first up, stuff left from last time-
1. complete front clip for 58-64 impala, broken down into boxes of bits. complete springs/wishbones/brakes/etc. I have the X-member with about 6" of chassis rail either side, and its rustfree. ive also go a pair of original/correct 14" chevy steels with new 185s to match. £75 the lot. this probably weighs more than my caddy does, so postage aint really an option unless you want it palleted up for about £60.
2. merc hubcaps. probably got 3 or 4 sets of these, £20 a set?
5.oil cooler. 1/2" ports, 13 row, 10"x8" matrix, a few small marks but nothing major, doesnt leak. £20
6. pre 67 bug rear valance. small cutout in centre at bottom for some reason- header clearance? otherwise new. £15
7. nissan fendermount mirrors. these were NOS when I got them, ran them on a car for about 2 months, so they're pretty much perfect condition. (the brown/yellow stuff on the baseplates is grease I lathered over them to stop them corroding) £50.
8.sierra sapphire rear drums. good usable condition, no lip, normal surface rust, £10
9. pair of 13x7 minilites (actually superlites) ET -6, good condition, no kerbing but flaking laquer on the dish. mini 4x4" stud pattern, I ran them on 4x100 no problems. tyres are 195/55 pirellis but are close to dead- I left em on as they hold air so are good for rolling a project around/ doing skids, but are close to a nicking for road use. £65.
11. mk3 golf rear lowering springs, jamex. part no. 85 3314rear. biggest drop they do, 60 or 80mm I think? £20
12. brand new VAG radiator. valeo brand. fits mk5 golf/jetta with the 2.5L motor. never fitted, a few storage marks on one side, loads of mounting points on both sides and the ends, so easily adaptable to your application. inlet and outlet both on LHS. £30.
new stuff. am getting into the boxes of stuff now, so I think quite a few interesting bits will start to turn up-
13. pinto HT leads. set of 5. orange, 7mm silicone. good clean usable condition, no damage. £10
14. magnecor electrosports 80 leads, set of 7. for vauxhall senator. (came off a 12v but I believe they fit 24v too) 8mm, blue. have a set of the lead number tag thingies fitted too. good clean usable condition, no damage. £25.
15. couple of bosch blue coils, with brackets. may have minor dents, but work fine. £5 each.
16. random assortment of stacklight merc (w114/w115) bits. a load of black interior trim parts. armrests are for rear doors. other bits will fit any door. 2 sets of vgc original wipers, one set of vgc original blades (so they're the right colour), and a minto set of headlamp rims (if you own one of these cars you know what they're usually like!)
tenner for all the door bits
tenner for all the wipers
20 quid for the headlamp rims.
17. more stacklight stuff-
black underdash card for passenger side (i think, will check) the always-broken front footwell plastic section, also in black, and the centre console mat, in black too.
18. a rather special set of w114/w115 merc headlights. no only are they perfect hella lenses, perfect chrome rims, and perfect bodies with good reflectors, they're angel eye lamps too! (will connect up later to get a pic of them on). proper H4 beam units which I fitted to the original brackets, so they adjust in the stock manner. £60 (the angle eye units cost that alone)
19. model A chassis ends, off my A- had various holes welded up in the past, but are smooth/solid. £15
20. a CB rig.
sonic unit(model GT-868), altai mike. works as far as I know. £10
21. pair of smiths gauges in chome underdash panel. oil pressure in psi, and water temp in C. matched pair of full sweep gauges with black faces, white letters, and white needles. 1301 series. complete with bulbs, wiring, capillaries(each about a metre long), and oil T-piece. £40.
23. mk1 mondeo (fit mk2 as well) genuine factory RS side skirts. all fittings included. £35.
24. mk1 mondeo genuine factory RS overbumpers. front has fogs and grille in vgc. they simply bond on over your existing bumpers, and have a few screws and clips for extra security (included) a few scruffs from storage, and a kerb srape on the bottom corner of the front one, will easily paint over. £50.
25. RHS rear corner for a vw splitscreen van. good cond all way up to gutter, bottom gone below light, has edges/lips but are a bit rough so id just view it as a new corner skin- good if yours is stoved in as i don't think you can get a repair panel for anywhere higher up than the light hole. £30.
26. spotlights, matched set of 4 same brand, 2 near, 2 far, all halogen, all work, no rust on sheels, all mountings present and correct and laods of wire attached. £30
27. mazda mx-5 1.8 brakes. full set of discs and calipers with less than half-worn greenstuff pads. pads are nearly 120 quid new!! £150. pics later.
all items in manningtree near colchester.
can post no problem.
yes I take paypal.
PM, ddmetalworks@hotmail.com or 07813289931 to get in touch with me......
PICS TO COME AS THEY UPLOAD ON MY PAINFULLY SLOW CONNECTION!
20. a CB rig.
yes I take paypal.
