Aug 23, 2009 14:37:45 GMT
Hi guys, I have a radiator for my ca18det capri. It has no filler cap in it, would I need to get a pressurised header tank (as in a plastic bottle with a screw on cap) as opposed to my 'flip cap' pinto overflow bottle?
Also, would I be able to use this to fill the rad or would I have to get an inline filler cap in the top hose? Cheers
Also, I need to extend the thick (+) battery cable from drivers side to passenger side, what ampage wire etc... would I need for this? I'm not the best electrician. Also where would you recommend to buy it? thanks a lot in advance
Aug 23, 2009 16:22:42 GMT
Aug 23, 2009 16:58:51 GMT
pick the cable up from a welding supplies shop. They should have heavy stuff in stock and its usually much cheaper tan other places.
purplevanman
Way too orangey for crows
Aug 23, 2009 22:48:10 GMT
welding cable is good stuff, comes red or black too
Welder, fabricator, general resto work
you can still use your pinto filler / expansion bottle just add an inline header / rad cap jobbie in the top hose. All kit car places do these in the 32mm you'll need for about £25 inc cap.
ENSURE your expansion bottle is higher than the rad cap where possible to ensure it flows back into the system when cooling, the one in me herald is too low and I keep having to top the system up, lol!
Aug 25, 2009 11:15:21 GMT
So I can use the pinto expansion tank bottle thing that has just a normal flip top? (ie not a twist off pressurized cap) and then just put a rad cap in the top hose? Sorry MightyMork can't work, out are you Tims friend who was there when we picked up the engine?
Aug 25, 2009 11:19:22 GMT
Yes is the answer to both of your questions, hehe!
Aug 25, 2009 11:32:54 GMT
Haha, cheers dude!! Couldnt work it out! Thanks for your fast replies too!! Ive got the rad in and sorted all the pipes, intercooler has been modded a bit to fit behind the front panel and Ive sorted all those hoses too. Got the wiring lying roughly where it needs to be in and out the car and about 60% of it clipped together. Got to do the earths and extend the battery cable. Got to work out how much HP fuel hose and I need to buy and fit that and then the exhaust. I think I'm just going to get a straight through mild steel pipe and connect it to my pinto performance backbox. Cheers for your help dude
Aug 25, 2009 11:45:46 GMT
nice progress dude, lack of updates in your topic tho.
hope to see this finished up soon. keep going!
