Oct 25, 2009 20:34:22 GMT
If you're anywhere near Ramsgate in Kent, I know a guy with another one. A local guy has an X-reg (1982, I think) Gamma coupe in that Royal Blue colour, that he bought for £200 - it may even be that very one from Ramsgate, as I know he bought it in Thanet recently. So far it has needed new front discs which had to be machined down Citroen items, and I've helped him with the Weber carburettor wiring, also today the rear lights. It now runs quite sweetly, and most of the electrics work - shock, horror! One snag he has is that the headlamps are pointing low. They appear to have a pneumatic/vacuum-controlled height adjusting setup, but does anyone know where the control for this is on the dashboard? Also, where to obtain a new air filter element - they seem to be very thin on the ground...
Oct 25, 2009 20:51:51 GMT
I'm sure the headlamps are worked from an attachment on the rear axle that senses if the boot is loaded up,try going into a decent motor factors to try and match them up,although i can't remember if the gamma has a really odd shaped airfilter.
always liked gamma's went to look at a berlina once,but even as a beta owner the prospect worried me a bit!
stefan
If it isn't broken fix it till it is
Saab transplant is good idea nice engine
POWER IS EVERYTHING WITHOUT CONTROL
1985 Honda jazz 1997 Saab 93 convertible 2010 transit 280
wuvvum
Oct 26, 2009 20:13:40 GMT
Wasn't it just the early ones of these that had the cambelt/PAS issues? I'm sure I remember reading that Lancia sorted the problem on later cars. Mine had had the PAS disconnected so it wasn't an issue - still perfectly manageable without it.
Oct 27, 2009 10:16:34 GMT
from what i have read they made the problem much less likely to happen with the redesigned pulleys etc but wasn't 100% apparently. The later version is on the left,note the extra idler
Oct 27, 2009 10:30:50 GMT
(quote)Also, where to obtain a new air filter element - they seem to be very thin on the ground...[/quote] from what I read air filters don't seem to be readily available I know one bloke at least is using a ford element(reversed),not sure what its from anything you want to know about a gamma can be found on here gammaconsortium.com/lanciagammaforum/index.php
Last Edit: Oct 27, 2009 10:31:17 GMT by james54
Oct 27, 2009 10:47:11 GMT
Major kudos for the rare coupe, now sort it out and drop in a more powerful and reliable Alfa engine.
There is no such thing as a curse word car just overstretched expectations................. Herald 10/10 Gasser 10/10 Total score 20/10
gtxtra
Oct 30, 2009 21:40:43 GMT
hope there's one of these at the NEC!
91 Scala, 87 GTX 16V, 87 GTX BRM 152, 85 GTL, 81 GTi
Oct 31, 2009 11:24:10 GMT
I've got a brand new set of front pads for one of these sat in my CD rack at home, you can have em for the cost of the postage if you like (a fiver?) PM me if thats any interest.
Oct 31, 2009 20:18:52 GMT
Dunno why but i always preferred the Gamma Saloon over the Coupe
