) with a chrome center cap.
is there a universal cap or an aftermarket cap i can buy?? or is it a case of modifying and adapting a set of caps to fit??
cheers choppah
Nov 12, 2009 23:32:50 GMT
oh the resson for micra steels and not a vauxhal or vw steel is the offset
Nov 13, 2009 12:43:36 GMT
Hope that you know that if you band the steel wheels, you will change the offset unless you band them equally much on the in- and outside.
194? Willys Jeep MB 1965 Volvo 544 Special 1968 Opel Rekord 1975 Opel Kadett Estate 1985 Mercedes-Benz 230E 1985 Datsun 720 King Cab 4x4 diesel 1997 Volvo S70 2.5SE (ex. "Volvo544special65" - changed to more reader friendly username. )
Nov 13, 2009 16:46:53 GMT
Figaros look fantastic with the white polo mint hubcap removed. The chrome centre cap is separate, so just clean the black steels and leave as-is. Figaros look good on Mini-lites and with 12" Moon discs from here: www.roadhouseretro.com
markbognor
Club RR Member Number: 56
Nov 13, 2009 18:23:10 GMT
Some Figaro inspiration. Wide steels on a pao. If you really get stuck you could always weld on tabs to hold on the chrome hub caps in a simmilar fashion to early Beetle wheels. Or maybe use the K11 base spec centers as a method of holding on something else by gluing them to the K11 items. They might even work in the center of the banded steel.
Last Edit: Nov 13, 2009 18:24:15 GMT by markbognor
